JHS - Little Black Buffer  [traced]
Postby kev1n » 10 Mar 2012, 07:12
I had the chance to check out a little black buffer the other day. Started to trace it, it looks like its based off jack ormans mosfet buffer. Has the same ic and 10 uf/ .1 uf cap.
kev1n
Have thanks: 10 times
Re: JHS Little Black Buffer
Postby sinner » 10 Mar 2012, 08:29
Cool, thanks for the info. Any picts incoming shortly? :thumbsup
Has thanked: 1240 times
Have thanks: 1099 times
Postby Seven64 » 14 Mar 2012, 23:55
on their website there is a small pic which shows its an IC buffer.
Seven64
Have thanks: 7 times
Postby Jack Deville » 15 Mar 2012, 00:16
So many high value resistors!!
Why!? WHY!? WHY!?
Opamp followers are EE101 material.
Hopefully, the excessive use of excessively high value resistors are being used as simple pulldowns, and one of the 0.1uF caps is being used as a power supply decoupling cap, but I suspect this is not the case. We'll never know without a trace side shot.
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
Jack Deville
Have thanks: 89 times
Postby Neeno » 07 Nov 2012, 17:15
Hey guys !
Has anyone a gut-shot of this buffer ?
Is it based around a BS170 or a TL07x ?
Thank you in advance !
Neeno
Re: JHS Little Black Buffer  [traced]
Postby POTL » 18 Jul 2017, 07:05
Schematic is here 8)
For this message the author POTL has received thanks:
modman (22 Jul 2017, 21:11)
POTL
Has thanked: 65 times
Have thanks: 60 times
Users browsing this forum: Frank_NH, hozy31, Seiche, temol, wilfman and 15 guests
