Vemuram - Jan Ray [traced]
- mmolteratx
- Degoop Doctor
Got this earlier this afternoon.
DSC_0008 by mmolteratx, on Flickr
DSC_0013 by mmolteratx, on Flickr
DSC_0017 by mmolteratx, on Flickr
DSC_0019 by mmolteratx, on Flickr
DSC_0021 by mmolteratx, on Flickr
DSC_0024 by mmolteratx, on Flickr
DSC_0028 by mmolteratx, on Flickr
- mmolteratx
- Degoop Doctor
And here are pics of the caps I measured, and the trace routing since it's a 4 layer board.
- Vemuram Jan Ray gut shot
- ScreenShot2013-03-06at74655PM.png (325.69 KiB) Viewed 20316 times
- mmolteratx
- Degoop Doctor
- candletears7
Timmy?
- candletears7
Timmy-san, then.
- apollomusicservice
VR is point R9-R10-C12 right?
- mmolteratx
- Degoop Doctor
Yup.apollomusicservice wrote:VR is point R9-R10-C12 right?
- IvIark
I've removed the first scheme you posted. Cheers Matt
+1 . The voltage divider is also missing a label for vref.Eisy wrote:Thanks to mmolteratx for tracing.
But are you sure about the values of R9/R10? Looks a bit odd to me and very mis-biased...
Nice work, btw!
- IvIark
Vero'd. And so another £300 rip off, no doubt some people will be stupid enough to buy it.
and one using a standard trimmer and with an extra switch to give you the option to also select the "compressed symmetrical" setting on the Timmy.
D6 on schem = D5 on board
- IvIark
Yes, I excluded the LED resistor so my numbering is different
I don't follow the scheme numbering convention because I don't number the main components. Of course I could have kept the diode numbering the same anyway, but I do it in a way that will cause me the least amount of work in the future, and I can guarantee I'd spend more time answering questions about whether I forgot to include a diode because of the missing number, than I will from people who notice the protection diode has the number given to the LED in the schematic.
Think of it as "based" on Matt's scheme
- mmolteratx
- Degoop Doctor
Yup. Removed and measured to be sure. It's definitely odd.Eisy wrote:Thanks to mmolteratx for tracing.
Ok, thanks.mmolteratx wrote:Yup. Removed and measured to be sure. It's definitely odd.Eisy wrote:Thanks to mmolteratx for tracing.
Maybe this is why the Jan Ray does not sound like a Timmy on the first view.
I guess this odd voltage divider will change the gain structure a lot.
Could be the bass cut section, the trim pot in parallel with the 9K1, vs the Timmy and it's fixed 3K3 (iirc ? ). Plus a different value on the treble pot ?Eisy wrote:Ok, thanks.mmolteratx wrote:Yup. Removed and measured to be sure. It's definitely odd.Eisy wrote:Thanks to mmolteratx for tracing.
- mmolteratx
- Degoop Doctor
Actually, thanks to an anonymous tipster, I realized that one of the bias resistors R10 was indeed mislabeled. Went back and checked my pictures and sure enough, LCR meter said 7k5 and I just misread the 7 as a 1 when I typed up the schem.
No, it's entirely in the different treble control. The bass response is exactly the same, all the trimmer does is vary the effective value of R4, which sets the gain of the stage. The treble control on the Jan Ray lops off everything above 2.8kHz at -6dB/decade at max. The Timmy's control at minimum does the same, but at 10.6kHz. Just use the Timmy's control in a different range and you've got a Jan Ray.dano wrote:Could be the bass cut section, the trim pot in parallel with the 9K1, vs the Timmy and it's fixed 3K3 (iirc ? ). Plus a different value on the treble pot ?Eisy wrote:Ok, thanks.mmolteratx wrote:Yup. Removed and measured to be sure. It's definitely odd.Eisy wrote:Thanks to mmolteratx for tracing.
- Realfi
- my favorite amplifier: VOX
Loving watching this over at TGP..mmolteratx wrote:Actually, thanks to an anonymous tipster, I realized that one of the bias resistors R10 was indeed mislabeled. Went back and checked my pictures and sure enough, LCR meter said 7k5 and I just misread the 7 as a 1 when I typed up the schem.
[ Image ]
So how many Timmy copies is that now?
What I was thinking with the bass cut is it depends where the trimmer is factor set. Plus you'd have to wonder why they have added a trimmer in parallel with a fixed resistor, I can think of two reasons, they couldn't source a 5K trimmer (unlikely) or , they wanted for some reason to make the circuit look a little different from the Timmy and add some mojo control to it..mmolteratx wrote: No, it's entirely in the different treble control. The bass response is exactly the same, all the trimmer does is vary the effective value of R4, which sets the gain of the stage. The treble control on the Jan Ray lops off everything above 2.8kHz at -6dB/decade at max. The Timmy's control at minimum does the same, but at 10.6kHz. Just use the Timmy's control in a different range and you've got a Jan Ray.
Good work on this, think i'm going to buy a 'proper' Timmy this year.
