Suhr KOKO BOOST  [traced]
Suhr KOKO BOOST
Postby Luke650 » 03 Feb 2011, 05:58
Does anyone have better pics from the Suhr Koko Boost? He sounds awesome.
Greetings
For this message the author Luke650 has received thanks:
modman (13 Jul 2017, 23:12)
Luke650
Have thanks: 12 times
Re: Suhr KOKO BOOST
Postby alexradium » 07 Sep 2013, 10:36
jstbrowsin wrote:[smilie=bump.gif] anybody got anything that can be traced. I'm surprised no one has done this yet??
i don't think anybody will take apart a 300 bucks pedal to discover it was your average full range clean boost and midboost in series,apart from the switching system,its something you can put together combining existing known circuits.
For this message the author alexradium has received thanks:
jstbrowsin (08 Sep 2013, 03:06)
alexradium
Has thanked: 46 times
Have thanks: 39 times
Re: Suhr KOKO BOOST
Postby shocki » 01 Dec 2013, 11:29
If anybody wants to trace it i can make some pics and send it to you. Just drop me a PM.
shocki
Re: Suhr KOKO BOOST
Postby alexradium » 01 Dec 2013, 11:55
I highly doubt anyone can trace it without a tester and desoldering boards...
alexradium
Re: Suhr KOKO BOOST
Postby shocki » 01 Dec 2013, 12:46
Yeah. You are probably right about that. There are 2 boards over each other and the components are not easy to identify. Still I could post some hi resolution pictures if anybody is interested.
shocki
Re: Suhr KOKO BOOST
Postby alexradium » 01 Dec 2013, 13:14
you can PM pics to my email,i'll try to guess at least the architecture....
alexradium
Re: Suhr KOKO BOOST
Postby shocki » 01 Dec 2013, 13:39
Yeah cool. That would help already.
shocki
Re: Suhr KOKO BOOST
Postby shocki » 01 Dec 2013, 16:48
I tried really hard to remove the board from the enclosure but I could not take it apart. Somehow the pots and stuff are connected to the board in a way that it cannot be removed easily. I have a high resolution shot of the guts. But not from the other site of the board and the second board. So this probably won't help.
shocki
Re: Suhr KOKO BOOST
Postby rwwalker » 24 Dec 2013, 18:35
Guys,
There's not much magic here...it's just a mid-boost / clean-boost.
Anyone can design this - the key is the center frequency and Q.
If I might give you a clue - check out modern graphic EQ schematics for a solution to this pedal....
bobw
rwwalker
Re: Suhr KOKO BOOST
Postby rmroza » 01 May 2017, 16:21
Looks like this thread hasbeen sitting a while. Who would destroy a high dollar pedal??...well I guess that would be me...or someone like me!
Attached is the slideshow to all of the photos for the Koko Boost. It also includes the BOM (Bill of Materials). A couple components are questionable as I tested them on the board, then off, but my iron is taking a sh*t after 25 years and decided to go to 1000 deg andvaporized them!
I sent the information to the people at Guitar FX Layouts, but it's been a long while (year or two) andthey still haven't released anything for it, so posting it here and anywhere else I/we can get some traction to get the full schematic and board made to clone it. A LOT of people use the pedal, soitmust be good and to be able to clone it, a LOT of people willbe interested in it. I don't have the time right now, but at least all of the pics, BOM, and information is available if someone wants to tackle it and be a god is some folks' eyes!
Enjoy!
http://s934.photobucket.com/user/rroza/slideshow/Suhr%20Koko%20Boost
For this message the author rmroza has received thanks: 2
J0K3RX (04 May 2017, 09:25), kukaratxo (14 Nov 2017, 09:20)
rmroza
Re: Suhr KOKO BOOST
Postby rmroza » 01 May 2017, 16:29
Here are pics of the mainboard
rmroza
Re: Suhr KOKO BOOST
Postby rmroza » 01 May 2017, 16:34
Here are pics of the daughterboard
rmroza
Re: Suhr KOKO BOOST  [traced]
Postby rmroza » 01 May 2017, 16:35
Oh, looking thru my folder, I see this schematic, but haveno idea if it's correct or not.
zamguitar (01 May 2017, 19:59)
rmroza
Re: Suhr KOKO BOOST
Postby bmxguitarsbmx » 01 May 2017, 18:24
rmroza wrote:Oh, looking thru my folder, I see this schematic, but haveno idea if it's correct or not.
you should give credit to Joey for tracing this
bmxguitarsbmx
Has thanked: 189 times
Have thanks: 63 times
Re: Suhr KOKO BOOST
Postby rmroza » 02 May 2017, 03:26
Thanks for the heads up, so forgetful!
Special thanks to JOEY over at the SloClone forum for drawing up the schematic!
rmroza
Re: Suhr KOKO BOOST
Postby rmroza » 11 Jul 2017, 14:03
For this message the author rmroza has received thanks: 4
bmxguitarsbmx (11 Jul 2017, 20:20), dv8r601 (13 Jul 2017, 01:02), jstbrowsin (11 Jul 2017, 15:40), kukaratxo (14 Nov 2017, 09:09)
rmroza
Re: Suhr KOKO BOOST
Postby bajaman » 11 Jul 2017, 22:29
looks interesting - can be done without relay :wink:
essentially a variable gain stage followed by a mid boost and then buffered to the output.
the unknown capacitor values should not be to difficult to figure out.
J0K3RX (12 Jul 2017, 01:54)
Has thanked: 350 times
Have thanks: 878 times
Re: Suhr KOKO BOOST
Postby jalmonsalmon » 13 Jul 2017, 02:51
Awesome pictures! If I had a schematic I can make a PCB
I am gonna check out the pics closely to see if I can come up with something
jalmonsalmon
Has thanked: 66 times
Have thanks: 22 times
Re: Suhr KOKO BOOST
Postby kukaratxo » 14 Nov 2017, 11:21
Hi everyone! In this schematic, what is the meaning of "VREF" and "CON"? Sorry I'm a begginer.
Thanks in advance.
kukaratxo
Re: Suhr KOKO BOOST
Postby Manfred » 14 Nov 2017, 13:39
Thanks in advance.
The power supply and switching circuits are not show in this schematic above.
VREF means the half supply voltage, CON means the control voltage sent by the switching circuit.
Manfred
Has thanked: 790 times
Have thanks: 364 times
Next
Users browsing this forum: LeroyP, Ripdivot, Sept29 and 7 guests
