Paul Cochrane - Timmy  [traced]
Re: Paul Cochrane - Timmy
Postby LooseCannon » 03 Aug 2014, 07:57
Could anyone please explain why the Drive pot is wired liked that with R3 going to the second terminal of the pot?
What effect would this give versus how it's wired on a TS9?
LooseCannon
Has thanked: 10 times
Have thanks: 4 times
Postby Nocentelli » 03 Aug 2014, 10:19
I think it makes little difference: The 3k3 (51k in TS) sets the minimum gain level: In the TS, this is in series with the zero ohms of pot resistance at minimum. In the timmy, the 3k3 is in parallel with 1M when the pot is at minimum, so is just a hair under 3k3. The timmy arrangement might have a tiny impact on the taper of the pot as the gain is increased since there's some parallel resistance going on, but I can't imagine it's significant.
Nocentelli
Has thanked: 880 times
Have thanks: 846 times
Postby LooseCannon » 03 Aug 2014, 13:27
Thanks.
I built the Timmy with this layout, and although it seems to work properly i've compared it to the schematic and the Drive pot wiring doesn't look right. R3 should be connected to the -IN of the opamp, not to the output.
Would this change the drive pot operation?
For this message the author LooseCannon has received thanks:
Manfred (06 Aug 2014, 22:06)
LooseCannon
Postby Nocentelli » 03 Aug 2014, 15:00
It will work just the same: the pot + 3k3 resistor act together as a single variable resistor, either way around is electrically identical.
Nocentelli
Postby LooseCannon » 03 Aug 2014, 15:41
Thanks again.
Is it normal for the bass pot to decrease the gain as the bass is cut? Does it change the resistance of R4?
Also regarding R4 (the "maximum gain" resistor) what's the difference between using a lower value for the resistor and using a higher value gain pot?
LooseCannon
Postby paulc » 06 Aug 2014, 01:42
LooseCannon wrote:Could anyone please explain why the Drive pot is wired liked that with R3 going to the second terminal of the pot?
That was done just to make it easier to wire when I made them on generic perf board. No effect on taper or gain range.
PaulC
Timmy pedals
For this message the author paulc has received thanks:
rocklander (06 Aug 2014, 02:38)
paulc
Have thanks: 49 times
Postby paulc » 06 Aug 2014, 01:59
LooseCannon wrote:Thanks again.
Yes - the bass control is part of the gain circuit. It increases the value of R4, but only in regards to the 1uf cap. R4 stays the same in regards to the 39nf. That's what makes it a shelf EQ instead of a 1st order.
PaulC
Timmy pedals
For this message the author paulc has received thanks: 2
piod (07 Aug 2014, 08:38), rocklander (06 Aug 2014, 02:38)
paulc
Postby LooseCannon » 06 Aug 2014, 18:01
Thanks for the info Paul :)
After a lot of experimenting with the TS basic circuit i'm starting to to think that the tone control is what makes it midrangy and a bit muddy, I guess the rat style tone control is what makes the timmy more transparent.
(Although I know you started it off as a booster and not as a TS clone)
LooseCannon
Postby mmolteratx » 06 Aug 2014, 18:31
LooseCannon wrote:Thanks for the info Paul :)
The TS is middy because it cuts all of the bass pre clipping and all of the highs post clipping. That first stage only amplifies things above ~720Hz fully, with everything below decreasing in magnitude as frequency decreases. It also lops off high end, of which the exact cut off frequency varies depending on the drive control setting. You're looking at ~72kHz with the drive at minimum, and ~6kHz with the drive at max. Then after that stage, another filter cuts off high end starting around ~720Hz. Then the tone control boosts or cuts frequencies above ~3.2kHz.
The Timmy is transparent because the tone controls go pretty much completely flat in the guitar's range.
mmolteratx
Has thanked: 103 times
Have thanks: 627 times
Postby LooseCannon » 06 Aug 2014, 19:03
mmolteratx wrote:It also lops off high end, of which the exact cut off frequency varies depending on the drive control setting. You're looking at ~72kHz with the drive at minimum, and ~6kHz with the drive at max. Then after that stage, another filter cuts off high end starting around ~720Hz.
At what stage does that happen? Are you talking about the 1k resistor and the .22 cap at the output of the first opamp?
LooseCannon
Postby mmolteratx » 06 Aug 2014, 20:32
The 1k/.22u is the last low pass filter I was talking about.
mmolteratx
Postby LooseCannon » 06 Aug 2014, 21:10
So what cuts off the high end before that?
LooseCannon
Postby mmolteratx » 06 Aug 2014, 23:37
LooseCannon wrote:So what cuts off the high end before that?
The 47p cap across the drive control/clippers.
mmolteratx
Postby Nacho5 » 03 Nov 2014, 20:53
rocklander wrote:still unverified.. but here's an update.
Thanks for PCB, what size is the pcb to etching?
Nacho5
Have thanks: 5 times
Postby rocklander » 03 Nov 2014, 22:05
no worries.. it's the size where you print it out and the opamp fits.. no idea sorry as I've never made it.
rocklander
Has thanked: 1580 times
Have thanks: 289 times
Postby jimwoud » 10 Aug 2016, 12:00
Hi All!
I want to make a Timmy Clone, but want to be able to cut more bass and have more treble available.
What do you recommend to change?
Thank you,
Jim
jimwoud
Postby swt » 11 Mar 2017, 20:37
hi. can you tell me the tonal differences between 4558, 4559 and 4560?. thanks a lot
swt
Have thanks: 9 times
Postby mlp-mx6 » 12 Mar 2017, 02:17
swt wrote:hi. can you tell me the tonal differences between 4558, 4559 and 4560?. thanks a lot
Undetectable, if they exist at all.
mlp-mx6
Have thanks: 3 times
Postby mictester » 12 Mar 2017, 04:30
Nothing at all, except the newer devices will hiss slightly less.
mictester
Has thanked: 33 times
Have thanks: 802 times
Postby swt » 13 Mar 2017, 14:56
ok thanks a lot. i read somewhere that the 4559 is darker and distorts more and just wanna check if this is true.
swt
Previous
Users browsing this forum: pc3326 and 2 guests
