Death by Audio - Apocalypse  [traced]
Re: Death by Audio - Apocalypse
Postby Bazzu69 » 01 Jan 2018, 11:44
...try now 2M2 in place of the new 910k resistor. If the signal increase you can try tu put more bigger value resistor till reach the quite signal level. The only problem is the signal/noise ratio, in this way its coming worse, but you can try for reach the good and simple sond withouth any kind of booster or complicated circit design.
Bazzu69
Postby Bazzu69 » 05 Jan 2018, 04:58
Between the two transformers, who the one is better in sound?
Bazzu69
Users browsing this forum: Groovenut and 5 guests
