Wampler Pedals - Triple Wreck  [traced]
Re: Wampler -Triple Wreck-
Postby demym » 19 Apr 2011, 14:17
fine thanks... on the first copy i will not make the correction, it sounds fine as it is... on the second one i'm doing i'll obviously follow the correct layout..
thanks
demym
Postby caspercody » 19 Apr 2011, 17:24
Mullisman,
I am interested in your Eagle files for the layout.
Rob
caspercody
Has thanked: 30 times
Have thanks: 43 times
Postby MullisMan » 19 Apr 2011, 21:21
I'll PM you caspercody. :)
I want to build it all.
MullisMan
Has thanked: 13 times
Have thanks: 53 times
Postby albru80 » 20 Apr 2011, 01:18
Hi Mullisman,
Would it be possible to have a copy of your Eagle layout?
Thanks a lot
Alex
albru80
Have thanks: 49 times
Postby MullisMan » 20 Apr 2011, 11:17
Here are my eagle .brd and .sch files. There's also a partslist for ordering. This hasn't been verified yet but it should work no problem. I don't know about squealing from the high gain circuit, and some things can get kinda tight in the layout.
For this message the author MullisMan has received thanks: 8
audioguy (20 Apr 2011, 13:35), Desdog (20 Mar 2015, 18:41), dorrisant (24 Mar 2013, 18:45), ezugaru (16 Mar 2012, 18:38), minnow (20 Apr 2011, 12:41), modman (23 Jun 2015, 12:57), rocklander (12 Sep 2011, 22:14), ronald_h_m (25 Apr 2011, 04:05)
MullisMan
Postby emman_t » 24 Apr 2011, 00:26
:hmmm:
emman_t
Postby audioguy » 25 Apr 2011, 00:48
Is the smaller Cream board the boost circuit?
audioguy
Has thanked: 24 times
Have thanks: 6 times
Postby jstbrowsin » 25 Apr 2011, 01:40
Just so everyone knows I wasn't commenting on the triple-wreck my comment was on the spam that was posted before my post and has since been deleted. Maybe one of the mods could delete my post please? Save some confusion :)
jstbrowsin
Has thanked: 71 times
Have thanks: 4 times
Postby MullisMan » 25 Apr 2011, 03:00
Yes, the smaller board is for the boost section, and I used a Va pad to provide power from the larger board's power section.
MullisMan
Postby MullisMan » 25 Apr 2011, 03:11
emman_t wrote::hmmm:
Looks good emman_t, did you use my layout and modify it a little bit? That looks a little smaller than my board.
MullisMan
Postby emman_t » 25 Apr 2011, 11:58
That's funny dude. No, I didn't use your layout, of course. :lol: :lol: . Does it looked like "modified a little bit" to you? :lol: :lol:
emman_t
Postby emman_t » 26 Apr 2011, 13:02
ronald_h_m wrote:
emman_t wrote:here's my complete build... :)
Can you post some soundclips/youtube vid please. TIA :D
What else can I say?..it's a triple wreck. Seriously, I don't have the proper/high quality recording equipments :D :D :D
emman_t
Postby audioguy » 26 Apr 2011, 15:42
emman_t wrote:What else can I say?..it's a triple wreck. Seriously, I don't have the proper/high quality recording equipments :D :D :D
Any chance you can share your verified layout?
audioguy
Postby emman_t » 27 Apr 2011, 07:17
audioguy wrote:Any chance you can share your verified layout?
..not for you, dude.. :lol:
emman_t
Postby batteryacidtea » 27 Apr 2011, 07:37
WTF! "That's the spirit" :slap: :slap:
batteryacidtea
Has thanked: 57 times
Have thanks: 15 times
Postby MullisMan » 27 Apr 2011, 12:59
Audioguy I should be boxing mine up soon once I get the remaining parts in the mail, I can let you know when I've verified it.
audioguy (27 Apr 2011, 21:31)
MullisMan
Postby audioguy » 27 Apr 2011, 21:31
Awesome, thanks!
audioguy
Postby andreaps72 » 04 May 2011, 21:04
Eisy wrote:EDIT 2: in boost mode C5 is 220NF || 1UF = 1.22UF...
What means ? the boost switch add a 1UF condenser?
I made one but :
-in the "cream" circuit if I don't use a lower resistor insted of 47K in the transistor the circuit don't work.
-the mid control have subtle effect, I realy don't understand how it works.
Any other have the same problems?
andreaps72
Have thanks: 2 times
Postby Eisy » 05 May 2011, 07:33
I made one but :
Yes, the boost adds 1UF (connected in parallel to 220NF).
My cream circuit works very well.
Eisy
Have thanks: 69 times
Postby andreaps72 » 05 May 2011, 09:11
So I need a 4 deviator switch or a mil. bypass to light up the boost led.
With the 47K resistor on the collector of the 5089 I have only 0,4V and obviusly don't work, with a 22K I have the standard 4,5V with a 9V fresh battery and works well.
But the problem remains in the middle control, checked several times but don't work like in the videos of the original.
andreaps72
Users browsing this forum: fentemple, rockgod666, Seiche, theehman, Visualdistortion and 6 guests
