Diamond Bass Comp
Diamond Bass Comp
Postby lohstah » 28 May 2011, 18:19
for you bass lovers out there.
cheers,
lohstah
For this message the author lohstah has received thanks: 10
atreidesheir (30 Dec 2012, 06:34), Blitz Krieg (14 Mar 2016, 07:45), Crowella (23 Dec 2014, 02:36), Crumbchildz (29 May 2011, 14:29), Krefu (29 May 2011, 22:05), modman (11 May 2012, 11:34), seedseed (29 May 2011, 04:47), tp801 (29 May 2011, 09:32), Wiseblood (23 Dec 2014, 04:57), x-tn (03 Jun 2011, 17:58)
lohstah
Has thanked: 198 times
Have thanks: 97 times
Re: Diamond Bass Comp
Postby seedseed » 29 May 2011, 04:52
Fantastic I've been hanging out to see what's inside the bass version. Any chance of getting a pic of track side of the board so if there are any changes to the original guitar schematic they can be spotted. Thanks again
seedseed
Have thanks: 5 times
Postby lohstah » 29 May 2011, 07:41
i´m afraid i only have pics from the component side. only had the thing for a short time together with the blueberry and did not get to take the bass comp apart. :(
i have more detailed pics of the component side but i guess they don´t make sense without the track side.
cheers,
lohstah
lohstah
Postby seedseed » 29 May 2011, 08:44
here are the diamond compressor guts shots to at leasts a b them may help in regards to getting an idea without the track side
they are from the diamond compressor thread on here
For this message the author seedseed has received thanks: 2
Blitz Krieg (14 Mar 2016, 07:45), modman (11 May 2012, 11:34)
seedseed
Postby seedseed » 29 May 2011, 08:46
As you can see from the diamond track side it would be helpful for the bass diamond compressor but you've done well. Don't usually get a lot of bass pedals looked at.
seedseed
Postby seedseed » 31 May 2011, 10:22
Has anyone else got a diamond bass comp out there they could take a pic of the track side so this one can be put to rest???????
seedseed
Postby seedseed » 14 Jul 2011, 12:35
bump anyone got any way of finding out the track side
seedseed
Postby pedalgrinder » 10 May 2012, 14:27
such a pity no track side. This wouldn't take much to get against the guitar one if only one other piece was there. Bump to anyone that may have it. Thanks in advance
pedalgrinder
Has thanked: 202 times
Have thanks: 151 times
Postby oscarv77 » 30 Dec 2012, 05:57
Are we still needing a track side pic of the pedal? I just got one in this week and can take it apart if needed.
For this message the author oscarv77 has received thanks: 2
lohstah (02 Jan 2013, 15:47), pedalgrinder (07 Jan 2013, 09:54)
oscarv77
Have thanks: 10 times
Postby atreidesheir » 30 Dec 2012, 06:35
Do it for Pedalgrinder, man. :thumbsup
atreidesheir
Has thanked: 452 times
Have thanks: 43 times
Postby pedalgrinder » 30 Dec 2012, 08:43
oh yes please i would love to see a track side can we also get some pot values????? anything more to try and put a schematic together would be great. I've heard this to be one of the better bass compressor. I will be forever in your debt!!!! [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif] [smilie=bowdown.gif]
pedalgrinder
Postby Fredenando » 30 Dec 2012, 10:13
Fredenando
Has thanked: 475 times
Have thanks: 93 times
Postby atreidesheir » 30 Dec 2012, 19:01
I had forgotten the diamond comp was sprinkled with fred briggs magic.
His diamante comp might be a beast when optimized for bass.
Or look at the schem of the tilt eq in the standard diamond comp.
courtesy of Briggs inc, Ltd.
The text states the tilt eq is centered @ 900hz. Comparing this schem to the Geofx eq white paper:
Change C3 and c4 to .0047uf to push center frequency of the eq down toward 150 hz (per rg Keen's graphic eq numbers)
or .0033uf for @ 250 hz center.
Now adjust input components and you may be getting close to a bass ready pedal. i am not a bassist so overlook me if these are not the frequencies to emphasize. But 150 hz sounds about right for bass in a mix. In my mixes I cut off bass and bass drum below 80 hz mainly because I love the low end interaction on Abbey Road and the White Album and those were the frequencies emphasized on those mixes.
Correct me if I am wrong, but if you attack me I am going to shove it up your asses. Keep your bad attitudes on your own continents. :P
For this message the author atreidesheir has received thanks: 2
Blitz Krieg (14 Mar 2016, 07:46), Wiseblood (22 May 2018, 02:25)
atreidesheir
Postby atreidesheir » 30 Dec 2012, 19:49
Using whitekeyhole's schematic:
maybe change:
C11 to 51p.
R22 to 1k.
replace C10 and C7 with a 22n.
I am a pedal builder who follows the recipe of the experts, but these seem to be values that will make the input of the diamond comp better for bass.
I could be wrong so feel free to correct my effort.
atreidesheir
Postby pedalgrinder » 31 Dec 2012, 04:25
i think there would be a number of things they have changed in the bass version. Head room would be one to gain more clarity. Obviously they would tune the tone control section to more bass guitar frequency's and they may have adjusted the gain to cater for more active style pickups. i am only guessing but with the new pics we can find out. :mrgreen:
pedalgrinder
Postby lohstah » 02 Jan 2013, 15:49
do it for pedalgrinder and lohstah, man :D
pretty please :wink:
lohstah
Postby pedalgrinder » 07 Jan 2013, 09:55
hows the pics of the track side coming along oscarv77 any luck?????
pedalgrinder
Postby pedalgrinder » 08 Jan 2013, 10:31
me thinks all of fuck all is coming for track side pics!
pedalgrinder
Postby pedalgrinder » 19 Jan 2013, 13:36
pretty much gauranteed why offer if you have no intention of coming through.
For this message the author pedalgrinder has received thanks:
lietuvis (22 Jan 2013, 18:20)
pedalgrinder
Postby yeraym » 27 Jul 2013, 12:31
atreidesheir wrote:The text states the tilt eq is centered @ 900hz. Comparing this schem to the Geofx eq white paper:
This is not correct, to change the pivot frequency you need to change both capacitors on the filter. Here is an article analyzing the tilt eq filter (not mine). To get a center frequency of 250Hz you need to use 20nF on C4 and C5 of WhiteKeyHole's schem.
I have checked it in LTSpice:
I've written a blog post with a long explanation of what I have found and I don't want to self link on my first time posting here, but I have implemented and on-line calculator to design a custom tilt eq filter and that maybe useful for someone here. With it you can specify your desired center frequency and amount of bass and treble boost (it can be asymetric) and it calculates the component values needed.
For this message the author yeraym has received thanks: 3
Crackerman86 (31 Dec 2014, 18:48), Ruy (07 Jun 2016, 23:49), Wiseblood (22 May 2018, 02:29)
yeraym
Have thanks: 3 times
Next
Users browsing this forum: No registered users and 7 guests
