Catalinbread Echorec - Pic and schematic
Re: Catalinbread Echorec - Pic and schematic
Postby Ice-9 » 05 Mar 2013, 19:36
coldcraft wrote:
loylo wrote:
Ice-9 wrote:@mrkaploca It's not possible to read protect the 24lc32a Eeproms, but reading the code from an Eeprom is of no use for study, only useful if you just want to flash it to another pedal.
I disagree. Reading some codes could be very instructive. For sure, you "can" learn to code a basic digital delay or a generic digital filter by yourself, given the necessary will. But Coding a "analog-like" filter needs advanced skills that you can learn from developped codes and algorithms. I have an elektor book about DSP with loads of very instructive examples.
I think that reading codes is as stimulating as deciphering analog circuits.
That said, I repeat that I respect your decision to not reveal the Echorec code.
I think ICE-9 means that its not possible to "read" (as in "extract") the code from an EEPROM back to the programming language on the computer, but it is possible to copy from one EEPROM to another. Correct me if I'm wrong.
Correct coldcraft, you can indeed read and use/copy the eeprom code but as a learning tool it is useless, as it is a compiled hex and no information is available to see how the assembly code works.
I'm sure there are clever people out there that can reverse the compiled code back to asm but thats not me.
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby loylo » 05 Mar 2013, 22:53
Oups, Im confused! Sorry for my misunderstanding! :oops: :mrgreen:
Then you're 100% right, Ice-9!
loylo
Has thanked: 15 times
Have thanks: 18 times
Postby micromegas » 05 Jun 2013, 21:09
loylo wrote:I have an elektor book about DSP with loads of very instructive examples.
may I ask what book is that?
micromegas
Postby loylo » 27 Jun 2013, 10:10
Sorry for the late answer.
It is this book:
http://www.elektor.fr/products/books/au ... 2601.lynkx
But I don't know if it has been translated...
loylo
Postby devastator » 27 Jun 2013, 11:50
loylo wrote:Sorry for the late answer.
It is this book:
I was thinking about getting a DSP/µC book , is it good ?
devastator
Have thanks: 24 times
Postby loylo » 28 Jun 2013, 08:47
That's the book I've recommended to you on g.com :wink:
loylo
Postby ilcaccillo » 14 Jan 2017, 06:33
I really like the sound of this pedal but having tap tempo is a must for my needs so unfortunately although I like the sound I can't use it.
I know a lot of people that don't have any use for a tap tempo in a delay pedal, and I understand that but there are the same amount of people that find it useful or really need it to sync with the songs. It depends on particular needs and uses.
I have seen a lot of other people asking for the tap tempo feature in this pedal but the manufacturer refuses to add that feature in new versions with the argument of "Tape Delays don't have tap tempo".
Would changing the code be the only way of achieving a tap tempo control in this unit?
For this message the author ilcaccillo has received thanks:
Wiseblood (05 Feb 2017, 14:25)
ilcaccillo
Postby captain_tango » 13 Jun 2018, 20:26
Sorry for re-surfacing this, but I'm really interested in the BJT preamp and mixer situation that Catalinbread has been using.
I want to get into the FV-1, but I feel like playing around with a bit more of a crude BJT preamp could be more fun than a stable and obvious op-amp one...
Does anyone still have the first draft or any draft schematic? I don't need spot on repliction, just general pointers, really!
captain_tango
Has thanked: 10 times
Have thanks: 4 times
Postby ilcaccillo » 02 Aug 2018, 21:41
Hi captain_tango, I would like to help you out but I dont have the schematic now I ever seen an atempt of a drawing.
For you guys much more knowledged than me on eproms,
do you think is there any way to modify this pedal so it can have tap tempo?
thank you so much
ilcaccillo
Postby Ice-9 » 08 Aug 2018, 10:34
ilcaccillo wrote:Hi captain_tango, I would like to help you out but I dont have the schematic now I ever seen an atempt of a drawing.
thank you so much
The only way I could think of to add tap tempo to the echorec while keeping the original code intact on the pedal would be to develop a PIC or ATMEL taptempo add-on which has a taptempo footswitch and a echo pot, this would need to replace the echorec 'Delay Time' pot which controls one of hte FV-1 pot control pins. Maybe It would be a big chore to work out the maths for the tap tempo to match the delay time of the pedal. It sounds like a nice mod that Catalinbread should do though.
The other way would be to completely write your own FV-1 code to replace the echorec code and include the taptempo FV-1 code within the new echo code. The problem here would be that the taptempo part of the FV-1 code uses quite a lot of the available code space and would not leave enough to make the echo code as good as the original pedal.
Ice-9
Postby ilcaccillo » 08 Aug 2018, 17:13
Thanks Ice-9
So it seems the "Pic tap tempo add on" would be probably the best way to attempt to do that
Thank you so much for your input
ilcaccillo
Postby Ice-9 » 09 Aug 2018, 16:17
ilcaccillo wrote:Thanks Ice-9
A pic code tap tempo would need to be a 0-3.3v control voltage for control of the tap timing unlike some tap tempo code which will output an LFO. It could be done but I have not give it any thought at all.
Ice-9
Postby ilcaccillo » 12 Aug 2018, 17:01
Would you be interested in developing this?
There's a lot of people asking for a Tap tempo solution for the Catalin Echorec, I'm sure they're will be demand
ilcaccillo
Postby Ice-9 » 15 Aug 2018, 13:02
Sorry that is not on my list of to do things.
For this message the author Ice-9 has received thanks:
Nocentelli (15 Aug 2018, 14:39)
Ice-9
Postby ilcaccillo » 17 Aug 2018, 15:43
If anyone is instered in developing an option for TAP Tempo control in Catalinbread Echorec please let me know
Thank you so much
ilcaccillo
Previous
Users browsing this forum: Danch, Groovenut, HiggsDigsTwigs, Nick123 and 9 guests
