Zvex - Jonny Octave [traced]
hum ... I think the second circuit is wired in parallel.
For the transformer, there are 45€ shipping cost to France .
For this reason, I ask somebody to sell me two of this transformer, because I don't want to buy they with shipping cost so high !
Regards,
Guillaume
Regards,
Guillaume
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 277 times
if you can find some old transistor radio....you can find trafo in it!!!! it was connected to drive a speaker..........or try to wind your own
and YES pcb's are connected in series............IT WAS MADE FROM SCHEMATIC (not tested)
nobody post gutshots......schem was drown based on text.........and Zwex took it from the Brasss master schem.............modified it
- puppiesonacid
would the radio shack audio tranny work too? i figure why not right? as long as you have something to provide the rectification? idk... not really an engineer ya know haha.
puppiesonacid
puppiesonacid
Hum .... I don't understand why you show me an transformer who it is'nt an TL002. I ask this question, because I know that the transformer have got different Impedance ( Input and Output ). I too a question about this transformer.
Can I buy two of this transformer, and ta change the value of the impedance with an differant metal wire. However, I don't know how must be the value for the pedal ( the schematic don't tell anything about it ).
Guillaume
Guillaume
The TL002 is specced as a 10K-2KCT driver, if you check the LT44 it is 20K-1KCT driver, and in a crappy (read less than critical) octave cct should work. The other trafo's are mini output trafo's (12KCT-32R and 1KCT-8R).
Ok I see ... On the like site I've seen this transformer who have an 2KCT output. However, it's an 2KCT, not an 2K, so I don't know if it will work.
Guillaume
edit : this one should correspond too, but it has an high input impedance (20k).
Well, what of this two transformer should work ?
Guillaume
Ok, stop, breathe.
The second link you gave is the same transformer as the LT44 at Maplin.
The first link is the same as the Mouser trafo. The CT means Centre Tap, but you dont have to use it, just leave the centre tap on the primary disconnected. You need the CT on the secondary, as ground reference for rectification.
But this is assuming that the T002 is what is actually used in the JO.
- WhiteKeyHole
Yeah, it's important to note that I drew this schematic based on information provided in this thread and it is untested. I have built something similar to it, but in my version I omitted the "driver" (2N3392 and support components) in the "modulator driver" stage. The 42TL002 is the transformer said to be used by the post I got most of the information from. I used 42TM022 with acceptable results.borislavgajic wrote:if you can find some old transistor radio....you can find trafo in it!!!! it was connected to drive a speaker..........or try to wind your own
Hi all,
Torchy, I know how to Breathe, and I was not exitd when I written my last message
So, ty a lot for your information about the transformers.
WhiteKeyHole, Why did u say that this layout " is untested" ? I believed u've blid one of this pedal from your schematic ...
Guillaume
Guillaume
I meant the links were getting confusing lol.
I just breadboarded a JO using my own schem but the same topology, and used the Maplins trafos. Needs a couple changes but sounding decent so far.
- borislavgajic
- Opamp Operator
and what would that changes be???
please could You let us see (hear) ????:thumbsup
greetings
greetings
- borislavgajic
- Opamp Operator
and still no guts???nobody............
this thread was my first......
- borislavgajic
- Opamp Operator
does someone have pictures of original J.O. ..........?
thanks
b.
thanks
b.
- borislavgajic
- Opamp Operator
what about now???....nobodyborislavgajic wrote:does someone have pictures of original J.O. ..........?
thanks
b.
p.s.
this was mine firs post in this forum.....so I am emotionall
- borislavgajic
- Opamp Operator
borislavgajic wrote:can somebodu post guts pictures from both sides of JONNY's pcb?????
please,and thank you
yes?no?
thank you
borislav
- borislavgajic
- Opamp Operator
borislavgajic wrote:borislavgajic wrote:can somebodu post guts pictures from both sides of JONNY's pcb?????
yes?no?
thank you
borislav
am I anoying? with two n-s.......
not giving up.....yet
I've been looking this pedal for years. The pedal on the demos sounded amazing and live sounds even better, it's really HUGE!
I did almost all the slow work! Please look at if I missed something because I will have the pedal for only a few days.
I leave the important photos here:
https://www.flickr.com/photos/149435924 ... 194349996/
Here is the complete photo album:
https://www.dropbox.com/sh/dwjwybt7q1jd ... b5NMa?dl=0
