Is there a parts list?checco1280 wrote:I hope this layout drawn by me can help you!!!
Okko - Diablo Boost+ (goop pics!!) [traced]
- sevinisthenumber
C.S. Lewis
C.S. Lewis
- caspercody
I have not made this, but have gotten replies back from those that used my layout and it does work.
- sevinisthenumber
What are the parts that have no values on the layouts????caspercody wrote:I have not made this, but have gotten replies back from those that used my layout and it does work.
C.S. Lewis
C.S. Lewis
- caspercody
I do not have my files with me, but the schematic was taken from the same schematic in this forum. I think it is on the second page. It is a pdf from Soulsonic.
yes, it's verified....not by me, but from a guy who built it some time ago...for the values you can look at the pdf that you find on the topic. I also have a master file for making the PCB.sevinisthenumber wrote:is this verified?checco1280 wrote:I hope this layout drawn by me can help you!!!
- masterdiablo3.rar
- (769.53 KiB) Downloaded 1255 times
- jmwreck
is there really an IC on this pedal, i've seen an IC on one of the layouts, but havent found an IC in the eagle file. OR maybe im just excited to make this pedal and overlooked it.
- caspercody
No IC, just Jfets.
in my layout there is an IC...it's just a LT1054 for the charge pump...for the 18V...but if you don't need it you can omit all the charge pump session!
- Alex Frias
Is it possible to use a MAX1044 as a charge pump or the needs for current is beyond what it can take?
- quaternotetriplet
i built this one.. and got some RFI when the gain is maxed..
how about you build guys?
- ryanuk
- Seiche
no, only the pots with the arrows are external pots. The smaller ones labelled gain+, bass+, tone+, level+, presence, and bass are internal trim pots.Question about the schematic for this build - the original Okko Diablo+ pedals have 6 knobs, with 2 internal presets. See guts below. However the schem on page 1 shows 11 pots!!??
Seems to be still a difference. no idea why there are 6 trim pots with the schematic when there are only 2 in the real thing.
- Seiche
hey kusi,
i appreciate it! that's what ryanuk posted a gutshot of, but on the gutshot you see there are only 2 internal trimpots (instead of 6 on the schematic), did you just include that for more tonal options or does the original indeed have 6 trimpots which we cannot see? maybe under the goop?
- kusi
hi,Seiche wrote:hey kusi,
ryanuk`s gutshot is form the basic-verison without the booster, just the "rock"-circuit.
in this version there are only two trimm-pots, presecne and bass.
regards, kusi
- Seiche
no, look again!kusi wrote:ryanuk`s gutshot is form the basic-verison without the booster, just the "rock"-circuit.
There are also two 3pdt switches visibleryanuk wrote:Question about the schematic for this build - the original Okko Diablo+ pedals have 6 knobs, with 2 internal presets. See guts below. However the schem on page 1 shows 11 pots!!??
- kusi
looks like heiko (mr. okko) changed some things in the newer pedals.
From his FAQ:
"Does the Diablo Gain+ have more gain than the "standard" Diablo?
No. Activating the "+" mode has the same effect as turning up the gain control. If the gain control is already on maximum, the "+" doesn’t increase the gain anymore."
the old gain+ version had an additional booster after the normal circuit, the newer gain+-controll looks just like serial-resistance with the gain pot.
but why he continue with gooping his pedals? a waste of money and time!
regards, khe
From his FAQ:
regards, khe
- Seiche
hmm apparently there is also a diablo boost+ as mentioned on Gregor Hilden's Website. It features a boost after the diablo stage, and has internal trim pots for bass treble and gain. Maybe there is the difference?
Exactly! There are 3 versions of Diablo:Seiche wrote:hmm apparently there is also a diablo boost+ as mentioned on Gregor Hilden's Website. It features a boost after the diablo stage, and has internal trim pots for bass treble and gain. Maybe there is the difference?
1. standard
2. Gain+
3. Boost+
2. Gain+ is the version which guts have been show in this thread recently (BTW it's the picture of my Diablo )
It doesn't have a gain boost per se, it's just more like a second gain setting.
This version has only 2 internal trimmers: bass and presence.
3. This Boost+ version has separate boost circiut and more trimmers inside.
