Castledine Electronics - The Wizard  [traced]
Postby gilmour_pugliese » 03 Feb 2013, 10:44
Hi guys, surfing on Youtube I've seen this great pedal:
Link
Link
According to the website
http://www.wah-wah.co.uk/wizard.html
The Wizard is "A new distortion pedal, inspired by Tony Iommi's guitar sound on the early Black Sabbath albums. It is well known that he used a modified Rangemaster to drive his amps, so the same principle was used for The Wizard. The first gain stage is essentially a Rangemaster, using a germanium transistor, but tweaked for a full range boost. That drives a distortion circuit which has been designed to give something of the tone and feel of a Laney Supergroup amp. Obviously, there is no substitute for a full stack at volume, but The Wizard has a similar distortion character and responds well to picking dynamics".
The boost stage is pretty simple, but the drive section is a bit hard to decode... Could be a tube-to-JFET conversion from a Supergroup amp?
For this message the author gilmour_pugliese has received thanks: 2
modman (12 Dec 2017, 00:20), OH!STOMPBOX! (10 Apr 2015, 22:51)
gilmour_pugliese
Have thanks: 34 times
Re: Castledine Electronics - The Wizard
Postby Cub » 03 Feb 2013, 10:54
Stuart should have used a larger enclosure so there would be enough space for an indicator LED.
For this message the author Cub has received thanks: 4
Addy Bart (25 Apr 2017, 00:17), atreidesheir (04 Feb 2013, 20:11), Belanger88 (15 Dec 2017, 01:06), Dirk_Hendrik (03 Feb 2013, 12:30)
Cub
Has thanked: 74 times
Have thanks: 87 times
Postby gilmour_pugliese » 03 Feb 2013, 11:00
Cub wrote:Stuart should have used a larger enclosure so there would be enough space for an indicator LED.
Probably a LED on a dirt pedal is not so Rock 'n' Roll :popcorn:
gilmour_pugliese
Postby Nocentelli » 03 Feb 2013, 11:38
Just guessing here, but the five black trannies for the distortion section could be two muamp stages and a buffer on the output like some other "amp emulators" by catalinbread etc - I'm only going off the physical arrangment of first two transistors, and the fact the upper transistor in the first two muamp pairs appears to have the drain directly connected to +9v. I've just been messing with the C'bread CB30 vox box, so it's on my mind.
Nocentelli
Has thanked: 878 times
Have thanks: 844 times
Postby Bill_Mountain » 04 Feb 2013, 15:42
I love big boxes with no LED's.
I'm a bassist but I want to try this out.
Bill_Mountain
Has thanked: 45 times
Have thanks: 4 times
Postby Max Cohen » 04 Feb 2013, 17:25
+1 to bigass enclosures. Still this one is not big enough to fit my cock in to, and all we know this is what expensive pedals should be made for
Welcome to freestompboxes.org
We can help... But we won't ;-)
Turretboard.org now with forum
TB.org on Facebook
Max Cohen
Have thanks: 8 times
Postby Dirk_Hendrik » 04 Feb 2013, 19:34
:shock:
you manage to get your weener in through a quarter inch jackhole!? And tell us, is the input or output jack better. I's say the input since it's a stereo jack and provides more friction.
Ever wondered about rear end insertions? That's where "big ass" pedal really....
ah never mind...
For this message the author Dirk_Hendrik has received thanks:
roseblood11 (04 Feb 2013, 19:36)
Has thanked: 255 times
Have thanks: 1022 times
Postby atreidesheir » 04 Feb 2013, 20:13
:whappen: he prefers the dc jack.
atreidesheir
Has thanked: 452 times
Have thanks: 43 times
Postby Max Cohen » 04 Feb 2013, 22:44
I'm deeply sorry, I don't speak fuck-right-off-ish dialect of assholian
TB.org on Facebook
Max Cohen
Postby phibes » 04 Feb 2013, 22:53
Max, do you wear ESD protection?
Image Ken
phibes
Has thanked: 85 times
Have thanks: 186 times
Postby Max Cohen » 04 Feb 2013, 22:56
phibes wrote:Max, do you wear ESD protection?
Do they do anti ESD bags for macrodix?
TB.org on Facebook
Max Cohen
Postby geiristudio » 07 Feb 2013, 22:15
Common guys, we need this traced!
geiristudio
Have thanks: 21 times
Postby beedotman » 04 Mar 2013, 16:07
Anybody got better shots? I found only this one.
For this message the author beedotman has received thanks:
modman (09 Apr 2018, 20:39)
beedotman
Has thanked: 426 times
Have thanks: 403 times
Postby fakcior » 02 Nov 2013, 15:13
Couple of new gutshots:
For this message the author fakcior has received thanks: 2
beedotman (02 Nov 2013, 20:56), modman (09 Apr 2018, 20:39)
fakcior
Have thanks: 22 times
Postby andregarcia57 » 02 Nov 2013, 16:01
andregarcia57
Postby cdeschenes » 04 Nov 2013, 05:27
This is a cool sounding pedal from the videos. I was looking at the photos in Photoshop and trying to clean them up and blow them up. Here is what I have found so far.
There is a CV7351 NPN Ge for the Rangemaster portion of the circuit.
5 X FET J201's.
Gain - A100k
Trebble - B100k
Volume - A100k
2 X 47uF Elec.
Some of the resistor values I can make out are consistent with a NPN Rangemaster. I wonder if the 5 JFETs are like a Brown Sound or a Marshall 18watt.
Looking for more photos of it now. Hope this can be traced at some point.
cdeschenes
Has thanked: 37 times
Have thanks: 20 times
Postby mmolteratx » 04 Nov 2013, 08:43
Anyone tried just emailing Stu? I know he was really straight up with me about the circuits in the few pedals I've bought from him, and he's a really friendly guy. From what I can see, one pair of J201s looks to be set up as a common-source stage with a DC couple source follower, so I'd guess that it's a Rangemaster-ish thing into a JFET version of the Supergroup preamp (probably just the treble channel, or a mash up of the treble/bass channels since it's only got one gain control) with a buffered output and a passive high cut tacked in there somewhere, likely right before the master based on the location on the board.
mmolteratx
Has thanked: 103 times
Have thanks: 627 times
Postby Cub » 24 Apr 2017, 07:46
Morning, lads! :D
I found an album on Photobocket with all sort of snapshots of this pedal, including the bottom of the PCB.
http://s77.photobucket.com/user/fantastik_badr/library/Castledine%20Wizard?sort=3&page=1
It's slightly newer and different from the ones that were posted in this thread so far.
enjoy :thumbsup
dv8r601 (24 Apr 2017, 16:28)
Cub
Postby Cub » 24 Apr 2017, 19:19
Too late to edit my previous post, but I had a go at it myself. It's my first attempt, so it's far from perfect. (please try and don't laugh too hard :blackeye) The things I'm not certain about are in red.
There's a resistor between the two big orange drops that doesn't appear to be connected on one end. Also, there's a trace going from the cap on its right to... ? I can't see, but I suspect the electrolytic cap.
The two images I used as a source are also attached for an unobstructed view. Perhaps the more experienced members can tell me where I went wrong or even have a go at it themselves.
For this message the author Cub has received thanks: 5
dv8r601 (26 Apr 2017, 12:22), J0K3RX (13 Dec 2017, 15:57), modman (25 Apr 2017, 16:19), Nocentelli (24 Apr 2017, 21:18), toneman (25 Apr 2017, 04:20)
Cub
Postby Jan1966 » 24 Apr 2017, 20:23
I'm interested.
The second photo down will be perfect to copy using Sprint.
http://www.ebay.co.uk/itm/2N1308-CV7351 ... 1069189439
others will probably work. Just need the cap values.
Jan1966
Has thanked: 13 times
Have thanks: 16 times
Next
Users browsing this forum: [Gringo], Dr Tony Balls, ElectricPB, jrod, tiago_guitar83 and 2 guests
