Page 1 of 2
Wampler - Ego Compressor - Gut Shots
Posted: 14 May 2011, 16:28
by MullisMan
Here are some gut shots, they're the first i've taken so let me know if I need to take more. I've started to trace it and it looks pretty similar to a Build Your Own Clone compressor.
Re: Wampler - Ego Compressor - Gut Shots
Posted: 14 May 2011, 19:27
by bubstance
But remember...
• NOT a clone or copy of any other product on the market
I guess he's being truthful. :roll:
Posted: 14 May 2011, 19:34
by mictester
bubstance wrote:But remember...
It looks like a Dynacomp with op-amp buffering.
Posted: 14 May 2011, 19:55
by plesur
The BYOC has the attack control, the wet/dry blend, tone control and an output buffer.
I suppose because you have to build it yourself it's not 'on the market' :hmmm:
Posted: 14 May 2011, 20:23
by reneshelle
The BYOC only has one IC. So it's not a 1:1 clone of clone of a clone that's for sure. But it looks Dynacomp/Ross based with more to it than that... I'm sure Mr. Wampler will tell you what it is based on if asked nicely. I've seen him do that several times before.
Posted: 14 May 2011, 20:31
by bubstance
I'm sure it's not an exact clone of any compressor, but I'm sure it's just a tweaked pre-existing one. I don't know, it just bothers me when manufacturers won't own up to their products being heavily based on other pedals, instead claiming that they're not clones of any other product. Yes it's true, but it's a bit misleading to the average non-electronically inclined consumer.
Posted: 14 May 2011, 20:44
by culturejam
bubstance wrote:I'm sure it's not an exact clone of any compressor,
And that probably qualifies it as not being a copy/clone of other existing compressors. There's not a whole lot of originality anywhere when it comes to stompbox compressors. It's either going to be based around an OTA (Ross, Dynacomp, etc), an op amp (Orange Squeezer), or some kind of optical element.
The differences really come in the add-on features. And it looks like this one has more going on that a Dynacomp.
Posted: 15 May 2011, 00:58
by jamiefbolton
lets give brian the benefit of the doubt since he's a stand up guy and a big contributor to the DIY community, until its proven that he's intentionally mislead folks. he's not like some builders who we know hype their builds as something more than they are.
Posted: 15 May 2011, 17:47
by MullisMan
jamiefbolton wrote:lets give brian the benefit of the doubt since he's a stand up guy and a big contributor to the DIY community, until its proven that he's intentionally mislead folks. he's not like some builders who we know hype their builds as something more than they are.
Definitely. I have a lot of respect for Brian and he comes up with some interesting designs, as well as contributing a lot to the DIY community like you said. In the Triple Wreck thread on this site he basically laid out the schematic for that pedal. I wasn't posting these pics to bring down his image, I genuinely want to figure this pedal out because it's the only compressor I like using.
I've tried desoldering the pots to get a better look at the traces but they won't come out even when using a solder sucker. Any suggestions?
Posted: 15 May 2011, 21:16
by culturejam
MullisMan wrote:I've tried desoldering the pots to get a better look at the traces but they won't come out even when using a solder sucker. Any suggestions?
Have to desolder both sides. That's the tricky part about 2-sided PCBs.
Posted: 15 May 2011, 22:23
by MullisMan
Ah, back to the lair. :horsey:
Posted: 16 May 2011, 17:07
by indyguitarist
It's your standard dynacomp/ross circuit with a clean blend via inverted opamp. fairly standard stuff.
Posted: 03 Dec 2011, 15:40
by seedseed
this one seems to sound better than your standard ross clones and so on and so on there is something unique there doing with this one to make it sound that good.
Posted: 04 Dec 2011, 01:18
by engineelite
Ya, I've owned both the byoc 5-knob comp and the current wampler comp. the wampler smokes the byoc in many ways IMO. The sound is more full frequency, there is much much more compression available and it might have been a touch quieter in the noise dept also. This wampler comp would be a nice build to add to my Rothwell Love squeeze clone and janglebox clone :)
Posted: 04 Dec 2011, 01:40
by Jack Deville
MullisMan wrote: I've tried desoldering the pots to get a better look at the traces but they won't come out even when using a solder sucker. Any suggestions?
Just bend em.
The legs can take a bit of abuse before they break. One word of caution, be sure to provide stress relief for the joints at the board. Some PCB's traces/pads can lift easily.
Posted: 07 Dec 2011, 02:23
by pedalgrinder
any chance of finding out what changes are in this one compared to a ross. If i could get my grubby hands on it i would trace it myself but i can't see enough from pictures. What are the differences it can't be an exact ross clone sounds to different and clean.
Posted: 19 Mar 2012, 09:55
by pedalgrinder
it may have the typical ross dynacomp topology but we definately need a good schematic of it. So if someone would like to build one they can after all thats what this is all about. it would be nice to see some track side pics so someone can have a go at a good trace. for a schematic. i bet if this thing could distort there would be a shit load more attention given to it. :roll:
Posted: 19 Mar 2012, 18:59
by bubstance
Seriously? What more do you fucking NEED?
indyguitarist wrote:It's your standard dynacomp/ross circuit with a clean blend via inverted opamp. fairly standard stuff.
Just look at the values in the photos and see where they fit into the standard topology. If you need to, pretend the clean blend isn't there; that should help. Barring that, just fucking BUY one and trace it. You'll get the compressor you so desperately want and you can post a schematic.
Posted: 20 Mar 2012, 11:12
by pedalgrinder
it always amazing me the shit you have to dribble bubstance you seriously can't help yourself. You go buy it if you have so much money and trace the thing geez your a joke!
Posted: 20 Mar 2012, 11:19
by pedalgrinder
so yeah anyhow as i was saying this thing has more than just the standard topology going for it so it would be a good candidate for a trace. Clearly bubstance is offering to trace it for us. He knows all and is keen to tell us how we should be and act in the forum that is based on electronic pedal knowledge. Good on ya bubstance your a good man! Get into it lad! :applause:
