Zvex - Fuzz Factory  [traced]
Postby Goop_buster » 25 Jul 2007, 00:01
analogguru wrote:
in one pic I can read "2N????".
You need glasses :wink: It´s a 2N 404(A)
Someone in the "stomp business" is selling 2N404A...
http://www.muzique.com/news/?p=31
what a coincidence :D .
Goop_buster
Have thanks: 5 times
Postby madbean » 25 Jul 2007, 15:14
This was one of my favorite builds! Sometimes I just look at this pedal for a while :lol:
http://www.mypicshare.com/utcpp863pic.html
madbean
Postby grolschie » 25 Jul 2007, 23:04
That is awesome! Check out its majesty!
madbean wrote:This was one of my favorite builds! Sometimes I just look at this pedal for a while :lol:
"Trogdor! Burninating the countryside! Burninating the peasants!"
To fill ya'll in:
http://www.homestarrunner.com/sbemail58.html
http://en.wikipedia.org/wiki/Trogdor
More recommended viewing:
http://www.homestarrunner.com/sbemail16.html
http://www.homestarrunner.com/sbemail36.html
grolschie
Postby soulsonic » 26 Jul 2007, 02:29
If Z got the AC128s "custom made" for him, then why is he using the 404s? The pedals with the 404s looked more recent than the one with the 128s. More BS for sure.... the only thing "custom" was the custom stamp he had made to put his name on the side of the can.
Muzique's prices on transistors are outrageous. Jeesh, they're not even tested. I'm not going to ever pay $14 for a PAIR of transistors that aren't tested. At least the overpriced trannys at Small Bear are tested first!
Has thanked: 56 times
Have thanks: 280 times
Postby invictus » 26 Jul 2007, 08:09
"im the master of my fate, im the captain of my soul... " -invictus
invictus
Postby soulsonic » 26 Jul 2007, 08:25
nice
Postby invictus » 26 Jul 2007, 09:38
look at those large heatsinks... :)
invictus
Postby soulsonic » 26 Jul 2007, 09:54
Yeah, with enough juice from the power supply, you could drive a speaker with those.
Postby modman » 04 Aug 2007, 11:26
http://f.defaut.free.fr/?q=node/4
Another IP Police victim??
28 avril, 2005 - 20:41 — fx
Salut a tous Pour des raisons juridiques, j'ai décidé de supprimer le tutorial de la fuzz factory. Je resterai disponible pour des questions concernant son montage, mais je ne fournirai plus les schémas ni le tutorial. Merci de votre compréhension ...
translation: hi all. For legal reasons I decided to remove the fuzz factory tutorial. I'm still prepared to remain available for question on building it, but I will no longer provide the schematic nor the tutorial. Thanks for you understanding.
Maybe the French tutorial still online is the same tutorial rehosted to another url. Anyway I wrote the guy some time ago (in French) but still no reply.
Has thanked: 3240 times
Have thanks: 607 times
Postby bradb » 05 Aug 2007, 06:45
Hey guys,
I own a fuzz factory and i'm trying to build another.
I soldered it all up using igloo's layout (thanks man!) and I'm using some AC128 / 01s (with the big heat sinks) anyway I bought 15 from a guy and some have numbers like 83 and 91 written on them, i'm assuming that that is hfes.
The bottom line is that its not really working nicely like my original, i think i need to swap out some of these transistors and find a good pair.
is the collector defined by the dent? i read that somewhere
what hfe are you guys using successfully in the fuzz factory?
bradb
Postby Igloo » 05 Aug 2007, 08:34
Here's an image showing the AC128 pinouts
http://forum.musikding.de/gallery/displayimage.php?pos=-1082
You set up the Ge's as you would a fuzz face, so you need HFEs of ~ 70-85 and 110-140.
Of course it is vital to use low leakage devices and test them.
GEO has the most useful method for this.
Igloo
Have thanks: 2 times
Postby bradb » 05 Aug 2007, 15:47
excellent, thank you!
is this the GEO method:
http://www.geofex.com/Article_Folders/f ... fftech.htm
bradb
Postby Igloo » 05 Aug 2007, 16:07
Yes, scroll down for the test procedure :wink:
Igloo
Postby Gila_Crisis » 05 Aug 2007, 23:07
Igloo wrote:You set up the Ge's as you would a fuzz face, so you need HFEs of ~ 70-85 and 110-140.
i've done some experiments about this and i founded out it work best with a very low Hfe for Q1 e an high value for Q2. so the controll works the best to me and the whole isn't so noisy.
actually i couldn't find AC128 so i used AC157
Gila_Crisis
Have thanks: 72 times
Postby modman » 06 Aug 2007, 00:59
Attention, what is mostly Q1 and Q2 in a Fuzz Face, is here Q2 and Q3 in most schematics for the Fuzz Factory Q1 being the silicon NPN.
Are you saying the first GE should be higher hfe than the second GE?
Postby Igloo » 06 Aug 2007, 03:16
Hey ho, attention etc.
I have added a necessary trace cut between c2 and c4 to the FF layout.
The current image is updated!
Igloo
Postby Gila_Crisis » 06 Aug 2007, 06:14
modman wrote:Are you saying the first GE should be higher hfe than the second GE?
the first GE lower and the second higher :wink:
i.e. in mine the first has an Hfe of 25 and the second 130
Gila_Crisis
Postby Igloo » 06 Aug 2007, 11:36
A good choice to test...or even to build is to use transistors
Mpsa2369a and/or BD139. These silicon transistors have Hfes ranging between 40 and 120 and are reported to sound outstanding as replacements for Ge's in Fuzzface circuits. A very good idea before inserting those precious
germs and debugging.
Check here Phillip Robinson's Axis Face
They are cheap and readily available.
Igloo
Postby modman » 06 Aug 2007, 23:34
I completed the Fuzz Factory tonight from Igloo's veroboard, which is hereby verified as working. It's a fast and easy build, on a minimal pieces of stripboard. I used my last 2N3904 NPN Si (Hfe 190) + two 2N404A's both Hfe 125)
2N404's picture
That worked alright, apart from RF radio stations at max gain. You have to find the right pot settings before you start switching transitors, as this provides the bias for the GE part of the circuit. Finding a preset was made a lot easier by making notes on the following youtube video:
http://youtube.com/watch?v=tf-Zck7YURs
eg: Fuzz Face =
gate 0
comp 0
drive 6 (=1 o'clock)
stab 10 (=5 o'clock)
Certain end of taper settings don't seem to work if like said earlier Q2 Ge to too high.
Had slightly better results using AC128 hfe 85 + 2N404a hfe 125 for Q2 and Q1. Still not all setting gave sound, but I did succeed to tune the oscillations with each control, so it's pretty much ok
Fuzz Factory Oscillation Test youtube vid
Using OC107 hfe95 or AC126 hfe105 gave me more RF interference, but this might be due to long wires and breadboarded pots.
Will try out some more transistors tomorrow.
Postby modman » 06 Aug 2007, 23:35
eg: Fuzz Face =
gate 0
comp 0
Using OC107 hfe95 or AC126 hfe105 gave me more RF interference, but this might be due to [urlhttp://i20.photobucket.com/albums/b230/zjokka/Fuzz%20Farm/DSCN4012.jpg]long wires and breadboarded pot[/url]s.
Users browsing this forum: jt, lietuvis, ratzl and 10 guests
