Wampler Pedals - Triple Wreck  [traced]
Re: Wampler -Triple Wreck-
Postby gnognofasciani » 06 Apr 2011, 18:31
Search button is your friend
For this message the author gnognofasciani has received thanks: 2
coldcraft (07 Apr 2011, 01:50), modman (23 Jun 2015, 12:56)
gnognofasciani
Have thanks: 11 times
Postby hewie » 06 Apr 2011, 23:44
Here's a small vero layout for the boost section if anyone wants it. Should be right.
For this message the author hewie has received thanks: 3
caspercody (07 Apr 2011, 00:01), Desdog (20 Mar 2015, 18:39), joeboo88 (07 Apr 2011, 00:55)
hewie
Has thanked: 20 times
Have thanks: 44 times
Postby earthtonesaudio » 07 Apr 2011, 00:31
gnognofasciani wrote:http://www.co-bw.com/Guitar%20Files/Guitar%20Amplifiers%20-%20Overdrive%20&%20Distortion_files/a_msm.gif
:thumbsup
Well there ya go. Notice that Marshall put a 100 ohm resistor in series to protect the op-amp from driving the 100n cap directly, and the 220n/100k before the input of the next stage significantly decreases the loading on the filter.
earthtonesaudio
Has thanked: 17 times
Have thanks: 109 times
Postby hewie » 07 Apr 2011, 05:22
Previous layout was missing some values, so here's the final vero layout for the Triple Wreck. It is now verified (by me) and sounding damn nice. Endless thanks to Eisy :applause: :applause: :applause:
For this message the author hewie has received thanks: 8
Chrismettal (13 Jun 2011, 13:28), joe_pineapple (07 Apr 2011, 19:57), joeboo88 (07 Apr 2011, 13:26), kantul (07 Apr 2011, 05:58), marmaliser (07 Apr 2011, 09:40), mcaviel (08 Apr 2011, 23:57), Quietus (09 Apr 2011, 01:24), SGJarrod (07 Apr 2011, 19:06)
hewie
Postby kantul » 07 Apr 2011, 05:55
audioguy wrote:
kantul wrote:I'm trying to create a layout based on the above scheme. Has not been verified. Tell me if you see an error there. thank you :)
This layout looks nice. Have you verified it yet?
Hi Audioguy,
Actually, after I checked, I found one the wrong track in my layout. Between C5 and R6. I fix it. I delete the previous image. But I really don't have time to try to build now. maybe next week I will try to build it.
I still hope that if there is someone who can make the layout better. This layout looks too big. I'm not familiar using perf layout.
Here :
http://i166.photobucket.com/albums/u90/ ... layout.gif
http://i166.photobucket.com/albums/u90/ ... ewreck.jpg
kantul
Postby kantul » 07 Apr 2011, 05:57
hewie wrote:Previous layout was missing some values, so here's the final vero layout for the Triple Wreck. It is now verified (by me) and sounding damn nice. Endless thanks to Eisy :applause: :applause: :applause:
wow, great. This layout looks better.
kantul
Postby hewie » 07 Apr 2011, 08:09
Mainboard with Boost add-on is verified.
Finished product (minus LEDs)
:horsey:
joeboo88 (07 Apr 2011, 20:26)
hewie
Postby demym » 08 Apr 2011, 17:37
very good Hewie !
I also did a veroboard layout, but something went wrong (although the electrical path is correct...)... it's about a week i'm working on it; i get big squeals and a very strong background noise...
is your layout pretty silent ?
i do everything on veroboard, and i had great expectations from my layout.. but... seems like i should learn to design them better..
have you also some samples ???
thanks, congratulations once again
demym
Postby indyguitarist » 08 Apr 2011, 18:36
demym wrote:very good Hewie !
there's a ton of gain there... layout is going to be a BIG thing with noise on the TW circuit.
indyguitarist
Have thanks: 161 times
Postby demym » 08 Apr 2011, 20:44
What a honour, Brian in person ! Do you mean Brian that even you are messing out with noises and squeals ? Incredibile :-)
I've bought your books, found them very useful for a novice !
Admiration, thanks, all the best
demym
Postby indyguitarist » 08 Apr 2011, 22:28
demym wrote:What a honour, Brian in person ! Do you mean Brian that even you are messing out with noises and squeals ? Incredibile :-)
Its just gainy circuits in general... layouts can make a difference. We are pretty picky about how we lay things out! There are definite no-no's to adhere to.
indyguitarist
Postby hewie » 09 Apr 2011, 18:52
demym wrote:I also did a veroboard layout, but something went wrong (although the electrical path is correct...)... it's about a week i'm working on it; i get big squeals and a very strong background noise...
No squeals with my layout/build. The layout is pretty quiet, but what veroboard high-gain circuit doesn't have a little noise introduced? Regardless, up until ~2/3 of the gain pot's rotation the effect is quite silent, then the noise starts coming in. The amount of noise is no different from say a Boss DS-1 with full gain. Keep in mind, the Triple Wreck has a LOT of gain available, I don't think I'd ever think of using it past 2/3 as it is. Half way seems to the be the sweet spot for me. With that said, I could definitely dime the gain, crank my amp, and not kill an audience/myself with horrendous noise.
hewie
Postby demym » 09 Apr 2011, 21:40
Good news Hewie, thanks..
Oh, and i just built another one using your vero layout.. didn't play with it yet, need some other pots..
Very clean layout.
Thanks once again, have a nice time
demym
Postby lutor » 16 Apr 2011, 09:50
Hi hewie,
in your layout there is one problem: the connection of R13 & C14 is not corrected, it, so take a signal from pin 1 of IC3, in the schematic they are connect to pin 2 of IC3.
:wink:
For this message the author lutor has received thanks: 2
Desdog (20 Mar 2015, 18:41), hewie (16 Apr 2011, 13:46)
lutor
Have thanks: 19 times
Postby hewie » 16 Apr 2011, 13:58
lutor wrote:Hi hewie,
:wink:
You are correct! Many thanks for noticing that one. To be honest, I'm not sure what effect that mistake would have on the operation of the pedal, but I plan to find out sometime this weekend :horsey:
If someone has used the previous layout, I suggest removing R13 from the board, and soldering it across the back of the board between J8 and L12 to fix this.
Here's the revised layout, with correction thanks to lutor :thumbsup
For this message the author hewie has received thanks: 6
bonsaxen (19 May 2011, 10:39), Desdog (20 Mar 2015, 18:41), grrrunge (15 Oct 2011, 05:18), joe_pineapple (23 Oct 2011, 01:48), lasermonkey (30 Jun 2011, 20:32), TubeHugger (15 Nov 2013, 00:09)
hewie
Postby lutor » 16 Apr 2011, 14:14
I have ended in this moment to construct my T.W. I have used yours layout, and had already made the correction on R13/C14.I did not have in home the JRC4580 and have used NE5532.I had not never felt a high-gain box thus wonderful and without noise.
Thanks! :applause:
lutor
Postby hewie » 16 Apr 2011, 14:48
lutor wrote:I have ended in this moment to construct my T.W. I have used yours layout, and had already made the correction on R13/C14.I did not have in home the JRC4580 and have used NE5532.I had not never felt a high-gain box thus wonderful and without noise.
Thanks! :applause:
It is a surprisingly nice high-gain effect, definitely one of my favourites.
hewie
Postby demym » 16 Apr 2011, 17:49
What effect does have this modification ? I did it with the previous Hewie layout and sounds fine....
thanx have a nice time
demym
Postby MullisMan » 19 Apr 2011, 13:53
Anybody interested in my eagle files for this? My own layout, but same schematic as above with a different power scheme. It's not verified yet but I have it all soldered, just waiting for some parts and an enclosure.
I want to build it all.
MullisMan
Has thanked: 13 times
Have thanks: 53 times
Postby hewie » 19 Apr 2011, 14:09
demym wrote:What effect does have this modification ? I did it with the previous Hewie layout and sounds fine....
I ended up doing the correction on my own build, if there is a difference sonically, it's subtle. Regardless, an error is an error :wink:
hewie
Users browsing this forum: fentemple, rockgod666, theehman, Visualdistortion, Zoom and 6 guests
