Bearfoot - Sparkling Yellow Overdrive 2 (SYOD 2)  [traced]
TheLemon
Been thanked: 23 times
Post by TheLemon »
Had a buddy in Cali send me some pics. Can't see the resistor values perfectly, but he gave me the cap values and basically it's a tweaked Dyna Red.
Reason: modified header
TheLemon
Post by TheLemon »
Tough crowd. I'm guessing the "M" knob is a A1M like used in the Sky Blue's "z" or resonance control, or its like a B5k used in the clipping section between the 220N to change where the distortion lies in the mids.
IvIark
Has thanked: 562 times
Been thanked: 586 times
Post by IvIark »
Thanks for the scheme, here's a vero layout if anyone wants to give it a try. Based on my Dyna Red layout which is verified so should be good to go.
[Incomplete]
IvIark
Post by IvIark »
TheLemon wrote:Tough crowd. I'm guessing the "M" knob is a A1M like used in the Sky Blue's "z" or resonance control, or its like a B5k used in the clipping section between the 220N to change where the distortion lies in the mids.
Oops, didn't realise it was incomplete, I suppose I should at least look at the front of one before doing a layout! :lol:
I'll check out the vids later to see what the M knob does
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
aaand another one... :lol:
TheLemon
Post by TheLemon »
Heres some ideas from the actual website on the M knob -
"It was 3 knobs but it also had the lowmids control attached to the drive knob in reverse - so you got a beefier clean/low dirt sound and it tightened up for higher dirt settings. The new M control does all of this but also lets you use it in other ways to push the DRD into fuzzier territory or use it as an EQ for cleaner tones - a little mids can go a long way ...... also has the red sparkle paint job and gold lettering."
Has thanked: 1675 times
Been thanked: 1360 times
Post by Manfred »
I guess that the "M"(Mid) knob potentiometer replaces the 1kOhm resistor which is shown in red marked area in the schematic detail.
TheLemon
Post by TheLemon »
Yeah guys, sorry for the rough pics, he said his camera could not capture the details. I'm sure your right about the "M" pot replacing the resistor circled in red.
Post by Manfred »
In comperation with other BF FX schematics, the "M"-knob circuit could be realized in a uniform manner.
Quietus
Has thanked: 54 times
Been thanked: 16 times
Post by Quietus »
hi, attached is the vero i just did based on the schematics by both our friend TheLemon and Manfred if anyone's interested. i omitted the 1K resistor that was circled in red, and i referred to Mark's DRD vero layout throughout. i've checked it against the schematic, and i'm fairly confident that it's correct. but could any of you be so kind as to check it against the schematic again just to make sure? :wink: thanks all!
Post by Manfred »
Hi Quietus,
thanks for modifying the layout.
please remain the seriell circuit containig the 1kOhms resistor and the the 200nF capacitor,
because the added feedback circuit which contains the 50kOhm Potentiometer and the other parts, are in parallel to it.
In the "Honey Bee" and in the "Modell H" the FB circuit is wired in the same manner.
Quietus
Post by Quietus »
okay, Manfred. noted. so, here you go guys! :horsey:
Post by Manfred »
I further difference to the Honey Bee and the Modell H schematic is the FET output circuit.
On the 3 knob SYO schematic is a source follower circuit is shown, the gain is about one.
On the HB and MH the output stage schematic is a source based circuit, the gain is about 2.5 .
It seems to be that a higher gain along with the feed back circuitry is needed.
Is there anyone who knows futher details?
muhd85
Post by muhd85 »
layout above is working for me. thanks everyone :)
Seiche
Post by Seiche »
modified header to facilitate searching this topic (the pedal's name is "Sparkling Yellow Overdrive 2", not "Sparklin' OSYODv2" or something). :thumbsup
world vs venkman
Post by world vs venkman »
Interesting--thanks!
If I gave the M control a shot in my Dyna Red, would it be advisable to change the values of the caps and resistors associated with it, or would it be fine as-is? It wouldn't be hard to lift one leg of the 1k resistor and add this in (just some creative wiring to fit it).
lukatosh
Has thanked: 33 times
Been thanked: 186 times
Post by lukatosh »
yes! :D
mlp-mx6
Post by mlp-mx6 »
Has anyone nailed down the differences between the SYOD 1 and 2? (or the switched components in the 3?)
Thanks,
Michael
HamishR
Been thanked: 46 times
Post by HamishR »
Just built this using Muhammad's layout - thanks Muhammad! It's sounding great, but I did reverse M1 and M2 so that turning the pot up increases mids rather than decreasing them.
The other issue I have is that I'm getting oscillation when M is on full. When M is on full I'm reading around 3ohms between C14 and ground. If I turn M down just a hair so I'm reading just over 4ohms between C14 and ground the oscillation stops. What could be causing this?
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
I'd really like to see, what's different in the version one ("SYOD1") and in the new SYOD3, which combines both voicings of the older versions.
