Amptweaker - Tight Metal [traced]
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
polite suggestion - just redraw my last schematic with the correct layout and values - posting your schematic with all it's errors just confuses people.
- apollomusicservice
At bridged T-notch filter where is the place for C15-R22 at the point R20-R21 or C14-R21-C16?
- euronymous0001
- bajaman
looking at the board again it certainly looks like it is connected at the R20-R21 point
If so my apologies - I will post an amended schematic unless euronymous0001 does so first - sorry.
Perhaps Jim could confirm this first.
- J0K3RX
- Degoop Doctor
I will confirm as soon as I get home from work todaybajaman wrote:At bridged T-notch filter where is the place for C15-R22 at the point R20-R21 or C14-R21-C16?
- jymaze
It is at the junction of R20 and R21! I even rechecked the pictures to be 300% sure... I was only 100% sure.
Anyway, if it were anywhere else but there it would not be called a T-filter, right...
- bajaman
hopefully correct value parts and configuration now
OK guys backing your changes I've made a small correction to the PCB. I am convinced that this is the final versionapollomusicservice wrote:This is a new version with implemented corrections. Points 1-5 are connected to ground, IN-input, OUT-output, IN1 and OUT1 to insert out, the T1 Tight pot, G1 and G2 to gain pot, G3 and G4 to gain pot other sections (both at Gate SW also), TO1 TO2 TO3 on Tone pot, TH on Thrash sw, V1 V2 V3 the Volume pot and
+9 V power supply.
- TightMetal SMD v1.4.pdf
- (11.57 KiB) Downloaded 144 times
- TightMetal SMD v1.4 components.png (7.49 KiB) Viewed 2423 times
- The G
- Grease Monkey
Great effort, dudes!
Can anybody enlighten me as to what purpose the lonely diodes between the IC1A and IC2A inputs serve? Are they really 1N4148, Jim? The pictures are too blurry to see anything clearly.
- jymaze
In clipping situation, the inputs can get away from each other as you are no more in linear situation. So the diode across the inputs of IC2A clips the signal. However, the diode across the inputs of the buffer is a mystery as it is totally linear...
- The G
- Grease Monkey
But it's only one diode, so the clipping is one sided. Does James Brown know something about TL072 that we don't?
Of course, it would be not the first time parts with no real function are found in pedals.
One way or another, I'll try to squeeze some time from this weekend to breadboard TM.
- bajaman
Here are some photoview files for the enclosed Sprint Layout V6.0 zip file (just rename the extension to .lay6 to open the file in Sprint ) Also included is the updated Eagle schematic. i have changed all the components to standard types - 475k becomes 470k etc.
- bajaman
Good idea - count me in for one boardAwesome, now maybe it is time for a fab run at OSH park?
- bajaman
- bajaman
I have been agonising over the 4 red leds and the type of socket used to connect the dc power supply - according to the designer of the pedal these lights only operate when using the power supply NOT when the battery is connected. obviously the 4 leds will drain the battery very quickly as stated current consumption is only 12mA in battery mode and twice this current when using a 9v dc power supply. He must be using a stereo mini jack socket to enable this type of operation. My layout files use a more standard 2.1mm dc socket which merely isolates the +9v dc battery connection when a power supply is plugged in. If anyone is planning on building this and is intent on using battery power it would probably be wise to omit these four red leds from their build.
- bajaman
tight and gain pots now wired as on the pcb
general tidy up
