Earthquaker Devices - Monarch revision 2 - 2011 [gut shot]
Re: earthquaker devices monarch [gut shot]
Postby storyboardist » 16 Feb 2015, 22:29
Sorry to resurrect a old thread, but I made a PCB/perf layout with on board pots if anyone is interested.
For this message the author storyboardist has received thanks: 3
onebuzz (29 May 2015, 23:04), selfdestroyer (18 Feb 2015, 06:29), Wiseblood (30 May 2015, 16:03)
storyboardist
Has thanked: 71 times
Have thanks: 193 times
Postby storyboardist » 29 May 2015, 15:11
My layout from the post above is now verified.
Sounds really good. Almost transparent at lower gain settings when pushing a clean amp.
EBRAddict (29 May 2015, 19:43)
storyboardist
Re: Earthquaker Devices - Monarch revision 2 - 2011 [gut sho
Postby Gila_Crisis » 10 Jun 2019, 16:18
I?ve built this using this layout:
http://tagboardeffects.blogspot.com/201 ... drive.html
sounds good, but when I crank the Treble to max, it acts like as if the circuit is overloading: from overdrive it becomes a fuzzy broken radio sound, which then fades. But as soon as I turn down treble and gain then it works again properly.
Do anybody else experienced this issue?
Gila_Crisis
Have thanks: 72 times
Postby Gila_Crisis » 11 Jun 2019, 19:02
I'v solved the problem by putting a 150k resistor between lug3 of the Treble pot and the 1nF cap.
Now with all the pots cranked it won't "collapse".
Gila_Crisis
Previous
Users browsing this forum: [Gringo], Google [Bot], hippo, pz and 12 guests
