Wampler Pedals - Triple Wreck  [traced]
Re: Wampler -Triple Wreck-
Postby rullywowr » 06 Dec 2013, 01:27
Thanks for the kind words, I appreciate it! :D
For more information about getting a board set, you can click the link in my signature. Let me know if you have any questions.
rullywow industries - DIY Guitar PCB Projects
http://www.rullywow.com
rullywowr
Have thanks: 7 times
Postby TubeHugger » 06 Dec 2013, 10:50
rullywowr wrote:Here's my layout for the Triple Wreck, complete with 3PDT breakout board (for switches and LEDs) which connects to the main board with a 6 conductor ribbon cable. Fits in a 1590BB perfectly.
[ Image ]
[ Image ]
[ Image ]
Probably the most brutal distortion I have ever built/used. It does have a bit of squeal say past 90% on the gain pot, but that is to be expected for a pedal that has a ridiculous amount of gain. I have extra boards if anyone is interested, hit me up.
[smilie=eek2.gif]
wow what a magnificent build.
have clips?
"JMP it's a good place to be" - Big Bob
TubeHugger
Have thanks: 2 times
Postby Casuistry7 » 07 Jan 2014, 21:26
I would also like to hear this in action. I read all 21 pages of this thread and their is a few spin offs off the original posted schematic. I was able to learn 3PDT wiring for a box, and how to find parts on mouser..... It takes a looooonnnng time, lol. Also got a good grasp on some opamp stuff as well as converting uF-nF-pF. Just wanted to say thanks to all who supplied info on this.
Casuistry7
Postby andregarcia57 » 05 Feb 2014, 10:36
as I get a bit more volume?
andregarcia57
Have thanks: 82 times
Postby AAntonio » 11 Feb 2014, 18:33
HI
there is some mods to have more high
the pedal is a little dark
I did this project
For this message the author AAntonio has received thanks: 2
Nicht Bernd (12 Feb 2014, 09:24), rocklander (11 Feb 2014, 20:00)
AAntonio
Have thanks: 15 times
Postby J0K3RX » 11 Feb 2014, 19:01
AAntonio wrote:HI
I did this project
Looks good but it's too small to see the components. Do you have a larger pic and what the mods are?
J0K3RX
Has thanked: 278 times
Have thanks: 432 times
Postby AAntonio » 11 Feb 2014, 19:11
J0K3RX wrote:
AAntonio wrote:HI
I did this project
yes
What can I change to have more high????
Many thanks
Nicht Bernd (12 Feb 2014, 09:26), rocklander (11 Feb 2014, 20:01)
AAntonio
Postby andregarcia57 » 12 Feb 2014, 10:26
I need a bit more volume here. how?
andregarcia57
Postby andregarcia57 » 12 Feb 2014, 11:05
rocklander wrote:I've made a 1590a layout.. I think it's right.. I built it and I get high gain sounds, but it's sounding a lil farty at times.. I think (hope) that it's something other than this pedal cos I'm getting the same result on a bsiab I made too so could be dodgy (car) speaker in my ruby is finally gone, or something else... all the controls do what they say though :blackeye
the orange and green are jumpers, and red is 9V, brown is 'B' just for my reference
(note the version numbers between the PCB and layout are different, but the only change was R10 value, not layout as such. thanks to slash555 for pointing that out :blackeye :thumbsup )
layout
PCB
expressPCB project file and PDF (A4 paper size) including rcustoms' schem (hope that's okay, happy to remove it if if not)
triple-wreck.zip
triple-wreck-1590b-TL074-pcb-schem-layout.pdf
andregarcia57
Postby jymaze » 12 Feb 2014, 18:22
You can try to bump R22 to 1 meg or even 2 meg. It should not create any significant noise as it is far in the chain of gain stages.
jymaze
Has thanked: 87 times
Have thanks: 158 times
Postby AAntonio » 12 Feb 2014, 19:28
for the high, I replaced with a capacitor c13 from 0,047 to 0,022
it seems to go better
what do you think?
AAntonio
Postby J0K3RX » 13 Feb 2014, 00:26
rullywowr wrote:Probably the most brutal distortion I have ever built/used. It does have a bit of squeal say past 90% on the gain pot, but that is to be expected for a pedal that has a ridiculous amount of gain.
That is a great layout! Squeal past 90% on the gain pot? That should not happen, I have built quite a few now and have not had that problem.. They can be a bit noisy which is normal but no squeal. The squeal may be happening because you have the input and output coming off the board right next to each other and the ribbon wires directly next to each other? I would separate them to opposite sides of the board with separated wires and shielded if needed..
On recent builds I installed a gate like the TM and fine tuned it for zero noise.
J0K3RX
Postby chi_boy » 13 Feb 2014, 03:48
Thought I would show off a couple of successful builds. One is mine and the was built by another forum member.
This is a modded version with a SHO replacing the original booster and a charge pump on board for selectable 9V or 18V operation for both the SHO and the main circuit. The SHO is wired as a boost AFTER the main. This gives a nice volume boost when it is needed rather than the flubby boost of the original.
I can't take credit for the mod ideas themselves. Those were gleaned from the forums and other users.
Cheers!
For this message the author chi_boy has received thanks:
J0K3RX (13 Feb 2014, 08:57)
chi_boy
Has thanked: 26 times
Have thanks: 13 times
Postby grrrunge » 13 Feb 2014, 07:29
chi_boy wrote:Thought I would show off a couple of successful builds. One is mine and the was built by another forum member.
Cheers!
[ Image ]
[ Image ]
Looks great! Where do you get your boards made?
grrrunge
Has thanked: 58 times
Have thanks: 199 times
Postby chi_boy » 14 Feb 2014, 05:42
I get all of mine at Seeed. So far I've had vey good luck with them.
chi_boy
Postby J0K3RX » 19 Feb 2014, 04:58
Cheers!
[ Image ]
[ Image ]
This is the best I have seen yet!! Great work! got any top shots? I am working on a 1590b
J0K3RX
Postby chi_boy » 20 Feb 2014, 04:25
No, I actually didn't take any pics of the board topside before I boxed. I have some of the last version, but not this one.
Are you going SMD for the 1590 layout?
chi_boy
Postby J0K3RX » 20 Feb 2014, 04:51
chi_boy wrote:No, I actually didn't take any pics of the board topside before I boxed. I have some of the last version, but not this one.
lol, actually I was talking about the top side of the enclosure :wink: No, I am doing through hole and no boost circuit. But, I am adding a noise gate..
J0K3RX
Postby rocklander » 20 Feb 2014, 04:56
without boost, my layout may be of use?
For this message the author rocklander has received thanks:
J0K3RX (20 Feb 2014, 06:09)
rocklander
Has thanked: 1558 times
Have thanks: 286 times
Postby chi_boy » 20 Feb 2014, 05:46
Ah, my mistake! And yes, I have that! The SHO makes a HUUUUUGE difference. The other booster is terrible by comparison. The SHO simply makes it louder. As it should be.
For this message the author chi_boy has received thanks: 2
J0K3RX (21 Feb 2014, 03:00), rcustoms (20 Feb 2014, 16:27)
chi_boy
Users browsing this forum: andlord, dimonty144, Optical, peterc, picatostas, THE666 and 18 guests
