Earthquaker Devices - Monarch revision 2 - 2011 [gut shot]
Re: earthquaker devices monarch [gut shot]
Postby Didi&Stulle » 13 Apr 2014, 09:43
seems like Earhquaker changed to multilayered pcbs lately :?
I found a lot of seemingly non-collected pads (I marked these blue), which seem to be connected on a non-visible layer, so I guess it wont make sense to put more effort into tracing my friend's board, right?
any ideas are welcome.
For this message the author Didi&Stulle has received thanks:
Nocentelli (13 Apr 2014, 10:18)
Didi&Stulle
Have thanks: 11 times
Postby marshmellow » 13 Apr 2014, 10:56
To me it looks like they are all connected to the top layer which is probably ground.
marshmellow
Have thanks: 123 times
Postby Intripped » 13 Apr 2014, 15:09
not all of them:
there are some other traces on the top-layer of the PCB - i can see two running under the upper row of components
and the upper-left diode is not connected to the top layer... maybe it's really a 3 layers board
...what about taking some other pics from different angles, and one of the other side too? :)
Intripped
Has thanked: 600 times
Have thanks: 216 times
Postby pietro_moog » 13 Apr 2014, 15:26
even if it's a 3 layers board, i don't think it's gonna be too hard now. the first stage (a mosfet, cool idea) is basically traced, the eq part is pretty much understandable and for the rest of the circuit we almost have it. a rough schematic can help to visualize everything.
pietro_moog
Have thanks: 44 times
Postby pietro_moog » 13 Apr 2014, 16:01
so, basically, this is a mosfet input stage, eq, a jfet mu-amp and then a jfet buffer with 2 resistors and caps to cut the high end. cool.
what is that wire on the side of B-? i have some doubts on the part between the volume pot and the mu amp but the rest is pretty much figured out.
btw, i don't think this is a 3 layers board at all. the traces that we miss are on the top layer and under the components. the vastly majority of the top layer is ground.
pietro_moog
Postby Didi&Stulle » 13 Apr 2014, 16:23
you are right: the wire "B-" goes to the dc jack battery connection ... right next to the "B-" is a ground pad (G) that goes to the input jack.
Didi&Stulle
Postby johnk » 13 Apr 2014, 16:26
pietro_moog wrote:so, basically, this is a mosfet input stage, eq, a jfet mu-amp and then a jfet buffer with 2 resistors and caps to cut the high end. cool.
I agree that it's most likely a 2 layer board. got any shots of the bottom of it?
johnk
Has thanked: 32 times
Have thanks: 272 times
Postby pietro_moog » 13 Apr 2014, 16:46
this is a first schematic. maybe someone can work it in a software.
myself, i'm not sure of a few values, like the ones on the bs170, but the schematic should be this.
For this message the author pietro_moog has received thanks: 2
Didi&Stulle (13 Apr 2014, 17:14), LucifersTrip (16 May 2014, 06:21)
pietro_moog
Postby pietro_moog » 13 Apr 2014, 18:15
i have some doubts on the 12k resistor before the eq, it looks like a strange value. can you measure it with a DMM?
and the 1k / 10k resistor from the bs170 leg is probably a 330Ω
pietro_moog
Postby Intripped » 13 Apr 2014, 20:10
this is my RE:
something to verify
please read the notes within the images
For this message the author Intripped has received thanks:
Didi&Stulle (13 Apr 2014, 20:15)
Intripped
Postby Intripped » 15 Apr 2014, 09:57
... Didi&Stulle?
Intripped
Postby Nocentelli » 15 Apr 2014, 10:08
as yet unverified, sounds good on the breadboard:
For this message the author Nocentelli has received thanks: 3
dbat69 (15 Apr 2014, 13:23), jubal81 (15 Apr 2014, 15:56), pietro_moog (15 Apr 2014, 14:26)
Nocentelli
Has thanked: 881 times
Have thanks: 848 times
Postby johnk » 15 Apr 2014, 17:58
does you breadboard version sound like the original?
I also drew up a vero for it.
johnk
Postby Nocentelli » 15 Apr 2014, 18:26
No, and i'd advise holding fire until the schem has been looked at a bit more closely. Last night through headphones it sounded great, but after a longer play through a few amps at volume it doesn't seem right (to my ears). I've only got linear pots, but even taking that into account i have to crank the bass and roll the treble almost off or it is way too thin and harsh. I'll check over my breadboard layout carefully, but i wouldn't build the vero i posted as is.
johnk (15 Apr 2014, 19:26)
Nocentelli
Postby pietro_moog » 15 Apr 2014, 19:33
well, the schematic structure seems pretty reasonable now. the values too. log pots on the eq are pretty much important, you can see by yourself on the duncan simulator. btw, on the bass pot, 2.2nf and 22nd should be switched, 2.2 is between lug 3 and 2. that's a big reason because it doesn't sound right. and the 470pf treble bleeding cap on the gain is more harmful than useless. i cut those even in amps. the last 2 caps, 220pf and 100pf they could be chosen by preference. even the eq could be modeled after personal taste.
anyhow, this pedal looks cool, but it's just a mosfet boost cascading in a fet mu amp with an orange eq in between.
Nocentelli (15 Apr 2014, 20:53)
pietro_moog
Postby johnk » 15 Apr 2014, 19:38
thanks!
looking at the gut shots, it appears that on your layout, the two 100K resistors on the lugs 2&3 of the bass pot should be 10K's. maybe that would give it more low end.
For this message the author johnk has received thanks:
Nocentelli (15 Apr 2014, 20:54)
johnk
Postby deafbutpicky » 15 Apr 2014, 20:10
pietro_moog wrote:anyhow, this pedal looks cool, but it's just a mosfet boost cascading in a fet mu amp with an orange eq in between.
...there's still a chance to do it with three diodes and an opamp :P
I'm using capacitors to replace my guitar effects and give more clarity to the sound.
deafbutpicky
Has thanked: 27 times
Have thanks: 20 times
Postby Intripped » 15 Apr 2014, 20:30
looking at this pic of another previous version there's a 100E resistor near Q3 and Q4 (on the right in the image)
so probably this is the source resistor of the mu-amp (R17 referring to my schematic)
Intripped
Postby johnk » 15 Apr 2014, 20:50
yep. that looks like a 100 ohm to me too.
I wish the op would've taken some pics on different angles of his REV2 so we could see some of the resistor and cap value markings better.
johnk
Postby johnk » 16 Apr 2014, 02:45
I built up my vero of it and it sounds great. the only thing is, is that it seems to have less gain than the video demos that I've seen. otherwise it's awesome.
if I can find a way to up the drive/dirt, it'll be perfect.
johnk
Users browsing this forum: No registered users and 16 guests
