VFE Fiery Red Horse  [traced]
VFE Fiery Red Horse
Postby drbob1 » 04 Jan 2013, 03:52
Interesting overdrive with dual "diodes in the feedback loop" op amp gain stages, including one setting where both op amp stages have single diodes for very asymmetric clipping. Sounds kinda cool and especially cool that he describes the circuits and shows shadow masks and gut shots on the website: http://www.vfepedals.com/fiery-red-horse.html
Ballsy move, cool guy!
drbob1
Have thanks: 39 times
Re: VFE Fiery Red Horse
Postby coldcraft » 04 Jan 2013, 14:01
Quite possibly the best Muff-style Fuzz for the money! VFE pedals are a great buy!
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Postby mmolteratx » 05 Jan 2013, 09:09
What? There are no op amp stages in that pedal... It's very clearly a Muff.
mmolteratx
Has thanked: 103 times
Have thanks: 622 times
Postby roseblood11 » 05 Jan 2013, 11:56
Sure, he confirms that one the website.
Many interesting pedals there, just variations of well-known circuits, but very usefull ones.
I'd be interested in schematics for many of them, esp. the Distortion3 (based on DOD250/Distortion+) and the Pale Horse.
One thing I don't understand about the Pale Horse: I can't see any germanium or schottky diodes near the mosfets. How can the mosfet clipping work then? Or is it just clipping of the body diodes?
roseblood11
Has thanked: 332 times
Have thanks: 304 times
Postby B3ar » 05 Jan 2013, 18:10
roseblood11 wrote:One thing I don't understand about the Pale Horse: I can't see any germanium or schottky diodes near the mosfets. How can the mosfet clipping work then? Or is it just clipping of the body diodes?
You can wire mosfets like diodes. This is probably best noted in versions of the Fulltone OCD.
B3ar
Has thanked: 29 times
Have thanks: 4 times
Postby roseblood11 » 05 Jan 2013, 19:23
Sure, but all you'll hear is the clipping of the body diodes, which sounds almost identical to any other silicon diode...
roseblood11
Re: VFE Fiery Red Horse  [traced]
Postby VonRutter » 23 Dec 2014, 21:48
drbob1 wrote:Interesting overdrive with dual "diodes in the feedback loop" op amp gain stages, including one setting where both op amp stages have single diodes for very asymmetric clipping. Sounds kinda cool and especially cool that he describes the circuits and shows shadow masks and gut shots on the website: http://www.vfepedals.com/fiery-red-horse.html
Here is the schematic of v2 Fiery Red Horse for anyone who is interested. It's a BMP-style fuzz circuit, with variable power from 3V to 16V (or higher if you plug in 12V or 15V power supply), plus active tone stage and variable compression in the 2nd distortion stage. The charge pump circuit is built on a simple 555 timer chip.
Owner & designer at VFE Pedals. Please email me directly at peter@vfecustom.com if you need a quick response.
For this message the author VonRutter has received thanks: 8
D-Day (24 Dec 2014, 20:37), induction (24 Dec 2014, 12:40), IvIark (23 Dec 2014, 23:33), mmolteratx (23 Dec 2014, 22:20), Moonsun (24 Dec 2014, 11:57), rockola (28 Dec 2014, 15:15), tp801 (24 Dec 2014, 11:53), x-tn (26 Dec 2014, 15:41)
VonRutter
Have thanks: 97 times
Postby VonRutter » 23 Dec 2014, 22:17
roseblood11 wrote:I'd be interested in schematics for many of them, esp. the Distortion3 (based on DOD250/Distortion+) and the Pale Horse.
Here you go! FYI, the Pale Horse has a charge pump that is not pictured. so the power rails are +9V and -9V.
Pale Horse schematic:
Distortion3 schematic:
Each mosfet is configured in a way that puts the body diode & Vgs saturation in parallel (and reverse polarity). The two mosfets are then put in series (also in reverse polarity). The result is a very high clipping threshold - around 2.7V on average. That's why a charge pump was used, to give the op amp the headroom needed to drive this configuration. It also lets the Pale Horse get LOUD!
For this message the author VonRutter has received thanks: 12
D-Day (24 Dec 2014, 20:38), hasanova (11 Sep 2017, 19:50), induction (24 Dec 2014, 12:40), IvIark (23 Dec 2014, 23:33), jrod (26 May 2015, 03:12), mmolteratx (23 Dec 2014, 22:23), Moonsun (24 Dec 2014, 11:57), roseblood11 (05 Nov 2017, 09:51), tp801 (24 Dec 2014, 11:53), x-tn (26 Dec 2014, 15:43) and 2 more users
VonRutter
Postby D-Day » 24 Dec 2014, 20:37
Whoah thanks Peter!
D-Day
Mojo Book Buster
Has thanked: 109 times
Have thanks: 22 times
Postby hasanova » 06 Sep 2017, 15:51
Here's the schematic of VFE Fiery Red Horse v2, with no values...
hasanova
Postby roseblood11 » 10 Sep 2017, 10:57
Can anybody upload all the other schematics again, please?
roseblood11
Postby hasanova » 11 Sep 2017, 16:11
Pale Horse
hasanova
Postby hasanova » 11 Sep 2017, 16:13
Distortion3
hasanova
Postby hasanova » 11 Sep 2017, 22:29
If you're interested in more schematics check out this thread:
viewtopic.php?f=7&t=28265&p=264287
Or VFE website: support - discontinued pedals:
http://vfepedals.com/discontinued.html
hasanova
Users browsing this forum: Derreck, EmmG, plush and 3 guests
