Amptweaker - Tight Metal  [traced]
Re: Amptweaker - Tight Metal
Postby J0K3RX » 30 May 2013, 04:38
What, nobody made a single layer through hole yet? :? Is it because it doesn't have Wampler tattooed on it? :mrgreen:
Don't make me do it! We will be debugging till the cows come home... :roll:
J0K3RX
Has thanked: 326 times
Have thanks: 516 times
Postby apollomusicservice » 30 May 2013, 07:18
OK bajaman thanks for notes, I dont have Sprint-Layout software but if someone has a schem as pdf, png, gif, jpg
I'll make correction in my Eagle files and SMD pcb.
apollomusicservice
Has thanked: 65 times
Have thanks: 783 times
Postby bajaman » 30 May 2013, 12:37
tight metal -3a.sch
my preliminary amended Eagle schematic - tone control, notch filter and power supply corrected :wink:
ggedamed (30 May 2013, 14:13)
Has thanked: 447 times
Have thanks: 1536 times
Postby apollomusicservice » 30 May 2013, 12:56
Bajaman can you upload your schematic as pdf?
apollomusicservice
Postby bajaman » 30 May 2013, 13:06
Postby ggedamed » 30 May 2013, 14:17
Bajaman, C1-R1-R3 should connect to GND.
Now the schematic look really interesting. Given some spare time I'll breadboard it.
ggedamed
Have thanks: 145 times
Postby jymaze » 30 May 2013, 14:32
Thanks you all for putting the schematic from my crappy handwritten drafts in a software. I just hate doing it for some reason. But I can trace all day long! That is the fun part for me.
For this message the author jymaze has received thanks:
J0K3RX (30 May 2013, 23:39)
jymaze
Has thanked: 87 times
Have thanks: 161 times
Postby azrael » 30 May 2013, 17:55
J0K3RX wrote:What, nobody made a single layer through hole yet? :? Is it because it doesn't have Wampler tattooed on it? :mrgreen:
Was just waiting until the correction were released. ;)
I'll finish it after work today. Just a bit hard to make out what's going on with the power network, I usually prefer to use Net labels or Voltage reference symbols for that sort of thing, so it was a bit harder for me to decipher it. :)
For this message the author azrael has received thanks:
J0K3RX (31 May 2013, 02:41)
azrael
Has thanked: 33 times
Have thanks: 93 times
Postby jymaze » 30 May 2013, 18:21
Azrael,
Here is the PSU in an easier to decipher format.
I already posted that before, but actually I forgot the 4007 in series with a 47 ohms resistor. There are 2 4007 diodes in the PSU... Good polarity protection!
PSU.pdf
modman (26 Apr 2016, 14:16)
jymaze
Postby apollomusicservice » 30 May 2013, 19:32
This is a new version with implemented corrections. Points 1-5 are connected to ground, IN-input, OUT-output, IN1 and OUT1 to insert out, the T1 Tight pot, G1 and G2 to gain pot, G3 and G4 to gain pot other sections (both at Gate SW also), TO1 TO2 TO3 on Tone pot, TH on Thrash sw, V1 V2 V3 the Volume pot and
+9 V power supply. :)
apollomusicservice
Postby bajaman » 30 May 2013, 21:07
grounds connected and extra diode in power supply :wink:
J0K3RX (31 May 2013, 01:07)
Postby bajaman » 30 May 2013, 23:09
My new rendition in Sprint Layout V6.0 - needs verifying - some of the tracks are on different layers - not sure what the DC socket is so pin footprints may be wrong - please advise if you see ay obvious mistakes :wink:
I will post complete files including gerber files etc. once layout is deemed to be correct - I will probably adjust the dc socket footprint for a 2.1 mm standard DC socket in the final draft.
here is a composite of V0.9
For this message the author bajaman has received thanks: 3
ggedamed (31 May 2013, 15:13), J0K3RX (31 May 2013, 00:19), modman (26 Apr 2016, 14:16)
Postby J0K3RX » 30 May 2013, 23:47
Just got home from work... nice progress!!!
J0K3RX
Postby J0K3RX » 31 May 2013, 02:42
Damn! Can't wait!! :D
J0K3RX
Postby bajaman » 31 May 2013, 04:17
still more corrections 15k changed to 1k5 :wink:
J0K3RX (31 May 2013, 05:16)
Postby euronymous0001 » 31 May 2013, 06:32
im not accustomed to the way bajaman drew the PSU. :mrgreen:
so here is one for those who are like me :oops:
For this message the author euronymous0001 has received thanks:
Belanger88 (23 Feb 2017, 22:00)
euronymous0001
Has thanked: 19 times
Have thanks: 29 times
Postby J0K3RX » 31 May 2013, 07:15
If somebody creates a through hole layout I can etch and build this weekend and do a side by side comparison... :twisted:
J0K3RX
Postby bajaman » 31 May 2013, 08:06
Can you do double sided etching okay Jim :?:
and you may not like my latest schematic euronymous0001 but at least it is correct - your one has at least two errors in the layout and component values :roll: ( and it is almost too small to read :cry: ) hint 15k resistor should be 1k5 and the second filter to ground in the notch section is connected wrong :wink:
Postby bajaman » 31 May 2013, 08:09
AND the 68k resistor supplying the bias line should be 6k8 :roll:
Postby bajaman » 31 May 2013, 08:10
AND the VR supply rail resistors are 18k and 47k NOT 100k and 150k :roll:
Users browsing this forum: tube65 and 9 guests
