Okko - Diablo Boost+ (goop pics!!)  [traced]
Re: Okko - Diablo Boost+ (goop pics!!)
Postby Chewbacca » 11 Aug 2017, 12:58
neb wrote:How is the sound difference between 9V and 18V? I am wondering if I should run it at 18V all the time and drop the switch.
Run it at 18V. Once I switched mine to 18V I never switched back. 9V is only worth it if you have exceptionally good J201s.
Chewbacca
Have thanks: 8 times
Postby Chewbacca » 11 Aug 2017, 13:07
ozzy666 wrote:Did anyone try this polish copy of the Diablo?
http://www.efekty-diy.pl/diablo.html
I actually have managed to build the pedal just from copying the pictures of pcb on their web site and from reading their BOM.
It worked perfectly! Highly recommended :-)
I've had some of the Polish kits in for Repairs. The Kits are actually pretty good and unlike the real Diablo they still use the active booster - which is pretty good as a booster by itself.
Problems mostly come with the J201 - the remaining J201s on the market are often rip-offs and do not work well. So make sure to get some good J201s or at least a whole bunch of them so you can cinderella out the bad ones.
Other problems with the Polish kit often come with the 7660. They often unexpectedly die or they produce a HF whine. Use 1044 or 1054 - they are much sturdier and less noisy.
For this message the author Chewbacca has received thanks:
ozzy666 (11 Aug 2017, 15:06)
Chewbacca
Postby neb » 12 Aug 2017, 13:01
I ordered mine directly from onsemi, smd SOT23 variant. TO92 is not in production any more afaik. I will also use LMC7660 from TI.
neb
Postby jalmonsalmon » 12 Aug 2017, 19:47
Here is an OSH Park shared for this pedal
https://oshpark.com/shared_projects/qqjus0RA
Should work fine!
For this message the author jalmonsalmon has received thanks:
ozzy666 (12 Aug 2017, 22:03)
jalmonsalmon
Has thanked: 80 times
Have thanks: 23 times
Postby vvv » 13 Aug 2017, 08:19
I like this pedal more at 9V. Unlike like some Catalinbread pedals this one is not at it´s best with any "extra tightness" that 18V gives. I recommend to include the switch or try running with adjustable power supply so you can try something in the middle too, like 12V.
vvv
Postby neb » 16 Aug 2017, 10:57
Here's the final board, 6x4cm.
neb
Postby strat100 » 29 Jan 2019, 22:04
Came across this on ebay with no goop.
strat100
Previous
Users browsing this forum: afont2000, Manfred and 18 guests
cron
