Alairex - H.A.L.O. Overdrive [traced]
- LaceSensor
Nice pictures
Thought this sounded pretty nice actually, justifying the amount of shit in there!
From looking at the solder side, I'd say the 16pin IC in the middle is a CD4049UB. pins 13 and 16 are free...
Another guess: It's for the saturation mode.
I'm using capacitors to replace my guitar effects and give more clarity to the sound.
- atreidesheir
Big ups Saruman!
Every time you post it is juicy.
Incredible amount going on for an od.
- atreidesheir
15 transistors
5 integrated circuits (counting the double)
and 6 diode sets (not counting the singles - i am guessing some assymmetrical pairs also)
that is really intricate for what it does.
If it was lovepedal, I would say maybe 5 electra distortions in series with 2 or 3 landgraff tubescreamers with "clipping options"
- Lucifer
And here it is - the LP Cooling system for nuclear fission plants.
- honkatron.jpg (15.05 KiB) Viewed 4076 times
Original or not, this one sounds killer in the demos.
Complexity -wise, it does rival mr Tripp's designs IMO.
Pretty expensive too!
Chuck Schuldiner said:
"Let the Metal flow"
- Ice-9
- Degoop Doctor
He's went to a lot of trouble even grinding of the value of the box caps .
- bajaman
- Has thanked: 595 times
- Been thanked: 2058 times
whoa
Is that a three layer board - looks like yet another tubescreamer rat combo with a speaker simulator and baxandall three band eq
would be interesting to see the filter values and interesting input buffer stage
"why use a 12A*7 tube when a dozen op amps will do the job just as well" quote for the day
- bajaman
Thanks to Saruman for the values - here is the really interesting bit - the post clipping filter response after the clipping stage and up to the master volume controls.
The red curve shows the input (normalized for a flat response)
The next curve (green) shows the response after the broad mid notch and gain recovery stage.
The blue curve shows the response after the first op amp low pass filter stage.
The purple curve shows the response after the second op amp low pass filter stage.
The yellow curve shows the response after the third emitter follower low pass filter stage.
AND the pink curve shows the response after the final broad notch filter and output buffer op amp stage.
The graph shows the response as the signal passes through each successive filter / gain stage.The red curve shows the input (normalized for a flat response)
- roseblood11
Did anybody ever try to make a pcb for the original circuit or for Sarumans stripped down version?
Sarumans version should be even small enough for veroboard in a 1590bb
