Xotic - BB Preamp  [traced]
Re: Xotic - BB Preamp
Postby ballfire » 21 Feb 2014, 04:26
hello everybody..
i build this pedal but there is a problem there is a craclikg crickling noise from the output but the output of the pedal .. the knobs is functioning well ic and transistors are okey..but there is a crackling in the background of the the effect when it bypass.. :(
any suggestions or advice?
ballfire
Has thanked: 28 times
Postby andregarcia57 » 09 Mar 2015, 06:20
OSHPark Xotic - BB Preamp (basead Madbeans)
https://oshpark.com/shared_projects/guCDvUnz
andregarcia57
Have thanks: 87 times
Postby Frabbio » 01 Oct 2017, 15:19
Here is my single sided layout for the BB Preamp, it's verified.
This version includes all the latest modifications to the schematic (stereo volume control, 4 clipping diodes), and was designed to fit board mounted pot, including the stereo pot for volume control.
Board dimensions are 5.5cmx5.5cm, should fit in a hammond b enclosure.
For this message the author Frabbio has received thanks: 5
287m (21 Oct 2017, 06:31), Intripped (21 Oct 2017, 04:01), Manfred (01 Oct 2017, 20:06), rafikian (14 Oct 2017, 10:16), txomin (07 Oct 2017, 09:19)
Frabbio
Has thanked: 10 times
Have thanks: 76 times
Postby rafikian » 20 Oct 2017, 21:53
special thanks to Frabbio for the great artwork :applause:
worked perfectly and sound amazing, this one is smoother than the first version, the gain is more linear, and the bass response is awesome !
here's some guts :D
For this message the author rafikian has received thanks: 2
287m (21 Oct 2017, 06:31), Frabbio (21 Oct 2017, 12:19)
rafikian
Have thanks: 8 times
Postby Intripped » 21 Oct 2017, 09:32
Freppo,
In your schematic the first half of the dual gang pot (the half acting as a filter) is connected in a strange way:
Is it a mistake or made on purpose?
In this way you have changed the frequencies of the filter to 15.8/40Hz (in all other schematics the frequencies are 40/160Hz)
And by the way: at the bottom end of the previous page of this topic, Frabbio (...are you two relatives?) said that the filter should work in the opposite way, making the filter add bass freqs while you turn the pot cw.
...I still haven't understood if he is right or not.
Cristiano
Intripped
Has thanked: 588 times
Have thanks: 215 times
Postby Frabbio » 21 Oct 2017, 12:25
Hi Intripped, i think you messed up with the names, there is no Freppo!
I tried both arrangements and i liked it better this way.
However if you want to try it by yourself give me your email in pvt and i'll send you the eagle files.
Frabbio
Postby Intripped » 21 Oct 2017, 13:49
Haha! :slap:
I definitely messed up with the names, sorry for that!
Thanks for your offer Frabbio, but I don't need the eagle files.
I have already built a clone, and I can easily modify it, since the pots are not board mounted.
I was just curious about this variant that you've made.
However: Do you know how this pot is wired in the original pedal? Is it as you said in your post in the previous page?
Intripped
Postby Frabbio » 21 Oct 2017, 16:04
I can't say for sure because i have never opened a real BB preamp, but with this configuration it sounds pretty good and really similar to the samples, give it a try ;)
The biggest difference however are the 4 clipping diodes.
Frabbio
Postby Intripped » 21 Oct 2017, 16:22
Ok, thanks!
I'll give it a try for sure
Intripped
Postby ballfire » 11 Nov 2017, 02:43
Frabbio wrote:Here is my single sided layout for the BB Preamp, it's verified.
hello sir..
is your bb clone suffer from noise and squelling noise at the volume when max??? i build the this bb preamp from madbean pedal and suffers much on noise and squelling im disappointed.. :( :( :(
is your clone behaving like this??
im confused which is the right one schematic that no noise or squelling..
thanks...
ballfire
Postby Frabbio » 12 Nov 2017, 15:02
Hi, this layout works perfectly, i have had no problem whatsoever.
Frabbio
Postby arivabox » 22 Nov 2017, 02:58
can someone come in handy)
For this message the author arivabox has received thanks: 2
Dave37LP (05 Jan 2018, 22:48), Intripped (28 Nov 2017, 06:38)
arivabox
Have thanks: 3 times
Postby marshmellow » 22 Nov 2017, 15:38
Don't drink and autoroute, stay safe bro. :hug:
marshmellow
Have thanks: 122 times
Postby rafikian » 27 Nov 2017, 16:08
oooh :twisted: this is the original BB Layout with two boards and the BS250 etc.
but this one has got 22k resistor insteade of 47k between lug 1 and 3 of the dual gang pot !
:horsey: I will try this to see (hear) how it sounds :D
rafikian
Postby Dave37LP » 05 Jan 2018, 22:46
In case that someone has any doubt about the resistor in parallel with the pot... yes, it's 22K.
Gutshot:
Dave
For this message the author Dave37LP has received thanks: 2
Intripped (05 Jan 2018, 22:57), rafikian (08 Jan 2018, 13:42)
Dave37LP
Has thanked: 25 times
Postby rafikian » 08 Jan 2018, 13:54
Hi everyone
I have tried the 22k resistor in the dual gang volume pot version, and this has bring the overall output up to the same level as the madbean version (with normal volume pot),assuming that there's two versions on the market, I think that the guys from exotic wanted to make them @ the same output level . using 4 diode make the BB has less (but still enough) gain than with 2 diodes, IMO it's smoother.
Rafik.
rafikian
Postby ballfire » 05 Nov 2018, 06:42
hello diy muscians..
i built this bb preamp and box it already ..but when i laid it down on the floor there is a noise in the audio background i check all the parts for ground loose but nothing i can find, the noise is like a shhh..noise..then when i lift it up just i 1 feet on the ground the noise disappear..what is this??
anybody advice?? thanks
ballfire
Postby Frabbio » 06 Nov 2018, 21:00
Is the box connected to ground? If you are using isolated jacks try soldering a ground wire on the backside of one of the pots.
ballfire (10 Nov 2018, 08:15)
Frabbio
Postby ballfire » 08 Nov 2018, 05:22
Frabbio wrote:Is the box connected to ground? If you are using isolated jacks try soldering a ground wire on the backside of one of the pots.
good day diy musicians
thanks for reply Mr. Frabbio
i already grounded the back of one of the pot to the jacks but still the hissing
still there..
theres also a another problem my bb preamp has a low gain when i max the gain pot..
i just have only 1MB pot and it has a low resistance can i have a substitiute for
1MB pot for gain knob what other potentiometer value can i used for gain knob??
any advice thanks..
ballfire
Previous
Users browsing this forum: ilshat, tube65 and 23 guests
