Xotic - BB Preamp  [traced]
Re: Xotic - BB Preamp
Postby BennyBoop » 18 Jun 2009, 14:42
How will it sound with a Burr Brown OPA2134PA? Anyoune tried it?
What other IC's have you tested?
BennyBoop
Postby mrkaploca » 26 Jun 2009, 16:52
what are original transistors and IC???
mrkaploca
Has thanked: 15 times
Have thanks: 12 times
Postby chicago_mike » 26 Jun 2009, 17:24
lm353 or lf353 or something like that. Not your everyday tl072
I'll be building these for bass and will use opa 2134's I think. I really like those.
The npn/pnp's though Im not sure whats used there.
Skyline FX 2013
chicago_mike
Has thanked: 23 times
Have thanks: 283 times
Re: BB Preamp, new layout!
Postby mrkaploca » 06 Jul 2009, 03:19
darkglass wrote:Hello, Im posting one layoout I designed with eagle for the BB Preamp, I used the schem traced by KHE founded in this forum...
So here it is!
Schem
http://darkfinn.googlepages.com/BBSchem.jpg
Layout
http://darkfinn.googlepages.com/Layout.jpg
And PCB
http://darkfinn.googlepages.com/BBPreampPCB.pdf
This layout is not verified though, I finished it yesterday, but Im quite sure it should work.
Best Regards
Douglas.
Enjoy
what about the output transistor here?+4,5V is not connected to base but to emmiter???
mrkaploca
Postby Silent Fly » 06 Jul 2009, 08:23
I am not convinced by the Q2 connections either... :hmmm:
Silent Fly
Has thanked: 20 times
Have thanks: 38 times
Postby mrkaploca » 10 Jul 2009, 00:28
So here it is!
Schem
Layout
And PCB
Best Regards
Douglas.
Enjoy
I tried this version,not working.I fixed output transistor pinouts(original are not correct,Va should go to base not emmiter,and emmiter to ground.)but still doesnt work.does anybody have working layout??
mrkaploca
Postby Silent Fly » 10 Jul 2009, 09:44
The bias of Q2 doesn't look right. As a test, I suggest you try pick up the signal from terminal 2 of the LEVEL potentiometer. If you hear a sound it's Q2. The connections of IC2A also look wrong.
I would recommend you have a look to this version.
Silent Fly
Postby mrkaploca » 10 Jul 2009, 16:35
Silent Fly wrote:The bias of Q2 doesn't look right. As a test, I suggest you try pick up the signal from terminal 2 of the LEVEL potentiometer. If you hear a sound it's Q2. The connections of IC2A also look wrong.
yes but I am realy bad in layout designing so I ask if somebody has working layout.I have a gig in france for 6 days and I realy need to finihs it till then!!!!!!!!HELP
mrkaploca
Postby zxbreak » 15 Jul 2009, 14:28
Hi!
Help me with a small questions.
BB PLUS preamp has a B>A and A>B channel selector. But how? :shock: Relays? DPDTs? or?
In the Zvex Box of Rock have been realized as A(on\off)>B(on\off) chanel only.
zxbreak
Postby mrkaploca » 24 Jul 2009, 15:51
Da Cat wrote:Thanks kusi, you the man :D
and the corected version:
OK,I ve built this version,engaged it and all I got is a HUM.Every pot is responding,difference can be heard when I turn gain pot,bass,treble,and the volume increases,but ll that is comming out is a hum sound no metter what you play(no distortion,no nothing).What could be the problem??
Thnx!!
mrkaploca
Postby madbean » 24 Jul 2009, 17:21
Re-flow your solder. You might have a solder bridge somewhere.
madbean
Postby mrkaploca » 27 Jul 2009, 16:26
madbean wrote:Re-flow your solder. You might have a solder bridge somewhere.
No,that's not the case,I rechecked all the paths.What else causes only hum sound.Transistors must be ok soldered or else there wouldn't be any sound at all??IC's????Someone help!!
mrkaploca
Postby modman » 28 Jul 2009, 02:35
You used a layout that somebody said was/you hope is verified. In that case and in fact always, you should check your build against a correct schematic or use the Audio Probe to trace your guitar signal.
Has thanked: 3113 times
Have thanks: 563 times
Postby TheLemon » 28 Jul 2009, 07:32
Thnx!!
You might have a grounding issue, maybe a connection missed
TheLemon
Have thanks: 21 times
Postby Da Cat » 28 Jul 2009, 12:21
Hmm, my bb is working fine with this layout i made....
Hum sounds like a ground problem. Check the power filtering diode going to ground - orientation!
Check the schematics kusi posted - i made layout after that one.
And also check the transistors - try 2n5088 or 2n3904.
Da Cat
Postby mrkaploca » 29 Jul 2009, 16:04
Da Cat wrote:Hmm, my bb is working fine with this layout i made....
I changed 2sc1815 transistors to 2n5088 and I finally made it work.Everything works fine except when I increase the gain potentiometer-then there is alot of background noise(hum)present :hmmm: .It can not be heard when I play but when I stop a noise appears.On a very low gain values it's ok.I put 1M log pot instead of linear one and I put 20k resistor(on the second gain stage of the first IC)instead of 19k.Can that cause the problem?
Sorry guys I torture u but I wanna make it right ,I really like the sound of bb preamp!!!
thnx!!!!
mrkaploca
Postby mrkaploca » 31 Jul 2009, 10:20
anybody with good advice??
mrkaploca
Postby mrkaploca » 04 Aug 2009, 17:13
thnx!!!!
So guys what could be the fault??increasing the gain pot a background noise (hum)appears!!!! :slap: :slap: :slap:
mrkaploca
Postby ODwan » 05 Aug 2009, 16:39
Hi!
Could be bad filtering of the power supply --> try with battery.
Could be hum pickup from external source like mains wire, transformers, lighting..... either through guitar pu's or circuitry.
Is the circuit shielded/in a box?
Hope this helps some!
Timo
ODwan
Postby diggum12 » 28 Aug 2009, 18:59
Has anyone tried this without the buffers? I may try it this weekend if I get time.
"Now we cheer if someone get's a tweed champ working. I feel like the future was here and we traded it away for trinkets." -diagrammatiks
ayayay! on the other site
diggum12
Users browsing this forum: BomBon, Jack Deville, ryou, zobi and 7 guests
