Noah's Ark - Distortion M
Re: Noah's Ark - Distortion M
Postby SPeter » 10 Dec 2009, 16:50
himister wrote:Well done bobo. :applause: May I ask what software you have used for this one?
:wink:
:applause:
!+! Nicely done!
:D
SPeter
Have thanks: 76 times
Postby bobo » 10 Dec 2009, 16:52
Illustrator
bobo
Postby gainiac » 03 Mar 2019, 19:00
Two mistakes with this layout, first the 47k resistor is actually a 4k7 and the connection to pin 5 of the opamp was all screwed up. I've gone ahead and revised the pcb and "layout" (this is not my original work btw) with 2 pads so you'll just need to put a wire jumper between them. Otherwise this is verified and sounds rather nice. FYI there's a vero layout on tagboardeffects but note that the input cap is mismarked as 220n, should be 22n per the schematic.
gainiac
Have thanks: 6 times
Postby gainiac » 06 Mar 2019, 00:18
My apologies, I missed one more change that needs to be made, luckily it's offboard so the revised layout is still correct. In order for the volume pot to work you'll need to add a wire from lug 1 connecting to ground, that's all.
gainiac
Postby Manfred » 05 Apr 2019, 09:52
I created the PCB layout without ground aera derived from the layouts of the previous posts.
The gound ground connection to the out potentiometer an the 4700pF capacitor in parallel to it have been omitted.
The capacitor can be soldered directly to the out potentiometer lugs, also the ground connection.
The clipping diodes are unmarked.
There are two versions one with the reverse polarity protection diode connected to ground
the other one with the diode in seriell.
I don't no which version is applied in the original pedal.
Ready to print PDF-files:
NoahsArcProtectDiodeToGroundComponentSide.pdf
NoahsArcProtectDiodeToGroundSolderSide.pdf
NoahsArcProtectDiodeToGroundSolderSideMirrored.pdf
NoahsArcProtectDiodeSeriellComponentSide.pdf
NoahsArcProtectDiodeSeriellSolderSide.pdf
NoahsArcProtectDiodeSeriellSolderSideMirrored.pdf
SprintLayout6-file:
NoahsArc.zip
287m (05 Apr 2019, 12:34), gainiac (05 Apr 2019, 18:54), sixthfloor (05 Apr 2019, 13:30)
Has thanked: 1051 times
Have thanks: 636 times
Postby gainiac » 05 Apr 2019, 18:58
This pedal is one of the best Marshall-in-a-box circuits I've come across, thanks for the professional looking layouts, very nice work you've done here.
gainiac
Users browsing this forum: deltafred, Güero 2.0, hiroyoshi miyachi, Iconnu, rocket512, ryou and 28 guests
