Wampler - Plexi-Drive  [traced]
Re: Wampler - Plexi-Drive
Postby azrael » 12 Jan 2012, 20:16
Did you use eagle to make that layout? if so, can you upload your .brd and .sch files?
azrael
Has thanked: 33 times
Have thanks: 91 times
Postby lukatosh » 12 Jan 2012, 22:20
i'm afraid that i delete them :(
but the layout, PCB and part list are on page 3 :)
lukatosh
Has thanked: 30 times
Have thanks: 177 times
Postby azrael » 13 Jan 2012, 03:49
why would you delete them? meh, waddling through your layout is tedious haha
azrael
Postby lukatosh » 13 Jan 2012, 05:13
i had to reinstall windows on my laptop
I only save that rar file...i thought that everything was inside of it... but no :(
lukatosh
Postby azrael » 13 Jan 2012, 08:35
Well, I waded through your schematic, seems to check out.
Check for shorts anywhere. It should not be behaving as you report.
azrael
Postby box » 13 Jan 2012, 15:03
nice link regarding above:
http://www.4shared.com/office/xypcM8j6/ ... Chris.html
Regards,
box
box
Have thanks: 34 times
Postby mganzer » 13 Jan 2012, 17:49
This layout was produced by the brazilian Chris on handmades.com.br
Original Thread:
http://www.handmades.com.br/forum/index.php?topic=3135.0
mganzer
Has thanked: 34 times
Have thanks: 27 times
Postby tjk3052 » 17 Jan 2012, 03:31
I just finished building this using the layout on page 2. I added an input cap and a pull down resistor as discussed on page 3. I picked through 10 jfets and got 3 that bias at 5.3-5.6V, which I guess is a little high, but I kept it as is because it sounds good. Not as much gain as I thought it would be, but it sounds good without any tweaks.
http://i881.photobucket.com/albums/ac15/tjk3052/PlexiDriveGuts.jpg
http://i881.photobucket.com/albums/ac15/tjk3052/PlexiDrive.jpg
tjk3052
Postby HHR18 » 06 Apr 2012, 20:30
I want to sort some J201s on voltage without having to open up my Plexi-Drive again (it was a tight fit with the veroboard). Is there any way to create a separate voltage test circuit for j201s? I can't be that hard but I'm a noob so I can't, for the life of me, figure out how. Thanks!
HHR18
Has thanked: 18 times
Have thanks: 3 times
Postby BAARON » 07 Apr 2012, 15:01
If you want to see how they're going to behave (voltage-wise) in the Plexi-drive circuit, just build a little circuit mimicing one of the gain stages (since they're all biased the same). Put a transistor socket on your board with a 1k resistor from source to ground, a 1M resistor from gate to ground, and a 15k resistor from drain to your 9v power source. Voila. Measure your voltages - no mathematical calculations needed to see how they're going to perform in a Plexi-drive configuration.
For this message the author BAARON has received thanks: 2
HHR18 (07 Apr 2012, 20:15), Karissimo (17 May 2012, 15:09)
BAARON
Have thanks: 18 times
Postby HHR18 » 07 Apr 2012, 19:45
BAARON wrote:If you want to see how they're going to behave (voltage-wise) in the Plexi-drive circuit, just build a little circuit mimicing one of the gain stages (since they're all biased the same). Put a transistor socket on your board with a 1k resistor from source to ground, a 1M resistor from gate to ground, and a 15k resistor from drain to your 9v power source. Voila. Measure your voltages - no mathematical calculations needed to see how they're going to perform in a Plexi-drive configuration.
Thanks for the confirmation, I build exactly that circuit just before your reply and was able to measure the voltages :) These J201s are all over the place, out of 10 only 2 or 3 where within the 4.5 - 5.0V range. Gonna try it with these new ones, the old ones had voltages of 5.8 and higher!
HHR18
Postby HHR18 » 13 May 2012, 15:09
The two new amp simulations by Wampler (Black '65 and Tweed '57) feature 3 band EQ. What would need to be added or changed to get this on this pedal?
HHR18
Postby geiristudio » 14 May 2012, 01:14
I built a box with two Plexi-Drives using the layout Mark made (http://www.tagboardeffects.com). I already built a single one but I loved the tone so much that I gave that one to my friend and built a double one for myself. On the right side I keep it low-gain for "tube-like" saturation/crunch and the left side I have a bit more gain for some rhythm stuff. I also use Marks offboard wiring layout which eliminates popping on every pedal because the input is grounded through the switch.
Anyways, here's a photo of my build:
I put the two bass switches on the back.
Sorry for the large image. I just couldn't be bothered making it any smaller.
Cheers!
geiristudio
Have thanks: 21 times
Postby andregarcia57 » 17 Dec 2012, 21:17
indyguitarist-wampler-plexi-drive is the same pedal?
those are trimpots to set 4.5v in J201?
thanks
andregarcia57
Have thanks: 83 times
Postby dludo59 » 28 Feb 2013, 17:31
I recently stumbled on the Plexi Drive while searching for information about j201 pedals and designs. So I decided to breadboard this one :wink:
I really like the sound it gives but I have some doubts and questions about all the gain/biasing stuff. When I ordered parts for this build I didn't know JFETs and especially j201's had to be biased, so I only got a bag of 4 j201's... At first the sound was gatted because my drain voltages were sitting at approx. 2.6V for each transistor with 15k stock resistor (they all seemed to have the same characteristics - except for Q3...). So I had to set the drain voltages for Q1, Q2 and Q3 by modifying the stock 15k resistors with these values : 10k for Q1 and Q2, and 7.4k for Q3. This gives me approx. 4.8V as drain voltage for all transistors.
However, I have 2 questions that puzzle me :
- when the gain control is turned all the way down, I have no sound : is this the normal behaviour of the design ? I know the 1k resistor going to ground on the first gain stage should ensure a minimal gain, but just wondering...
- how much can the overall gain be affected by using lower values for drain resistors ? Is it correct to assume the gain for each transistor is roughly calculated by dividing the drain resistor by the source resistor value ?
When the gain is cranked all the way up the sound is overdriven but it seems a little anemic to me...
Thanks guys !
dludo59
Postby Gboutique » 17 Mar 2013, 19:36
dludo59 wrote:I recently stumbled on the Plexi Drive while searching for information about j201 pedals and designs. So I decided to breadboard this one :wink:
Thanks guys !
That is wrong.... Brian recommend set up all j201 (matched) to 4.5V - 5VDC max in drain voltage., do not change any resistor value.. You must sort a set of 3 J201 to accomplish it. This is important for to have a true clone PlexyDrive..
Gboutique
Postby dludo59 » 20 Mar 2013, 20:32
Gboutique wrote:That is wrong.... Brian recommend set up all j201 (matched) to 4.5V - 5VDC max in drain voltage., do not change any resistor value.. You must sort a set of 3 J201 to accomplish it. This is important for to have a true clone PlexyDrive..
Ok, guess I'll have to buy a bunch of j201 and pray to have the perfect trio then !
dludo59
Postby lukatosh » 21 Mar 2013, 14:57
hello!... I don't understand....
you need to:
1.- match 3 jfets at any vgs
2.- match 3 jfets at 4.5v?
i've got 3 matched but at 0.6v
lukatosh
Postby dludo59 » 21 Mar 2013, 15:32
lukatosh wrote:hello!... I don't understand....
you need to:
Hello,
You have to match 3 j201 at 4.5-5v (drain voltage). Your only luck is to buy several j201 and hope to stumble on a good trio. Unfortunately you have no way to predict the values you will get, so you have to buy large quantities. Check Ebay for that.
dludo59
Postby Nicht Bernd » 03 Jul 2013, 07:54
Why not puting a Trimmpoti for the 10R resistor?
Nicht Bernd
Has thanked: 97 times
Have thanks: 6 times
Users browsing this forum: matt239, まさお。 and 3 guests
