Wampler - Tweed '57  [traced]
Wampler - Tweed '57
Postby indybeez » 28 May 2012, 17:54
I just picked up this pedal last week, and it sounds fantastic. Brian did an outstanding job on this pedal.
Anyway, I though I would post some pictures.....
I might try my hand at tracing this....I have never done it before.
thanks,
George
For this message the author indybeez has received thanks: 10
caspercody (31 May 2012, 16:35), HHR18 (28 May 2012, 18:22), Intripped (17 Feb 2015, 16:32), lolbou (28 May 2012, 19:37), lukatosh (29 May 2012, 00:46), Mbas974 (28 May 2012, 21:30), modman (03 Jun 2012, 15:54), Nocentelli (28 May 2012, 20:47), rocklander (30 May 2012, 01:47), sinner (28 May 2012, 19:39)
indybeez
Have thanks: 24 times
Re: Wampler Tweed '57 - Guts Shot
Postby Mbas974 » 28 May 2012, 21:30
Wow... this pedal souding totally amazing !
Thanks for the images.
Is it possible to have also the right side :-)
The parallel j201 remember me the Crancked AC... maye he started from that.
tx
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Postby indybeez » 28 May 2012, 21:40
Mbas974 wrote:Is it possible to have also the right side :-)
Let me know what exactly you want a picture of, and I will try to zoom in.
thanks,
George
indybeez
Postby indybeez » 28 May 2012, 22:19
Oh....I just looked at this post on my iPad, and see the bigger photos are cut in half. I will repost shortly.
indybeez
Postby sinner » 28 May 2012, 22:32
indybeez wrote:Oh....I just looked at this post on my iPad, and see the bigger photos are cut in half. I will repost shortly.
They're fine bro, but uploading them (attached to the post) is better idea
Has thanked: 1240 times
Have thanks: 1100 times
Postby lukatosh » 28 May 2012, 22:43
we need photos of traces under the potentiometers, photos of capacitor values...everything always needed :)
thanks so much!
lukatosh
Has thanked: 33 times
Have thanks: 180 times
Postby indybeez » 28 May 2012, 23:57
I didn't unsolder the pots...I could just bend them out of the way. I did have to unsolder the LED in order to see behind the middle pot.
Here you go...enjoy.
The last photo is a composite using my pitiful photoshop skills. You can see the whole solder side, except for beneath the toggle switch.
For this message the author indybeez has received thanks: 2
lukatosh (29 May 2012, 00:46), Mbas974 (29 May 2012, 16:44)
indybeez
Postby lukatosh » 29 May 2012, 00:39
wow!, thanks man!
could you take a picture or take note about the capacitors values?
thanks so much!
lukatosh
Postby grrrunge » 29 May 2012, 13:52
Piggybacked J201's :?: Interesting...
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby Mbas974 » 29 May 2012, 16:47
Excellent !
Could be possible some picture of front part also ?
as said above
nice to have red caps value too !!
Many thanks in advance
Mbas974
Postby Mbas974 » 29 May 2012, 17:01
I just noticed that downloading the picture these are complete, not like seems on the forum.
So no more pictures are required. discard previous request same subject.
There is one IC on the top right side, diode/optocoupler... wha else can you tell us more about it ??
Red cap values are required indeed...
:thumbsup
Mbas974
Postby grrrunge » 29 May 2012, 18:16
The print on the enclosure says "Vintage American Tone Structure", but the pot values are a perfect match for a scaled marshall tonestack :hmmm:
grrrunge
Postby alexradium » 29 May 2012, 18:58
grrrunge wrote:The print on the enclosure says "Vintage American Tone Structure", but the pot values are a perfect match for a scaled marshall tonestack :hmmm:
the tweed 59 bassman is the father of all early Marshalls,so yes,you can call it vintage american...
alexradium
Has thanked: 63 times
Have thanks: 65 times
Postby grrrunge » 29 May 2012, 19:56
Obviously, amp history isn't my strongest feature :P I just dug out Duncans tone stack calculator, and compared the gut shots pot values with the standard models in DTSC
grrrunge
Postby caspercody » 29 May 2012, 21:09
Hope this helps to get the schematic started. The straight lines represent resistors. The rectangle's, and circle's represent capacitors. The elipse's represent J201.
caspercody
Has thanked: 31 times
Have thanks: 49 times
Postby caspercody » 29 May 2012, 21:11
Here is a reverse image to go along with my previous post to start the schematic.
For this message the author caspercody has received thanks:
modman (11 Apr 2015, 09:59)
caspercody
Postby Mbas974 » 29 May 2012, 21:14
Hi I traced bottom and top frame... the yellow point still uncertain about.
Can you help tracing yellow point ? :hmmm:
I'm goin to put res values stay tuned :-) :horsey:
sorry for attachment but I do not now how to post here images fro my PC :slap:
Mbas974
Postby Mbas974 » 29 May 2012, 21:18
[img]C:\Documents%20and%20Settings\Administrator\Desktop\Tweed57.png[/img]
For this message the author Mbas974 has received thanks: 2
indybeez (29 May 2012, 22:49), modman (11 Apr 2015, 09:59)
Mbas974
Postby Mbas974 » 29 May 2012, 22:24
it's too late for the resistor coding..... need the sun light :-)) (tomorrow will have less error possibility)
Attached so far what I've done... hope it help
Still missing :
1) Electrolitics caps value
2) Polyfilm red caps value
3) IC on the top left position name or value
4) Trans should be all J201 (pls confirm)
Indibeez, you are our eyes, pls let us see the light !
good night dyers!!!
Mbas974
Postby indybeez » 29 May 2012, 23:47
I have added the markings on the orange caps to the picture....but didn't look up the values. I did add the values of the Electrolytic caps. The transistors are all J201 (with the addition markings of F BB25). The other chip in question is marked IRFD9024, with AE, and R06K below.
Also, though not easily seen on the photo, it appears that the number three lug of the A100K bass pot is soldered to the same solder-side trace as the number two lug.
What else do you need?
thanks,
indybeez
Next
Users browsing this forum: cctsim and 15 guests
cron
