Amptweaker - Tight Metal  [traced]
Re: Amptweaker - Tight Metal
Postby jymaze » 24 May 2013, 15:52
If someone could plug it in a schematic software, it would be nice. I just don't like to do it and I think it is nice to give people the option to participate :D .
jymaze
Has thanked: 87 times
Have thanks: 160 times
Postby jymaze » 24 May 2013, 16:47
Repost, the bottom of the schematic got cut-out by my scanner. This one is fine:
For this message the author jymaze has received thanks: 2
Intripped (24 May 2013, 22:30), modman (27 May 2013, 14:22)
jymaze
Postby coldcraft » 24 May 2013, 19:43
thanks for your hard work. does Vref not have a bypass cap to ground?
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Postby jymaze » 24 May 2013, 20:52
Yep, did not detail the PSU too much. Basically it is like I represented, except it happens multiple times around the board, sometimes with decoupling, sometimes not, sometimes with a resistor to the opamp non-inverting input, sometimes not. It is very random as I see it. I would make one solidly decoupled Vref and use it for all needs. The main 9v is also decoupled with a big 100u cap and a smaller 100n poly cap, it feeds the opamps directly. Then there is a low pass filter (6.8k and 22u) that leads to the voltage point used for all the Vref points. It is a very oversized PSU, but whatever... I can draw it if you really want...
Also, I retraced and found an error around the tight control, so here it is again, correct for now at least:
Tight Metal - First Draft.pdf
The diodes between the inputs are a little mysterious to me... from the output to the input, fine, but across the inputs... Whatever... Not sure they ever rectify anything, but who knows...
For this message the author jymaze has received thanks: 3
Bill_Mountain (27 May 2013, 15:03), Eisy (24 May 2013, 22:47), FiveseveN (25 May 2013, 11:59)
jymaze
Postby Eisy » 24 May 2013, 22:47
jymaze wrote:The diodes between the inputs are a little mysterious to me... from the output to the input, fine, but across the inputs... Whatever... Not sure they ever rectify anything, but who knows...
I guess they are just for protection?
Anyway, thanks for tracing!
Eisy
Have thanks: 69 times
Postby J0K3RX » 24 May 2013, 23:44
jymaze wrote:Repost, the bottom of the schematic got cut-out by my scanner. This one is fine:
:applause: I will try to go over it tonight against the board... May make a layout in Sprint if I get ambitious?
J0K3RX
Has thanked: 310 times
Have thanks: 481 times
Postby J0K3RX » 25 May 2013, 02:31
jymaze wrote:If someone could plug it in a schematic software, it would be nice. I just don't like to do it and I think it is nice to give people the option to participate :D .
I don't have any simulation software so it's gonna be freestyle for me...
J0K3RX
Postby euronymous0001 » 25 May 2013, 03:58
:secret:
http://www.filedropper.com/tightmetal
euronymous0001
Has thanked: 19 times
Have thanks: 29 times
Postby J0K3RX » 25 May 2013, 04:14
euronymous0001 wrote:
:secret:
won't open for me?
J0K3RX
Postby bajaman » 25 May 2013, 05:28
what program opens this .sch file ? :hug:
Altium designer just shows a blank page :(
Has thanked: 406 times
Have thanks: 1372 times
Postby bajaman » 25 May 2013, 05:41
tried EAGLE - got load error 292 etc. :(
Postby J0K3RX » 25 May 2013, 05:58
bajaman wrote:tried EAGLE - got load error 292 etc. :(
Got the same error... opened with notepad and there is definitely code in there?
J0K3RX
Postby euronymous0001 » 25 May 2013, 06:32
euronymous0001
Postby bajaman » 25 May 2013, 07:32
using Eagle 6.40 light :wink:
downloaded new file :thumbsup
still getting the same error :? :( :(
Postby euronymous0001 » 25 May 2013, 08:02
http://www.filedropper.com/tightmetal_2
used eagle lite 6.4 this time :mrgreen:
euronymous0001
Postby J0K3RX » 25 May 2013, 10:23
Here it is a little less chopped up...
J0K3RX
Postby euronymous0001 » 25 May 2013, 10:43
can't decipher the component connected to lug 3 of the tone pot. can't read if its 33k or 33n :scratch:
also, the pots might be reversed wired on my eagle file :mrgreen:
and not sure diode types :slap:
euronymous0001
Postby bajaman » 25 May 2013, 11:46
it would be interesting to know what the diodes are - schottky, zeners, ultrafast, general purpose :?: :hmmm: :hmmm:
Postby coldcraft » 25 May 2013, 13:03
I tried a noise gate like that once and was disappointed in its performance. I guess I didn't have enough gain before it.
coldcraft
Postby coldcraft » 25 May 2013, 13:09
as drawn in the eagle schematic, the Gate pot is backwards. The resistance should increase as the gain is turned up.
coldcraft
Users browsing this forum: JohnyBgoode and 24 guests
