Okko - Diablo Boost+ (goop pics!!) [traced]
What transistors are applied in the original Diablo+? Who knows?
The newer D. has the charge pump circuit, the older didn't and the same with more drive feature. Any CP circuit (from the Centaur or other FX) can be added in front of the BIAS devider. I would drop the more drive circuit, IMHO there's no need for it and for me it's overkill in this circuit. Catelinbread's D-secret has a very similar layout and I think some features from the D. could be added to soup it up a bit.
JHS
JHS
- flood
only slightly OT - has anyone tried running the BSIABII off 18V? what's it like?
i suppose it could be done with only an adjustment to the trimpot...
Ed G. What transistors applied in Diablo+?
- sinner
- Has thanked: 1031 times
- Been thanked: 908 times
I have plugged 12-18 voltage to number of pedals and It was always less gainy with stronger bass response. But I guess It's personal impresionEd G. wrote:I've run it off 18v. It becomes really gainy. Lots louder too. I've come up with an 18v design but I've had to revoice it and restructure the gain.
I'm working on BSIAB2 with charge pump up to 18vdc with active EQ section borrowed from Xotics + switchable AMZ MiniBooster on front of it right now. It's my learning process (and contribution finally ), that will take ages as I'm sucks + I have take alot of hours in my abmulance station as I'm buying a house. I hope it will be kickass
- Liquids
sinner wrote: I have plugged 12-18 voltage to number of pedals and It was always less gainy with stronger bass response. But I guess It's personal impresion
Ed's findings confirm my findings too. I think the difference is that with op amps based circuits, more voltage means more headroom...
I've been messing with Mini-Boost based circuits at higher voltage, and my theory for why it's gainier (yet also a bit more dynamic and 'alive' feeling) is that, since it's not using diode clipping...the added voltage yields more volume...which means the first stage slams the next harder...so, hence more gain.
I've also been messing with the Xotic active tone control circuit...which is right from the Boss Fa-1, far as I can tell. It's interesting, but I'm not sure I like it for more than novelty. I find using 47n or 100n caps are more useful to control the lowest frequencies, while the 33n control a bit more 'mud' frequencies. I also liked making the treble caps smaller like 2.2n over 4.7n to control just the highest frequencies - personal preference. That being said, check the LM833 datasheet--I haven't compared them yet, but the active EQ they detail has a different arrangement for the treble part of the EQ, and might be worth comparing.
"Gain" is short for "voltage gain." So, if you increase voltage to a gain device, you increase gain. Problem is, people use "gain" and "distortion" or "drive" interchangeably. I can see how that happens in circuits that are designed to distort. Increase gain, you increase distortion or drive. But that's not always the case, especially with opamp devices.
By increasing voltage to the bsiab you can do away with J201's, which I find usually dark and mushy. In fact, going to mpf102s for Q1-Q4 and 2n5457 for Q5 yields plenty sustain and drive. I find it becomes more touch-sensitive and dynamic, more open sounding. You hear the string underneath, that old school british marshall kerrang sound.. I've experimented with this in re-voicing the circuit and I'm working with Chad Matthews of cmatmods to release a commercial version. The pedal will have a charge pump. I've tried all kinds of tone controls but keep going back to the BSIAB2 values (which, btw, I understand are used in at least a couple big-name commercial pedals).
- caspercody
Has anyone created a pcb transfer? Or found out what Jfets are being used in this?
I hope this layout drawn by me can help you!!!
- masterdiablo3.rar
- (769.53 KiB) Downloaded 902 times
- fosnal1950
What Eagle software did you do it with ? I can't open it.
Just downloaded the most recent Eagle version and get the message : this not a valid schem !
What could be wrong ?
Alf
Alf
- caspercody
I am using 5.6.0.
- fosnal1950
Sorry guys, I was being very foolish !
Tried to open in with express !
It works perfectly with eagle 5.6 .
do you use the freeware version ?
- caspercody
Yes, I use the freeware version. I use Gaussmarkov library, and the hobby .dru pcb rules file.
chriscustom wrote:soulsonic wrote:Bumping this to attach the schematic. I don't remember who traced this one or where I found it... I think I found it at Das Musikding... maybe Kusi traced it?
Anyway, I hope it is okay with the author to post this here.
OKKO_Diablo+.pdf - LEVEL 10kk??? It is an error? Can should be 100k?
+1
- quaternotetriplet
hi... what is the purpose of the r21? the 100e on the power section.
- quaternotetriplet
anyone knows how to increase the gain of this bad boy?
- sevinisthenumber
is this verified?checco1280 wrote:I hope this layout drawn by me can help you!!!
C.S. Lewis
C.S. Lewis
