OKKO Dominator  [traced]
Postby Saruman » 26 Jan 2011, 10:58
YEAH...THE OKKO DOMINATOR
For this message the author Saruman has received thanks: 44
audioguy (26 Jan 2011, 19:49), bajaman (26 Jan 2011, 11:29), dellamorte (26 Jan 2011, 12:38), floris (29 Jun 2016, 07:32), IvIark (27 Jan 2011, 17:37), KB (07 Feb 2011, 13:19), Lawnchair (30 Jan 2011, 18:44), modman (28 Feb 2011, 18:31), pandadandan (28 Jan 2011, 09:22), ~arph (28 Jan 2011, 17:26) and 34 more users
Saruman
Have thanks: 124 times
Re: OKKO Dominator [schematic, layout]
Postby RnFR » 26 Jan 2011, 11:03
looks like someone just made Degoop Doctor. :thumbsup
Has thanked: 150 times
Have thanks: 174 times
Postby kusi » 26 Jan 2011, 11:05
nice, thank you!!
kusi
Have thanks: 44 times
Postby Güero 2.0 » 26 Jan 2011, 11:51
Thanks Saruman, the White
Güero 2.0
Have thanks: 25 times
Postby kusi » 26 Jan 2011, 12:00
are you shure about R4 / R5?
regards, kusi
kusi
Postby hewie » 26 Jan 2011, 15:17
Brilliant! Looking forward to getting this one built up in the near future.
hewie
Has thanked: 20 times
Have thanks: 45 times
Postby batteryacidtea » 26 Jan 2011, 19:31
Hell yeah! Now that's something to really care about and spend crazy time building and playing! :applause:
batteryacidtea
Has thanked: 57 times
Have thanks: 15 times
Postby DimebuGG » 27 Jan 2011, 17:11
From the layout, the two Vref's(V/2) are tied together?
DimebuGG
Have thanks: 182 times
Postby RnFR » 27 Jan 2011, 17:50
kusi wrote:are you shure about R4 / R5?
regards, kusi
I was wondering about the first stage, too. that does not look right.
Postby Saruman » 28 Jan 2011, 06:39
are you shure about R4 / R5? - yes
From the layout, the two Vref's(V/2) are tied together? - no
Saruman
Postby kusi » 28 Jan 2011, 09:04
please check R4 / R5 again, its impossible that a 10k/5k voltagedivider makes 4,7V from 10,8V...;)
kusi
Postby Saruman » 28 Jan 2011, 10:02
R4=R5=10K I do a stupid thing :lol:
Saruman
Postby bajaman » 28 Jan 2011, 10:52
Yes :thumbsup
I was running some potential jfets on my simulator and to get the voltages on your schematic, I had to change the value of R4 from 5k to 10k :wink:
Incidentally the correct jfet type is critical to the sound of this pedal - I could not get the correct measured voltages with J201 or 2SK117 :shock:
It would be great if you could determine what these fets are!
In the meantime my simulations with the 2SK30ATM were right on the button - the same voltages as on the schematic BUT it has DGS not DSG pinouts.
Most of the non linear amplification occurs in this input stage - the 10k loading resistor (R4), draws nearly 4 times the current of the fet when biased on and limits the gain of the first stage by nearly 50%. The distortion due to this badly biased and "slugged" input stage depends very much on the Jfet type and is assymetrical in nature for some types more so for the J201 than the 2SK30
No clipping diodes further down the track either :hmmm:
Incidentally almost any n channel jfet should work for Q2 - it is configured as a buffer stage between the input tone shaping Q1 and the rest of the circuit - the gate is biased at exactly half voltage or 10.8 / 2 = 5.4 volts dc - the source sits at 5.65v dc
floris (29 Jun 2016, 07:35)
Has thanked: 457 times
Have thanks: 1579 times
Postby Saruman » 28 Jan 2011, 11:25
All nominals on all the details (except resistors) erased :(
Q1 is the most interesting.
Saruman
Postby bajaman » 28 Jan 2011, 12:06
the rest of the circuit is very similar to the Marshall Bluesbreaker / KOT etc. fopllowed by another buffer (op amp this time) and then a 3 way active tone control with switch selected mid frequency centres.
Postby bajaman » 28 Jan 2011, 12:07
followed :wink:
where did the edit feature go :?: :?: :?: :?:
Postby Saruman » 28 Jan 2011, 12:11
R4 - 10K, C5 - 220n Q1, Q2 - BF245A :thumbsup
bajaman (28 Jan 2011, 12:33)
Saruman
Postby DimebuGG » 28 Jan 2011, 12:14
Saruman wrote:are you shure about R4 / R5? - yes
DimebuGG
Postby bajaman » 28 Jan 2011, 12:32
BF245A :thumbsup :applause: :applause: :applause: :applause:
Postby RnFR » 28 Jan 2011, 16:21
the first stage is still confusing me. this seems like a very odd way to bias a FET. it would obviously bias it close to 1/2 Vcc, but it also seems like you would be shunting a ton of signal to ground through that 10K resistor. I'm aware of what the 10k on the emitter is doing, and why there is gain reduction and distortion there, but why is the collector biased off of the divider like that?
Next
Users browsing this forum: FuzzMonkey, kmmoe, ratzl, Visualdistortion and 6 guests
