Wampler - Plexi-Drive  [traced]
Re: Wampler - Plexi-Drive
Postby Mbas974 » 07 Oct 2014, 20:17
It worked !
500K is too big value in my taste... I replaced the tone pot with one having 100K and it sound really good now.
For this message the author Mbas974 has received thanks:
modman (24 Aug 2015, 12:37)
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Re: Wampler - Plexi-Drive jfet biasing
Postby jimiguitar » 14 Dec 2014, 07:55
i had no trouble sorting jfets out of 90 i got 23 that that measure between 4.5. and 5.0and 17 that measure 4.11 and 4.5 in the plexidrive mostly also out of the 90 got 7 that bias in the pinnacle out of the same 90 plus more that i'am sure i will find more to fit in other pedals i measured each one and recorded it using plexidrive as reference logging what D S G resistors so i could kinda base by the circuits D S G resistors if my drain voltage will go up or down on the ones i got logged
jimiguitar
Postby Ripdivot » 14 Dec 2014, 17:55
I wish I had your batch of jfets. I got 3 out of 50 when I built mine.
Ripdivot
Have thanks: 59 times
Postby jimiguitar » 14 Dec 2014, 18:53
i got them from small bear
jimiguitar
Postby storyboardist » 16 Dec 2014, 16:40
For this message the author storyboardist has received thanks: 3
jwpartain1 (16 Dec 2014, 17:13), rcustoms (17 Dec 2014, 14:02), selfdestroyer (17 Dec 2014, 08:52)
storyboardist
Has thanked: 59 times
Have thanks: 147 times
Postby jt » 26 Aug 2016, 08:14
Tone pot in the schematic is wrong.It should be 25k linear.
In some gut shots you can see the letter B at the silkscreening.
jt
Has thanked: 13 times
Postby zedsnotdead » 13 Sep 2017, 20:27
Sorry for the necro guys, but I think I have some pertinent info on this circuit.
I love Brian's work and tried to replicate this pedal using a PCB from a well known UK seller and populating it with components according to the schematic that was posted here. It happens that it doesn't quite match the same tone I get from the original Plexidrive (I bought one). The "replica" was more mid-rangy and somewhat muffled, it didn't have the same clarity as the original.
Mind that I used J201's SMD - hoping to avoid counterfeit fets - and I biased the drain voltage of those 3 like the original.
So I was wondering what could cause such difference...
Opened the original and started to check the components.
So in short:
jt wrote:Tone pot in the schematic is wrong.It should be 25k linear.
This is true. It is B25K pot.
It also has a input resistor (1K) and cap (100n). The differences are in red. Check:
After I done the caps replacement, it sounded identical. Not "nearly". I really mean 99.9% identical.
Now, what bugs me is that "bass" switch caps. It doesn't have almost any impact on the sound, it's 1n or 2n. It is very, very subtle if you compared with the 2n2/470p sound - which has a really noticeable difference in bass response. I wonder if this was done on purpose, or it was just a builder momentary distraction.... maybe indyguitarist could chime in?
For this message the author zedsnotdead has received thanks: 7
brejna (21 Nov 2017, 19:30), Danch (03 Oct 2017, 12:30), dv8r601 (14 Sep 2017, 23:19), jt (14 Sep 2017, 07:11), Manfred (13 Sep 2017, 22:23), microbailey (14 Dec 2017, 23:30), snoof (18 Jan 2018, 01:39)
zedsnotdead
Has thanked: 32 times
Have thanks: 53 times
Previous
Users browsing this forum: ckilgore, dirty dog, Dr.Detroit, lapsteelman, Motter, t0thedrums and 5 guests
