Catalinbread Pareidolia Harmonic Mesmerizer  [traced]
Postby KindaFuzzy » 23 Nov 2011, 00:54
Just got this one in the mail today, so far I count 4 x 2n5484, 2 x 2n5457, and some smd chips, a tl072, a 2206d and a 78m09 regulator. Trace may take a while it's a pretty crammed layout.
For this message the author KindaFuzzy has received thanks: 13
culturejam (27 Nov 2011, 19:08), Fredenando (23 Nov 2011, 01:01), Intripped (22 Sep 2013, 21:17), morelius21 (12 Mar 2012, 23:21), Nocentelli (23 Nov 2011, 07:47), p.eat (23 Nov 2011, 09:24), roseblood11 (23 Nov 2011, 10:24), Stray (23 Nov 2011, 09:44), tp801 (23 Nov 2011, 12:21), WhiteKeyHole (23 Nov 2011, 08:58) and 3 more users
KindaFuzzy
Has thanked: 106 times
Have thanks: 296 times
Re: Catalinbread Pareidolia Harmonic Mesmerizer
Postby Matt Gnarly » 23 Nov 2011, 03:24
Very interested, will be following the progress on this one.
Matt Gnarly
Postby grrrunge » 23 Nov 2011, 08:55
Ouch! :) Pretty crammed on the top side, huh?
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby roseblood11 » 23 Nov 2011, 10:29
Definitely more complex than I thought it was!
Can you please post a parts list? (I'd like to place my order soon, as shipping from Thailand takes sooo long...)
roseblood11
Has thanked: 350 times
Have thanks: 310 times
Postby Nocentelli » 23 Nov 2011, 11:01
roseblood11 wrote:Definitely more complex than I thought it was!
I assume you're planning to do a vero layout? That's going to be BIG
Nocentelli
Has thanked: 880 times
Have thanks: 846 times
Postby roseblood11 » 23 Nov 2011, 11:34
I've got some already drilled 1590BB enclosures from other projects...
other question: How can a 7809 work in a circuit that is powered with only 9V? :scratch:
But wait, does it really use a 9V power supply? The datasheet says that the supply range of the XR-2206 is 10 to 26V.
roseblood11
Postby mrkaploca » 23 Nov 2011, 11:44
maybe there's a v-doubler inside?On the top side of the board?
mrkaploca
Has thanked: 15 times
Have thanks: 12 times
Postby mrkaploca » 23 Nov 2011, 12:06
no doubler it seems(there is sa picture of both sides of pcb :oops: )
Pedal has battery snap...How can 9v regulator work with battery voltage which usually is below 9 V?
mrkaploca
Postby KindaFuzzy » 24 Nov 2011, 03:43
Ok, parts list as requested, I should start every trace like this.
Pots: 1Mc rate, 10Kb depth, 500Ka volume
Chips: xr2206d, tl072, 78m09
Diodes: 1n4007, two 1n4148, dual orange/green led
Transistors: Q1, Q2, Q4, Q5 are 2n5484, and Q3, Q6 are 2n5457
Caps:
c1 47uf
c2 47uf
c3 270p
c4 .1
c5 .0022
c6 .1
c7 2.2uf
c8 47uf
c9 .1
c10 .0047
c11 .1
c12 2.2uf
c13 1uf
c14 1uf
c15 100uf
c16 4.7uf
c17 1uf
Resistors: 9x 1M, 6x 10k, 4x 1k, 100k, 4.7k, 22k, 240r, (23 in total including the four hidden under the input jack).
I ordered a couple of xr2206cp chips from ebay which should be the functional equivalent in a dip package so I can compare to the original. The cap numbers are straight from the board. I'm sure you can use a 1ma pot as well, just wired backwards instead of the c tapered one.
For this message the author KindaFuzzy has received thanks: 5
culturejam (27 Nov 2011, 19:09), Intripped (22 Sep 2013, 21:17), Jack5 (24 Nov 2011, 11:12), roseblood11 (25 Nov 2011, 00:41), tp801 (24 Nov 2011, 09:33)
KindaFuzzy
Postby Prostheta » 27 Nov 2011, 11:51
mrkaploca wrote:no doubler it seems(there is sa picture of both sides of pcb :oops: )
Perhaps the regulator is purely there for the DC input. It may run "raw" off a 9v battery however the DC in might be higher and be regulated down to 9v? :scratch:
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use" - Søren Kierkegaard
Prostheta
Have thanks: 5 times
Postby Oliphaunt » 30 Nov 2011, 02:43
I didn't know about this pedal, but I am glad to see someone tackling this project. I have a friend with the old Fender amp with this odd tremolo circuit and I love it. It is completely unique, and sounds great. The videos I have now seen of this pedal all have an overwhelming throb in the low end that seems out of balance. Hopefully the circuit either doesn't sound like that in person, or can be modified to have a more balanced frequency response.
Oliphaunt
Have thanks: 3 times
Postby madbean » 30 Nov 2011, 03:36
I'm pretty stoked to see further progress on this. Demo sounds lush.
madbean
Postby roseblood11 » 30 Nov 2011, 09:18
@madbean: Will you offer a pcb for this one?
I think of putting the Pareidolia and your version of Bajamans Trembulator in one 1590BB enclosure...
roseblood11
Postby madbean » 30 Nov 2011, 16:58
roseblood11 wrote:@madbean: Will you offer a pcb for this one?
No, I'm just interested in how it works, not cloning it. Sorry :(
madbean
Postby mrkaploca » 16 Dec 2011, 12:55
any progress on this one?
mrkaploca
Postby KindaFuzzy » 16 Dec 2011, 13:26
I had a customer amp build that was priority, should get to this next week sometime.
Nocentelli (16 Dec 2011, 16:19)
KindaFuzzy
Postby coldcraft » 16 Dec 2011, 15:12
if we get through this, I'd consider having some PCBs made for it. Perhaps with some modifications as well.
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Postby mrkaploca » 16 Dec 2011, 18:51
KindaFuzzy wrote:I had a customer amp build that was priority, should get to this next week sometime.
Cool! But could this be 7805 regulator(it is not so visible on the image,or it is sanded out ? ).
mrkaploca
Postby KindaFuzzy » 16 Dec 2011, 19:48
mrkaploca wrote:Cool! But could this be 7805 regulator(it is not so visible on the image,or it is sanded out ? ).
Nope, it says 78m09b for sure, I haven't looked at that section at all to see how it works with a battery though.
KindaFuzzy
Postby coldcraft » 16 Dec 2011, 20:16
2206D (as in XR-2206D) is a function generator. That's most likely their LFO
coldcraft
Next
Users browsing this forum: 6L6GC, art7710, Chugs, Google [Bot], junkwork and 10 guests
