Page 1 of 8
Okko - Diablo Boost+ (goop pics!!)
Posted: 12 Jan 2008, 17:14
by modman
Posted: 12 Jan 2008, 17:31
by soulsonic
The circuit board needs to take a bath. A chemical bath.
Posted: 12 Jan 2008, 18:34
by briggs
I love those cases. Huge LED's are great!
Posted: 13 Jan 2008, 04:08
by neilnil
I used to own one (without boost) and it had the thickest epoxy goop i've ever seen. The goop was hard enough to hold the PCB securely so I couldn't dare to trace it. It was quite versatile and covered a lot of grounds but lacked dynamics IMO. Pretty nice OD overall and looks really cool with that contoured face. I would guess it has ROG style fet-based circuitry.
Posted: 13 Jan 2008, 10:22
by JHS
The basic circuit is a BSIAB1. The boost function seems to be split gain pots ala FD-2.
JHS
Re: OKKO - Diablo Boost+ (goop pics!!)
Posted: 13 Jun 2008, 14:01
by plexilover
Where can i get the BSIAB1 circuit? What are the differences to the BSIAB2?
Posted: 13 Jun 2008, 16:09
by JHS
A stock BSIAB2 will not produce the sound of the Diablo. The Diablo is a very heavy modded BSIAB2 with a lot of finetuned part values. The tone is generated by this mods and the Diablo sounds way different compared to the bland sounding BSIAB.
JHS
Re: Okko - Diablo Boost+ (goop pics!!)
Posted: 14 Jun 2008, 12:39
by seniorLoco
its rocket science i tell you
modding the Bsiab2....
Posted: 14 Jun 2008, 21:29
by soggybag
The description talks about a charge pump option. BSIAB probably sounds pretty good at 18V.
Posted: 05 Jul 2008, 05:43
by Ed G.
soggybag wrote:The description talks about a charge pump option. BSIAB probably sounds pretty good at 18V.
It does.
Posted: 24 Oct 2008, 16:53
by plexilover
Again, anyone who have the BSIAB1 schematic? What are the differences between BSIAB 1 and 2?
Anyone out there who modded a BSIAB?
Posted: 25 Oct 2008, 17:02
by Ed G.
I think the term "bsiab" in this sense is used improperly. The Okko Diablo, I'm sure, uses cascading miniboosters (revealed to DIY'ers by Jack Orman) but other than that, I suspect it shares little else with the BSIAB or BSIAB2.
I urge anyone to experiment with a breadboard and fets. The minibooster is high gain, self-biasing and sounds great. When overdriven, I find it sounds much more natural than diodes clipping. There are many avenues for tone shaping.
Look up also Aron Nelson's booster 2.5 and Doug Hammond's Sweet Thing schematics for more examples.
Posted: 13 Dec 2008, 16:02
by Lawnchair
Anyone degooped one yet? I might have to pick one up after the holidays. I'm tying to work up a body control for the BSIAB2 now.
Re: Okko - Diablo Boost+ (goop pics!!) [traced]
Posted: 14 Aug 2009, 03:19
by soulsonic
Bumping this to attach the schematic. I don't remember who traced this one or where I found it... I think I found it at Das Musikding... maybe Kusi traced it?
Anyway, I hope it is okay with the author to post this here.
Posted: 14 Aug 2009, 09:05
by Saruman
Posted: 14 Aug 2009, 18:42
by SPeter
Thanks Man!
Posted: 15 Aug 2009, 13:23
by eddieod
GREAT!!!
BUT...which fet's go into this circuit (Q1....7)? J201's?
Edwin
Posted: 15 Aug 2009, 15:12
by soggybag
Is that two mini-boosters followed by a BMP tone control? Similar to the BSIAB. The more channel looks more interesting, especially the bass control.
Posted: 16 Aug 2009, 13:03
by chriscustom
soulsonic wrote:Bumping this to attach the schematic. I don't remember who traced this one or where I found it... I think I found it at Das Musikding... maybe Kusi traced it?
OKKO_Diablo+.pdf - LEVEL 10kk??? It is an error? Can should be 100k?
Posted: 01 Sep 2009, 11:00
by checco1280
Hi. in the original pedal, there is a selectable charge pump inside (for a 18V supply);
according to the scheme of the power supply posted in pdf, where the charge pump should be placed? For example can I use the charge pump of geofex
http://www.geofex.com/circuits/+9_to_33.htm
before the entire circuit?
