Basic Audio - Scarab Deluxe  [traced]
Re: Basic Audio - Scarab Deluxe
Postby toneman » 20 May 2017, 00:36
hey cub,
that's a good link that i havnt seen b4!!
thanks!
:thumbsup
Tone-to-the-Bone
toneman
Has thanked: 90 times
Have thanks: 19 times
Postby Cub » 20 May 2017, 08:31
Any time ! A thread is never too old to be bumped if the information is relevant.
Cub
Has thanked: 74 times
Have thanks: 87 times
Postby roseblood11 » 21 Jun 2017, 23:06
Who has tested transistors with different gain? I wonder if 2n5088 with hfe close to 600 or bc547b with hfe around 350 would be better?
I had forgotten this project, but today I found a layout and a half populated board. So, after three years, this will be finished soon.
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby HamishR » 23 Jun 2017, 11:28
I had an original Basic Audio Scarab Deluxe. I have a few others of John's pedals too - he makes great pedals. Not just clever circuits but beautifully built too. The Alter Destiny is amazing.
HamishR
Have thanks: 16 times
Postby marshmellow » 23 Jun 2017, 18:09
Built it this afternoon. I like the general tone, more overdrivey and less all-out fuzz. With 1µ the Fat control isn't doing that much for me, but I think that is due to the tone control, which cuts a lot of bass in general. I think I would have preferred a BMP style control or a simple treble cut here. Transistors are all BC550C. I'll also try a bigger feedback resistor for higher maximum gain, right now it's just a little bit lacking.
marshmellow
Have thanks: 122 times
Postby roseblood11 » 30 Jun 2017, 11:06
After three years, I finally finished my build...
- Using bc547b transistors with hfe around 350 is no problem, I even liked them better than 2n5088 with higher gain
- I tried both variants of the tone circuit that were discussed in this thread. Both are useful, so I put them on a switch as shown in the vero board layout.
Wiring five 9mm pcb-mount pots in a 1590b enclosure is slave labor! Does anybody sell a pcb for this circuit?
roseblood11
Postby roseblood11 » 30 Jun 2017, 15:04
...but the bias isn't perfect in my build. Maybe I'll use transistors with higher hfe or increase the feedback resistor?
The original pedals sounds thicker and creamier in some of the videos.
And I have a strange problem with hiss in my pedal:
- hiss increases, if I turn up the bias pot, but after the 2 o'clock position, it's totally gone. Maybe this is normal, because that's the point where the sound gets gated.
- there's hiss on the fat pot, but only at two small areas, around 10 o'clock and 2 o'clock, and only if the fuzz put is fully clockwise. Maybe caused by creeping current on the veroboard? I used some foam as isolation, that I've never used before...
roseblood11
Postby roseblood11 » 30 Jun 2017, 16:27
The wires to the fat pot and the 10µF cap at the input are very touch sensitive. Maybe a leaky cap? Could this explain the hiss and strange behaviour?
roseblood11
Postby roseblood11 » 30 Jun 2017, 16:59
I doubt that the fat pot is wired correctly in the schematics.
Wouldn't it be better to connect the 10n cap directly to the input and add the 10µF via the pot wired as variable resistor?
Like this:
http://music.codydeschenes.com/wp-conte ... ansfer.pdf
roseblood11
Postby roseblood11 » 30 Jun 2017, 23:42
Some people here and at tagboardeffects reported problems with hiss, oscillation, touch sensitive parts and some power adapers...
All of that might be caused by the fat pot, which is definitely wired wrong in the existing schematics and layouts. It should look like this:
Quick fix: Add a jumper between lugs 2&3 of the pot or on the board. The pot is still wired backwards, but that doesn't matter as it's linear taper.
For this message the author roseblood11 has received thanks:
Wiseblood (16 Jul 2017, 01:19)
roseblood11
Postby destro » 14 Aug 2017, 16:25
Toss a .0022 between the base and collector of Q2 for the 5th cap that all the schems and layouts are missing. The difference is small, but noticeable.
destro
Have thanks: 36 times
Postby Shango » 30 Aug 2017, 21:57
Came across this schematic through a google image search. The two differences I noticed are the 22uf cap coming off the wiper of the Fuzz pot and the extra resistor and cap to ground on the tone control. Is this a version 2 by Basic Audio? Or just someone modding the original design?
https://www.youtube.com/watch?v=KBanayYEj4Q
Shango
Have thanks: 3 times
Postby destro » 01 Sep 2017, 21:50
What you have there is the assumed schematic applied from a circuit design mentioned earlier in this thread.
destro
Re: REQ: Basic Audio Scarab Deluxe
Postby ggbb » 14 Sep 2017, 01:04
~arph wrote:Yes, you can influence taper, but shouldn't the 10k be connected to the wiper instead of the low side of the pot to simulate a reverse log action? The way it's connected now just makes the 50kB pot a 8.3kB pot.
I think the tone pot probably needs to have pins 2 and 3 joined. That makes the 10k in parallel with the pot a true 0-8.3k C-taper variable resistor, and it makes the tone control a true shelf control with the 100n in series with varying resistance from 10.5k to 2.2k.
ggbb
Have thanks: 5 times
Postby Boba7 » 10 Jul 2018, 11:13
destro wrote:Toss a .0022 between the base and collector of Q2 for the 5th cap that all the schems and layouts are missing. The difference is small, but noticeable.
Do you mean 2n2 or 220pf? 2n2 seems a lot
I agree with roseblood11 about the fat pot wiring.
So the circuit is still not exactly traced right? The tone section is still a mystery, and so is the 5th film cap.
And the latest schematic doesn’t include the 4k7 resistor
Boba7
Have thanks: 7 times
Postby elbeeuk » 15 Jul 2018, 09:20
roseblood11 wrote:After three years, I finally finished my build...
They sell a PCB over at PedalPCB :)
https://www.pedalpcb.com/product/dungbeetle/
elbeeuk
Previous
Users browsing this forum: ferryarliansyah, Manfred and 10 guests
