Wampler Sovereign Distortion  [traced]
Postby lukatosh » 29 Jun 2012, 10:46
this was supposed to be posted here... sorry :( ...
just couldn't delete the topic posted in modern effects
anyway...have you seen this?
Link
it sounds just great!
from wampler website:
It has a mid control that is admittedly borrowed from other great Wampler pedals like The Pinnacle, but this one is refined, less fussy and instantly gratifying over the full range of its sweep
Check this out...From youtube...5 transistors (maybe j20, used often), power mosfet for polarity protection, and a JRC4580D... no onboard pots names/values :cry:
lukatosh
Has thanked: 33 times
Have thanks: 180 times
Re: Wampler Sovereign Distortion
Postby jymaze » 29 Jun 2012, 14:22
It looks like a BMP tone stack with a variable mid pot (see MI Audio Tube-Zone for an example).
jymaze
Has thanked: 87 times
Have thanks: 161 times
Postby jymaze » 29 Jun 2012, 16:31
So my best guess is:
- 4 cascaded JFET gain stages, the 5th being a buffer before the tone stack(see Dr Boogey)
- a BMP tone stack with variable mid pot (see Tube Zone)
- an output opamp buffer to recover the loss of amplitude (see Pinnacle II LE)
- the bright switch would add a bright cap somewhere around the gain pot (think Marshall amp)
- the boost switch changes the voltage dividing network between stage 2 and 3 (probably)
I have been thinking about making a Dr Boogey with a BMP tone stack with mid control for a long time. It seems I was not the only one.
jymaze
Postby culturejam » 29 Jun 2012, 17:17
Is that an opto isolator IC at the top of the board (4 pins)?
culturejam
Has thanked: 463 times
Have thanks: 582 times
Postby lukatosh » 29 Jun 2012, 17:22
from wampler tweed 57 topic...
Actually it is the polarity protection. Read this article by R. G. Keen. The advantage of this method is the very low voltage loss across it, as opposed to usual series diode which eats around 0.6V.
lukatosh
Postby okgb » 30 Jun 2012, 01:20
What does the name suggest ? ??
okgb
Has thanked: 198 times
Have thanks: 41 times
Postby Ice-9 » 05 Jul 2012, 13:38
culturejam wrote:Is that an opto isolator IC at the top of the board (4 pins)?
It's more likely a fet for polarity protection (diode next to it as well.)
OOps someone already said this. :slap:
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby indyguitarist » 16 Jul 2012, 08:12
jymaze wrote:So my best guess is:
nope! ;)
indyguitarist
Postby jymaze » 16 Jul 2012, 13:38
Thank you for the dream-crushing Mr Wampler... :wink:
Maybe mu-amps then...
jymaze
Postby lukatosh » 25 Jul 2012, 23:27
up!
lukatosh
Postby mrkaploca » 21 Dec 2012, 19:32
jymaze wrote:Maybe mu-amps then...
Most certainly, judging by the amount of gain available...
mrkaploca
Has thanked: 15 times
Have thanks: 12 times
Postby thn.technik » 11 Feb 2013, 16:03
any news? somebody have this pedal? maybe some pics for trace ;-)
thn.technik
Have thanks: 43 times
Postby Mrdorbe » 24 Nov 2013, 22:20
i'm really interested in building one on my own.. did anyone trace this circuit or made a layout? thank you.
Mrdorbe
Postby Nacho5 » 27 Jul 2015, 02:38
I'm very interested in build one. Did anyone trace this circuit or made a layout? thank you.
Nacho5
Have thanks: 5 times
Postby modman » 28 Jul 2015, 18:58
this:
Has thanked: 3113 times
Have thanks: 563 times
Postby roseblood11 » 27 Aug 2015, 07:10
It would be really interesting to see this pedal retraced!
It started with a limited run for musiciansfriend, but it's easily available now.
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby Bloodman » 21 Jul 2016, 04:54
The monolithic circuit and parameters of the sovereign are very similar with the pinnacle
Bloodman
Has thanked: 13 times
Have thanks: 34 times
Postby MoonWatcher » 24 Jul 2016, 16:36
Bloodman wrote:The monolithic circuit and parameters of the sovereign are very similar with the pinnacle
Indeed. It seems that there are a bit of similarities, in particular, with it and the Pinnacle LE. The latter was traced out in what I think was a Pinnacle II thread. So I went and dropped in the capacitor values for the LE, and then looked at the Sovereign. I tried to label what I thought might be the cap equivalents.
I figured that until someone has one to trace, that the next step would be figuring out the resistor values, and then they could be cross-referenced to the Pinnacle as well.
This seemed like as good a place as any to start. I hope it helps.
For this message the author MoonWatcher has received thanks:
modman (27 Sep 2017, 08:16)
MoonWatcher
Has thanked: 43 times
Have thanks: 63 times
Postby Bloodman » 25 Jul 2016, 10:31
I have already traced this pedal
Bloodman
Postby Ice-9 » 25 Jul 2016, 22:57
Smashing, I couldn't be happier for you. Thanks for sharing.
Ice-9
Next
Users browsing this forum: fredmerts, POTL and 19 guests
