Wampler - Tweed '57 [traced]
- Mbas974
@askwho69, your point is right !
I really thing output cap is 1uF not 100nF. It should be equal value than c12.
Thanks for prompting it.
@ sinner what is filtering you post ? is what you see... or variation suggested ?
- roberttomasz
..sinner ,cześć tomek-Szczecin.Całość jest ok.Jedynie dla przeanalizowania schematu i pcb brakuje mi połączeń w przełączniku/ mini switch.Coś nie tak z ścieżkami i ich pałączeń .Reszta wygląda ok.
- Mbas974
Last schematic with updates.
Updates :
- output cap 1uF
- Filter section (before last stage) as spotted by our great mentor (thanks again Sir !!)
Hey sinner... do you see the difference now ?
sarcasm detector --> status: ON ( ciao Intripped )
Pls double check the filtering update ( lukatosh or anyone else ) so we can say final to this release.
Updates :
- output cap 1uF
- Tweed57.png (10.33 KiB) Viewed 4410 times
- lukatosh
Oh Come On guys! That's wrong... check the picture on page two..
the signal goes through 1uf Cap, the through 10k resistor and then arrives where 1.5 cap and two 10k resistors join together
please, correct me if i'm worng...
@ Mbas974: sinner was being sarcastic with his filtering...
bryan says that something is wrong with filtering... lets find it out!
- Intripped
this is my try on REing
there are some minor differences with the previous schemes (some resistors values, one cap missing)
i've followed Mbas974' suggestion about the traces under the two 10K resistor in the filtering section - i agree with this interpretation
one last note: are we 100% sure about caps' values? - expecially the big cubic one indicated as 104 (100n). it really looks like a 1uF
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
Turn your sense of humor status on I'm never sarcastic, sarcasm is low kind of humor for frustrated paranoids.Mbas974 wrote: Hey sinner... do you see the difference now ?
No offense was intended then and now
- Mbas974
I've chechked res code/colours... so
OK for 10K resistances in place 12K
Thanks for C9 (just missing!!)
Note for power protection :
I've checked the cheap power protection using 3904 and 3906, it's not good... , it reduce by 0,4V the power.
I've used the Mosfet P-Channel and it is ok 9V no loss ! ( http://www.geofex.com/Article_Folders/m ... switch.htm )
That's all for this pedal!!! Nice build to everyone.
- Intripped
other different values are:Mbas974 wrote:I've chechked res code/colours... so
res just before the volume pot is 100K
res used in the supply circuit, close to the transistor, should be 1 Ohm 1%
sorry for the cap question; i totally missed the conclusion - output cap is 1uF and not 100n (let's say it one more time)
...I like sarcasm... Sinner please don't give up!
- lukatosh
- IvIark
Knock yourselves out!
- IvIark
Oops, I noticed I had the output from Q6 from the drain and not the source, the layout above has been corrected.
- lukatosh
Hey guys!
hello once again!
i have a question... hope you can help me! ,
is there a way to increase overall bass of this pedal?... or maybe add a bass bost switch?
eemmm... yeah i know that the pedal was made to sound as it sounds but... i would like to increase those frecuencies a little bit without getting those kind of fuzzy sounds that you can see on some youtube videos
Excuse my bad english... hope you can understand!
Thanks so much!!
hello once again!
Thanks so much!!
- grrrunge
+1 !HHR18 wrote:Would it be possible to post the voltages of all the J201s? Since Brian matches all J201s before putting them into the circuit!
Matching JFET's made a huge difference in my plexidrive...
