Prescription Electronics - Experience Octave Fuzz
Re: Presciption Experience
Postby noelgrassy » 08 Aug 2009, 00:36
Are these those?
noelgrassy
Have thanks: 3 times
Re: Prescription Electronics - Experience Octave Fuzz
Postby iamadamb » 08 Aug 2009, 01:06
it was just two pictures of a schematic in blue and black.
but holy crow this is a board and wiring diagram!! :shock:
this is perfect!
if i wanted leds id have to put in 3dpt's or a millennium bypass huh?
p.s. if anyone has the justin philpotts schematic still i would love to see it also :D
thank you!
iamadamb
Postby rousejeremy » 08 Aug 2009, 04:31
FWIW I built the Original "Swell Circuit" and tested it out with a Fuzz Factory and an Ampeg Scrambler. Check it out here.
http://www.youtube.com/watch?v=2al4eJUecX8
For this message the author rousejeremy has received thanks:
Electric Albatross (26 May 2019, 15:41)
rousejeremy
Has thanked: 28 times
Have thanks: 25 times
Postby rousejeremy » 08 Aug 2009, 04:38
iamadamb wrote:it was just two pictures of a schematic in blue and black.
this is perfect!
thank you!
Here's a vero of the original Anthony Leo Fuzz that is used as the swell circuit.
rousejeremy
Postby Greg » 08 Aug 2009, 04:40
rousejeremy wrote:FWIW I built the Original "Swell Circuit" and tested it out with a Fuzz Factory and an Ampeg Scrambler. Check it out here.
Awesome.. especially with the Fuzz Factory.. thanks for the clip..
I'll have to add this to my long list of projects.
:thumbsup
Greg
Has thanked: 77 times
Have thanks: 195 times
Postby noelgrassy » 08 Aug 2009, 13:59
Here's the other part of the circuit;
noelgrassy
Postby rousejeremy » 28 Aug 2009, 18:58
And how about that switching? It's interesting how the swell only works when the Octave is engaged.
rousejeremy
Postby Solidhex » 14 Sep 2009, 08:09
I notice the Experience uses 1n4001 silicon diodes and all 100k pots instead of germanium diodes and 50k pots. From my memory the Experience had a lot more fuzz and sustain to it than any Foxx Tone Machines I've played through. I'll have to try it out.
-Brad
Solidhex
Has thanked: 10 times
Have thanks: 18 times
Postby aquataur » 28 Aug 2010, 23:07
Folks, I read the explanations, but I admit I don´t understand how this device is used.
I collect this has to be an integral part of another design rather than a series effect device.
How would you use this with an existing fuzz design?
thanks,
-helmut
aquataur
Have thanks: 20 times
Postby SpencerPedals » 29 Aug 2010, 04:33
Unless I'm missing the question due to gin intake, it is indeed used in series after your effect of choice. The previous clips of scrambler/fuzz factory illustrate this. I've been curious about the stacking and how it works well with over-the-top fuzzes but not some others. I've yet to breadboard it and get around to doing some firsthand things because the addiction pulls me in all sorts of directions and summer has made it too hot to move in any, but I'd suggest breadboarding it and sticking it after your fuzz of choice. Someday I'll do this as well. Someday.
SpencerPedals
Have thanks: 10 times
Postby aquataur » 29 Aug 2010, 10:56
Folks, I find several discrepancies in the schematics depicted here :shock:
Jeremy, the breadboard version you show here is not coincident with neither the original Anthony Leo circuit, nor with the Experience Pedal swell circuit (assumed this is correct...).
The 50k pot on the original connects between the emitters. The Exp. Pedal swell pot connects from the emitter of Q1 to the 680k resistor. Your version has the 50k pot between emitter of Q1 to base of Q2 according to the drawing.
Can you shed a little more light on this?
As I suspected, the circuit is not a stand-alone device. In the P.E. Experience Pedal it is an integral part of another device and they cleverly made it to steal away the bias of subsequent active components. This is akin to a tube-amp bias tremolo, except it is triggered by the signal itself.
Being a very basic circuit, it only works within limits as some folks noticed.
This circuit would need a wrapper around it to make it more reliable and versatile.
As a swell, (as some guys have mentioned rightfully in the other diy forum) it is lousy and not worth another thought. It might have some application as an "amp-on-the-verge-to-give-up sound" generator as somebody has mentioned here: http://www.thegearpage.net/board/archive/index.php/t-317030.html.
Listen to this guys Pete Cosey demo here: http://www.soundclick.com/bands/default.cfm?bandID=600160&content=music
He has the Pete Cosey sound to a T.
I listened to a youtube demo of the P.E. Exp Pedal and towards the end they demonstrate the swell sound. As I said, lousy as a swell, great for psychedelic effects. But you folks might instantly know of a better solution anyway :wink:.
have fun,
-helmut
aquataur
Postby celadine » 30 Aug 2010, 01:37
aquataur wrote:The 50k pot on the original connects between the emitters. The Exp. Pedal swell pot connects from the emitter of Q1 to the 680k resistor. Your version has the 50k pot between emitter of Q1 to base of Q2 according to the drawing.
Q1's collector is connected to Q2's base, so you could say the pot is connected to Q1's collector. This wouldn't be far from the Experience, with a tiny 470ohms between collector and pot. IMO, the effect was pretty noticible and interesting on the demo video, its a wonder there isn't more interest in this little circuit.
celadine
Has thanked: 16 times
Have thanks: 16 times
Postby celadine » 31 Aug 2010, 02:38
Here's a redraw, makes it clear its not a fuzz face derivative:
celadine
Postby aquataur » 31 Aug 2010, 09:14
No, not all two-transistor circuits are fuzz face descendants :mrgreen:
Thanks for the redraw.
This makes it even more obvious that the circuit won´t work with all devices after it.
I personally think the swell effect, although present, is lousy compared to (agreed more elaborate) other implementations.
But in extreme settings it seems to make the sound that the beforementioned guy was allegedly able to achieve.
I hesitated to sling one together because I suspect that it won´t work with any of the gear I have just as-is without further investigation.
I wonder if any of you guys who have the P.S. device or even the working excerpt to confirm this action.
take care,
-helmut
aquataur
Postby SpencerPedals » 02 Sep 2010, 01:26
aquataur wrote:In the P.E. Experience Pedal it is an integral part of another device and they cleverly made it to steal away the bias of subsequent active components
Are you saying that it's not used in series in the Experience? I'm confused by what you're referring to with respect to the bias of subsequent active components. From the experience layout it is just in series after the effect, but only when the octave is switched on. Unless I'm missing something obvious.
SpencerPedals
Postby aquataur » 03 Sep 2010, 09:40
The drawing of rousejeremy that shows the (complicated) switching is not quite clear to me. The switch symbols he uses are uncommon for me, so it is hard for me to interpret what is really going on.
It looks like the swell circuit is interacting with the other circuit.
What supports this thesis is the fact, that some people observed that the swell unit is not working with all successors.
It is standard engineering practise these days that all audio circuits are to be free of dc on their outputs.
So, as a precaution, all inputs and outputs are either coupled via a capacitor of suitable size or other measures are taken to maintain dc free coupling.
Virtually all inputs (except most traditional valve amp inputs) are capacitor coupled.
I do not see how a unit´s functioning can rely on the fact, that the successor´s input is not dc-isolated via capacitor.
And if they did, that would be a lousy implementation. But you never know...
Sometimes it is hard to tell from a distance, with several people´s inputs inbetween...
-helmut
aquataur
Postby aquataur » 10 Sep 2010, 22:09
Does anyone have the PCB layout for the wiring diagram and parts layout shown earlier?
The guys I contacted directly via PM did not respond.
thanks,
-helmut
aquataur
Postby noelgrassy » 11 Sep 2010, 00:47
Howdy aquataur [Wet Bull?],
Check yer PM.
Here's a picture of the component side with the wiring. The second one
is not my pedal though one can make out the leads more clearly. Compare this wiring
to the artwork I posted to verify it matches what's found in the PE Exp. box. :wink:
I'll need to extricate all the parts from mine to reveal the board and get yez a tracing view.
Noel Grassy.
PE pron w/ linguini system;
noelgrassy
Postby aquataur » 11 Sep 2010, 09:09
noelgrassy wrote:aquataur [Wet Bull?],
Kinda... aquarius + taurus.
An astrologer once said to me, this combination is akin to an astronaut ready for the launch, but all he has is a tractor. So I sit in full space suit on my tractor (mind: this is hot-rodded at least :applause: ) and plough the field :wink:
noelgrassy wrote:Check yer PM.
Done. Thanks for your time.
Since the original PCB artwork of that PCB seems lost and since this board does not seem verified I doubt wheter one should invest more time in it. For a second I considered making a new board but this appears futile in the presence of verified boards for the foxxtone. There are at least two of them around. It seems rather intelligent to make a little PCB for the swell circuit and that I will do. As soon as this is ready I will put it up here.
have fun,
--helmut
aquataur
Postby aquataur » 11 Sep 2010, 10:04
(Cannot modify my previous post so here is a new one...)
Noel, you could do us a sublime favour. I just noticed that the schematics that are around all have different pot values for the foxxtone part (and even the swell...).
Please have a look at the pot values and laws and let us know, thanks
have fun,
--helmut
aquataur
Users browsing this forum: fuzz guy and 4 guests
