Page 1 of 6
Top Tone - Light Drive
PostPosted: 04 Feb 2012, 11:58
by MWichni
Welcome, I have some gut shots of the Top Tone Light Drive (thanks to one kind person). I believe this is a Pete Cornish SS-2 without an input buffer. I have traced the pedal and I can post the schematic but I'm not 100% sure and only a few values (don't remember which) are read from the gut shots.
EDIT:
I don't have the pedal unfortunately, only gut shots.
Here is the schematic.
Re: Top Tone Light Drive
PostPosted: 04 Feb 2012, 12:59
by sinner
Looks very much like two cascaded RAT's to me, am I right?
PostPosted: 04 Feb 2012, 13:13
by MWichni
sinner wrote:Looks very much like two cascaded RAT's to me, am I right?
Totally not. If I traced it properly it is a Distortion + with added tonestack and second gain stage.
PostPosted: 04 Feb 2012, 15:29
by Ghandi
ah finally, thanks very much! :thumbsup
yeah the Top Tone Light Drive is a clone of the Cornish SS-2
I asked them and they gave me the hint in the direction of the Dist.+ with something added after that.
BTW the Costalab Natural Drive is also a clone of the SS-2 but the Top Tone is supposed to be better sounding...
cheers for that!
ghandi
PostPosted: 04 Feb 2012, 17:46
by gilmour_pugliese
Ghandi wrote:ah finally, thanks very much! :thumbsup
cheers for that!
ghandi
The N.Driver is NOT a SS-2 clone, because it's a 2 transistor (2N5088) circuit followed by a buffer inspired on IC buffer... Also the ND is poor sounding and too muddy... :popcorn:
PostPosted: 04 Feb 2012, 18:22
by MWichni
If someone could look at the values and schematic- does this make any sense? And pot values are:
Volume A10k
Drive C50k
Tone B25k
PostPosted: 04 Feb 2012, 18:59
by mmolteratx
Are you sure R11 is connected to 9V? Would make more sense to be connected to Vb.
I find it odd that he used 2 LM741s instead of an LM1458 or JRC4558. Would've made for a more compact layout.
PostPosted: 04 Feb 2012, 19:11
by MWichni
From what I see on the last picture where I marked +9V and GND rails r11 is connected to +9V. But as I wrote earlier it would be great if someone could check the schematic and values.
PostPosted: 04 Feb 2012, 19:53
by mmolteratx
Did up the schem and a quick single sided 1590B sized layout in Eagle. Part numbering matches that of the schem in post 1. Only difference is that the two LM741s have been replaced with a single dual op amp.
Schem: http://dl.dropbox.com/u/8021347/Light%20Drive.sch
Board: http://dl.dropbox.com/u/8021347/Light%20Drive.brd
PostPosted: 04 Feb 2012, 20:21
by Ghandi
mmolteratx wrote:Are you sure R11 is connected to 9V? Would make more sense to be connected to Vb.
I could imagine that he used two single op-amps because the first one is the old "crappy" LM741 for the overdrive side
and the second one is a more modern one like a Tl071 or something like that...
@MWichni:
I'll try to go through the schem and the pics later this evening if I find the time.
Thanks again for your work!
PostPosted: 04 Feb 2012, 20:45
by Ghandi
MWichni wrote:If someone could look at the values and schematic- does this make any sense? And pot values are:
Volume A10k
Drive C50k
Tone B25k
The values look good,
that 50K drive pot gives a max op-amp gain with R7 being only 470ohm of 212 and it is also reverse log and that is perfect.
C5 across the drive pot is a difference to a normal distortion+ and would give some high end boost if the drive pot is turned down and bypassed by the cap giving the higher frequencies more gain and presence, pretty cleaver as a stock distortion+ sound pretty muddy at low gain settings.
The Tone pot also looks good.
The second op-amp looks a bit strange to be, especially the connections around R12, R13 and C12, but it could work that way,
I'll have to think some more about it...
One question do I understand it correct that you only used the pics to make that schematic?
and the pic from the pcb side with some values given and some unknown, has that the same part numbering as the schematic?
I cant make out many values from the pics, how did you do that?
PostPosted: 04 Feb 2012, 22:20
by MWichni
Values marked on the picture is read from the pictures. I had some resistor color codes read down by the owner and from that I made my guesses. Hope it helps. And yes I traced it only from the pictures.
PostPosted: 05 Feb 2012, 00:00
by Ghandi
Well,
I can't confirme the schematic.
There are too many connections were I can't make out if it's a resistor or capacitor and what value they have.
For example C1, D1, D? look a bit wrong if that C1 is supposed to be the C1 input cap from the schematic
and if D1 and D? are the 1N270 clipping diodes...
Also the value of the input cap seems to be a bit too large
PostPosted: 05 Feb 2012, 10:30
by MWichni
Don't compare parts numbering from schematic to the layout because they are not the same. I'm sure that D1 and D? are clipping diodes because this make sense, right? If you will trace this from what I drawn and from the pictures you will come close to the schematic I ended up I think.
PostPosted: 05 Feb 2012, 14:20
by Ghandi
ah, OK that makes it clearer for me...
Could very well be that I end up with a very similar result,
but there are a few parts totally under the goop where it's impossible to tell what values they have, caps and resistors.
Also I would really like to know what IC's he used, since I believe that he used two different ones...
my bet would be 741 and TL071 but that is only a guess...
PostPosted: 05 Feb 2012, 15:05
by MWichni
Unfortunately I can't tell that too. I think that for the dist+ part of the layout it is 741 and for the recovery stage it could be 741 or TL071. The biggest problem is to determine resistors and capacitors values in the recovery stage as there is no way to read them. But dist+ and tonestack values are rather sensible and some of them were read from the pictures.
PostPosted: 05 Feb 2012, 16:00
by mictester
MWichni wrote:Unfortunately I can't tell that too. I think that for the dist+ part of the layout it is 741 and for the recovery stage it could be 741 or TL071. The biggest problem is to determine resistors and capacitors values in the recovery stage as there is no way to read them. But dist+ and tonestack values are rather sensible and some of them were read from the pictures.
The output stage doesn't make much sense as drawn - I think it's probably a bit simpler:
The 1M coming from the junction of the two 10k resistors would bias the first op-amp input OK. The two 1M bias divider resistors can't be used with a 10ยต capacitor as drawn - the time constant would mean that the bias would drift up towards 4V5 over several seconds!
It seems to be a pretty crude design (in common with a lot of this guy's circuits - usually built on the basis of "what you don't put it can't go wrong"!). The use of a pair of 741 op-amps is probably in an effort to use the limited bandwidth of this IC type.b The problem will be that it will be noisy (the 741 really hisses badly by modern standards!).
PostPosted: 05 Feb 2012, 19:17
by MWichni
Thanks for the reply but if you trace the schematic from the picture I'm sure that you will get the same schematic that I get. This is why I'm thinking about the values of the parts instead of chaning the schem. But maybe I'm wrong so I'm asking about confirmation. Hope it's not too much. Thanks in advance.
PostPosted: 11 Feb 2012, 15:04
by IvIark
Here's a vero for it, currently unverified but I've checked it through a few times. I've used a series protection diode, but you can always alter it if you want it as per the original, or omit it entirely if you don't want the small voltage drop.
PostPosted: 11 Feb 2012, 15:06
by IvIark
Oh and here's the Cornish buffer :mrgreen:
