Wampler - Triple Wreck  [traced]
J0K3RX
Has thanked: 316 times
Been thanked: 556 times
Post by J0K3RX »
Versus wrote:
MullisMan wrote:
pedalgrinder wrote:How did you go mullisman you were going to post your latest eagle files. Iam pretty keen on them since they have the boost section and i see that as a majority of the point of this pedal. To do one without the boost makes it no different to a glorified tubescreamer in my view. The boost is what sends it into overdrive mayhem.
Sorry for the long wait. I've been busy getting married and working. Here are the eagle files for the disortion section and the boost section of the Triple Wreck.
Only differences here are the power section. The power for the Boost board comes from the distortion board, there's a pad labeled Va, use that.
Cheers.
JM
Hi guys! Anyone used this pcb? Work?
No but, the madbean "upper decker" layout is excellent!! Works 100% and has on-board pots and the boost circuit!
Don't know if it's posted here but I can send it to you if you can't find it..
Versus
Post by Versus »
Send, please. And thank you for your kindness!
batak_man
Has thanked: 15 times
Been thanked: 7 times
Post by batak_man »
+1 sir.. :applause:
1 have another TW layout(beside R Custom), but madbean layout make me curious
If you want my layout i can send it to you
thx sir :D
Versus
Post by Versus »
+1 sir.. :applause:
thx sir :D
Send me too, please! For collection :D
J0K3RX
Post by J0K3RX »
Here is what I have...
I also redrew the layout with the pots all mounted facing the same way... The parts layout is pretty much the same but had to move around a few components to make it work... You will have to figure that out for yourself if you want to use my redrawn layout, not that hard to figure out!
https://dl.dropboxusercontent.com/u/111 ... 0Clone.zip
batak_man - I would like to see yours also!
batak_man
Post by batak_man »
This is TW layout that i found :mrgreen:
http://www.4shared.com/office/j4Ayv3m-/ ... Wreck.html
Verified? I think yes, to make sure youcan trace it again
I already make the PCB, just wait mood to solder it
J0K3RX : thx for upload man
J0K3RX
Post by J0K3RX »
I think I have seen that one before...? I like the use of the TL074 and no boost circuit! The boost is awful in my opinion and doesn't need any boost either.. Plenty of gain without it. The boost just makes it into a fuzz box, kills the attack and just sounds like garbage...
batak_man
Post by batak_man »
what kind of TL072 that u use?
In my place i just found TL072CN, i cant find tl072P (it is TI?)
I think TL072P more good than CN :twisted:
Lozboy
Post by Lozboy »
"The N has better heat dissipation and is good at higher temperatures than the cheaper P package"
This is a quote I found some where on the internet.
Both will do just fine.
J0K3RX
Post by J0K3RX »
TL072 is the actual op-amp chip and manufacturers may add suffixes to denote the type of package and or operating temperature. In this case the 'P' means it's in a plastic DIP (Dual Inline Package) but other manufacturers may use 'N' to mean the same thing etc... I don't think operating temperature will factor in much in this case.
leftfingaz
Post by leftfingaz »
im looking at rcustoms layout then i see x1 x2 x3. I will make a two hole for input, output, and volt? how can i wire that into the 3dpt? :( :( or can someone send me the schematic and pcb layout of madbeans? :?: :(
rcustoms
Has thanked: 363 times
Been thanked: 520 times
Post by rcustoms »
leftfingaz wrote:im looking at rcustoms layout then i see x1 x2 x3. I will make a two hole for input, output, and volt? how can i wire that into the 3dpt? :( :( or can someone send me the schematic and pcb layout of madbeans? :?: :(
just see the schematics remember this is only the main circuit not include the boost section
SCHEMATICS 3w.pdf
(195.58 KiB) Downloaded 372 times
guitars,pedals and amps.
@zuleta.rafael(Instagram)
leftfingaz
SCHEMATICS 3w.pdf
thanks. this will be my first diy pedal :D
leftfingaz
can i use 2n5088 subtitute for 2n5089?
rasta_maleek
Has thanked: 52 times
Been thanked: 52 times
Post by rasta_maleek »
leftfingaz wrote:can i use 2n5088 subtitute for 2n5089?
yes, you can
J0K3RX
Post by J0K3RX »
yes, you can
rasta - Watched your youtube vids.. Did you build that ubershall 15w? Sounds bad ass as a mutha!!!
rasta_maleek
J0K3RX wrote:
yes, you can
Yes, I did. One of my last builds. Like the brunetti mercury box in zvex style enclosure. I can't stay stopped.
Thanks, I hope build some more.
leftfingaz
thanks
ballfire
Has thanked: 38 times
Post by ballfire »
hello ....
is there a correct pcb trace here using a dual op amp on triple wreck? any?
thanks..
rocklander
Has thanked: 1406 times
Been thanked: 231 times
Post by rocklander »
ballfire wrote:hello ....
thanks..
is this trick question? don't they all have at least one dual opamp?
