Death by Audio - Apocalypse  [traced]
Postby Glass_Hero » 06 Oct 2011, 04:23
i have apocalypse gut shots.. i'll give you a taste for now.. a quick explanation is the first function is just a twin t filter..second is the newer fuzz war circuit in the bottom right, third is the tl072 opamp, in between the 5 way rotary switch and the tone knob..the fourth is the octave clang circuit in the corner with the 741, transformer and Ge diodes in the upper corner..and then last one is called gain times 1000.. i have not traced down anything on this yet but i have schems for the fuzz war and octave clang..the input preamp is a 741 set up like it is in the octave clang.. i'll have more pics to post later..
For this message the author Glass_Hero has received thanks: 6
culturejam (25 Jan 2012, 19:35), modman (07 Apr 2017, 00:49), OH!STOMPBOX! (10 Apr 2015, 22:51), sinner (25 Jan 2012, 20:49), tabbycat (15 Oct 2015, 21:14), Wiseblood (15 Feb 2017, 00:50)
Glass_Hero
Have thanks: 114 times
Re: Death by Audio Armageddon
Postby Emanuele » 06 Oct 2011, 13:35
Glass_Hero wrote:i have apocalypse gut shots.. i'll give you a taste for now.. a quick explanation is the first function is just a twin t filter..second is the newer fuzz war circuit in the bottom right, third is the tl072 opamp, in between the 5 way rotary switch and the tone knob..the fourth is the octave clang circuit in the corner with the 741, transformer and Ge diodes in the upper corner..and then last one is called gain times 1000.. i have not traced down anything on this yet but i have schems for the fuzz war and octave clang..the input preamp is a 741 set up like it is in the octave clang.. i'll have more pics to post later..
We want more! :popcorn:
Emanuele
Postby Glass_Hero » 06 Oct 2011, 14:13
most of the pics are large and somewhat fuzzy..i'll post them this weekend, maybe by then i'll have figured out the other two functions..
Glass_Hero
Re: Death by Audio - Apocalypse
Postby culturejam » 06 Oct 2011, 14:41
I split this into a new topic, as it is a different pedal (I think).
culturejam
Has thanked: 463 times
Have thanks: 582 times
Postby Glass_Hero » 06 Oct 2011, 20:21
culturejam wrote:I split this into a new topic, as it is a different pedal (I think).
i think its a progression of a pedal design..the armageddon started an early fuzz war circuit (7 backwards transistors) mixed with a switchable filter section..as time when on he added more functions, the armageddon pedal Oliver (the DBA guy) uses for his band has the multiple fuzz circuit switch and the switchable filter sections.. if we can use these armageddon pics to figure out the two filter sections then putting that into an apocalypse would complete the package..
in the movie Fuzz, he said something about the fuzz war being based on his distortion unit..and the quest for an ultimate distortion.. this armageddon pedal is an early step in that quest..
i feel as though the apocalypse and armageddon are the same unit just at different stages of development.. we can see from the pics of this armageddon that it is a 7 transistor fuzz war.. the sub switch opens up more bass frequencies (bigger input & output capacitors).. we have seen in the fuzz war thread how that pedal has changed over the past few years going from a 7 transistor unit to a 4 transistor unit (did i post the partial schem i did on the newer fuzz war yet?).. the apocalypse is a stripped down (missing the second switchable filter section) version of the newer armageddon design.. the fuzz war circuit in the apocalypse is the newer 4 transisor version (actually it only uses 3 of the 4 stages..the output buffer is left out)..
http://www.youtube.com/watch?v=OArdM4Cb-ho
pause the video at about 3 seconds in, its an up-close shot of Oliver's armageddon pedal, it can be seen in the video there are 6 positions on Oliver's pedal.. and the second filter.. what do each of the postions do? not sure but my guess is that its pretty similar to the apocalypse fuzz selection switching..
but on to the real issue, the circuit.. and more pics, which i will be posting soon..
Glass_Hero
Postby Emanuele » 07 Oct 2011, 00:04
not yet! :mrgreen:
Emanuele
Postby CodeMonk » 07 Oct 2011, 01:36
I hate you.
I was gonna call my new fuzz Armageddon.
Now I can't :(
Oh well.
CodeMonk
Has thanked: 16 times
Have thanks: 55 times
Postby Mbas974 » 25 Jan 2012, 18:24
One question, close to the led there is a trans.. which model is it ?
Is it for supply or what ?
Thanks in advance.
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Postby bubstance » 25 Jan 2012, 20:41
Same as the Octave Clang. It's a 10K primary, 2K secondary. Mouser part #42TM002-RC or 42TL002-RC.
bubstance
Has thanked: 80 times
Have thanks: 112 times
Postby Glass_Hero » 18 May 2012, 16:21
i have a schem.. and yes this is an updated, yet slightly stripped down ( no filter stomp w/ second filter, and fuzz circuit #6) version of an armageddon..
i wonder how pissed off the DBA guys would be if i were to post this schem??
Glass_Hero
Postby bubstance » 18 May 2012, 21:17
Glass_Hero wrote:i have a schem.. and yes this is an updated, yet slightly stripped down ( no filter stomp w/ second filter, and fuzz circuit #6) version of an armageddon..
If they sell a pedal the information inside is available to whoever opens it. Does it really matter if they get pissed off? I would vote share.
For this message the author bubstance has received thanks:
roseblood11 (19 May 2012, 01:23)
bubstance
Postby Glass_Hero » 18 May 2012, 22:56
37 resistors
27 caps
3 ICs
1 Transformer
5 transistors
4 Ge Diodes
3 pots
1 rot_switch
1 stomp
1 LED
this is in no way a beginners circuit to build.. i have about 8 pages of schems from this pedal.. this will not fit well on vero-board..
Glass_Hero
Postby ieatyouforbreakfast » 13 Dec 2013, 21:52
I'm interested to see the schematic for this. Still have it?
ieatyouforbreakfast
Have thanks: 10 times
Postby digi2t » 20 Dec 2013, 05:15
Can't watch the video, it's marked private. :cry:
No matter how many times I cut it, it`s STILL too short!
digi2t
Has thanked: 54 times
Have thanks: 347 times
Postby tsume67 » 06 May 2014, 13:29
Someone has the schematic? I am very interested in this great pedal.
Please :(
tsume67
Postby tabbycat » 15 Oct 2015, 21:28
this, many times over. i don't know if i'll have the ability or the patience to build a clone, but i'd like to know what is going on in there. just to know and understand a bit more about what is required to make a great noise.
i would also be extremely surprised to discover that oliver has never used this site at some point for his own design research.
as the great steve zissou would say, we're not stealing anything, it's a scientific community.
"be a good animal, true to your instincts" (d.h. lawrence).
"there is no excellent beauty that hath not some strangeness in the proportion" (francis bacon).
"ni dieu ni maître" (anarchist slogan).
tabbycat
Has thanked: 227 times
Have thanks: 64 times
Postby turdadactyl » 29 Dec 2016, 16:27
It looks like this thread has been bumped several times over the last few years but the schematic never made it into any of the replies. Does anyone have it?
turdadactyl
Have thanks: 18 times
Postby ksenanekro » 01 Feb 2017, 20:04
i'm here too...asking for this schem...!!!anyone??
ksenanekro
Has thanked: 13 times
Have thanks: 35 times
Postby modman » 01 Feb 2017, 21:30
Glass_Hero wrote:i have a schem.. and yes this is an updated, yet slightly stripped down ( no filter stomp w/ second filter, and fuzz circuit #6) version of an armageddon.. i wonder how pissed off the DBA guys would be if i were to post this schem??
Who cares? It's your drawing and your copyright.
turdadactyl wrote:It looks like this thread has been bumped several times over the last few years but the schematic never made it into any of the replies. Does anyone have it?
tsume67 wrote:Someone has the schematic? I am very interested in this great pedal.Please :(
ieatyouforbreakfast wrote:I'm interested to see the schematic for this. Still have it?
ksenanekro wrote:i'm here too...asking for this schem...!!!anyone??
Guys, this isn't helping. Buy, borrow or steal the pedal and trace it yourself.
He's really only a glass hero ;-)
For this message the author modman has received thanks:
Nocentelli (01 Feb 2017, 23:28)
Has thanked: 3113 times
Have thanks: 563 times
Postby Cannibal » 10 Feb 2017, 17:10
Done and tested, I'd say verified.
That's my take on the DBA Apocalypse, reversed from an original a friend owns.
Hope it helps.
Enjoy.
Updated files are here
Seiche wrote:there's a difference between being drugged (I don't think it was only booze) and retarded.
For this message the author Cannibal has received thanks: 5
d312a (12 Feb 2017, 17:06), idy (17 Feb 2017, 17:16), Nocentelli (15 Feb 2017, 09:56), tp801 (20 Feb 2017, 22:19), turdadactyl (08 Mar 2017, 17:45)
Cannibal
Has thanked: 31 times
Have thanks: 15 times
Next
Users browsing this forum: No registered users and 17 guests
