Bearfoot - Baby Pink Booster  [traced]
Postby mmolteratx » 20 Mar 2013, 06:02
For this message the author mmolteratx has received thanks: 7
atreidesheir (02 Apr 2013, 02:14), IvIark (20 Mar 2013, 16:21), mac_2006 (20 Mar 2013, 13:27), modman (20 Mar 2013, 17:28), pedalgrinder (24 Mar 2013, 11:33), rocklander (20 Mar 2013, 07:06), tp801 (21 Mar 2013, 17:44)
mmolteratx
Has thanked: 103 times
Have thanks: 627 times
Re: Bearfoot Baby Pink Booster
Postby skywise » 20 Mar 2013, 16:02
That unnecessarily huge cap must be where all the awesome is stored. :thumbsup
skywise
Has thanked: 47 times
Have thanks: 20 times
Postby IvIark » 20 Mar 2013, 17:02
Love the quickies :)
For this message the author IvIark has received thanks: 3
modman (08 May 2015, 12:14), pedalgrinder (24 Mar 2013, 11:34), rocklander (20 Mar 2013, 20:25)
IvIark
Has thanked: 668 times
Have thanks: 681 times
Postby mmolteratx » 21 Mar 2013, 01:56
And here's a PCB. Parts match the schem, and I don't think I need to say no commercial use, but no commercial use. Print at 300dpi.
For this message the author mmolteratx has received thanks: 3
modman (08 May 2015, 12:14), pedalgrinder (24 Mar 2013, 11:34), rocklander (21 Mar 2013, 02:34)
mmolteratx
Postby mmolteratx » 21 Mar 2013, 02:17
And here's one with larger pad sizes. Figured I'd make it a bit easier for less experienced etchers.
modman (08 May 2015, 12:14), pedalgrinder (24 Mar 2013, 11:34), rocklander (21 Mar 2013, 02:33)
mmolteratx
Postby real-pcb » 21 Mar 2013, 08:51
Would above PCB be processed?
real-pcb
Postby marshmellow » 21 Mar 2013, 13:11
real-pcb wrote:Would above PCB be processed?
Would you please stop spamming the DIY electronics forums? Thank you.
marshmellow
Have thanks: 122 times
Postby phibes » 21 Mar 2013, 16:06
No it needs to be coagulated.
Image Ken
phibes
Has thanked: 85 times
Have thanks: 185 times
Postby Seiche » 21 Mar 2013, 19:38
so switch is wired so that the thing is still a buffer when it's off. For regular operation regular switch wiring, right?
Seiche
Has thanked: 241 times
Have thanks: 184 times
Postby mmolteratx » 21 Mar 2013, 19:41
Seiche wrote:so switch is wired so that the thing is still a buffer when it's off. For regular operation regular switch wiring, right?
Yup. If you want to wire it as true bypass, dump the 150k resistor at the cold lug of the boost pot and leave the wiper connected to ground.
modman (08 May 2015, 12:15), pedalgrinder (24 Mar 2013, 11:34), Seiche (21 Mar 2013, 20:24)
mmolteratx
Postby Seiche » 28 Mar 2013, 14:52
looking at the pcb again, this looks like it could be the same pcb used on the candy apple fuzz (as usual for the Bearfoots). This might be a good opportunity to trace out the pcb connections, as the traces are easily visible to facilitate tracing of the CAF once it's released.
Seiche
Postby coldcraft » 28 Mar 2013, 18:43
people pay for this?
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Postby Seiche » 28 Mar 2013, 19:56
well it's pretty darn cute :mrgreen:
Seiche
Postby phibes » 28 Mar 2013, 22:38
Seiche has been waiting to unload that Reese photo!
Image Ken
phibes
Postby mmolteratx » 30 Mar 2013, 00:04
Seiche wrote:looking at the pcb again, this looks like it could be the same pcb used on the candy apple fuzz (as usual for the Bearfoots). This might be a good opportunity to trace out the pcb connections, as the traces are easily visible to facilitate tracing of the CAF once it's released.
It's used in the CAF and EGD. Was gonna buy an EGD, but I've kinda lost interest.
modman (08 May 2015, 12:16)
mmolteratx
Re: Bearfoot - Baby Pink Booster
Postby laoliang » 27 Aug 2017, 20:19
Excuse me:D1,D2,D3 is 1n4002?
As far away as China
laoliang
Postby laoliang » 17 Sep 2017, 09:08
laoliang wrote:Excuse me:I'm ready, but no sound, I checked again and again, my triode in 5458
laoliang
Postby Seiche » 22 Jun 2018, 08:47
mmolteratx wrote:If you want to wire it as true bypass, dump the 150k resistor at the cold lug of the boost pot and leave the wiper connected to ground.
Can someone explain what is happening here? I just left the 150k in the circuit and wired the bypass as usual. What's the difference? When turned all the way down, the signal is at unity gain.
laoliang wrote:Excuse me:D1,D2,D3 is 1n4002?
No, D2 is a zener for LED protection, D3 is an LED. I left D2, D3 off my build as I did not use the buffered bypass.
Seiche
Users browsing this forum: calfzilla, Nikolas and 13 guests
