Amptweaker - Tight Metal  [traced]
Re: Amptweaker - Плотный Металл
Postby J0K3RX » 21 May 2014, 10:24
ggedamed wrote:
Darksid46 wrote:SPSim12\0LionSound+E530JFET http://www.youtube.com/watch?v=VDa3uOqrerc
Is it related to the Tight Metal or to the AMT L1 Series?
Neither... Not really sure what it is, a cab sim or amp sim? 1208 programmable opamp..?
http://lionsound.ru/?mod=prod
http://postimg.org/image/w7i6n7zjj/full/
J0K3RX
Has thanked: 308 times
Have thanks: 471 times
Postby ggedamed » 21 May 2014, 11:44
Darksid46 wrote:Нет это не связано с AMT L1 серии.Это новая разработка LIONSOUND14\0 \DarkAngel/ А СИМ я взял от 12версии.+добавил выход на наушники от HotLine2/
I think he said
Code: Select all
No, it is not associated with the AMT L1 series. It is a new development  - LIONSOUND14\0\DarkAngel/. And I took the cabsim from version 12 and added the headphone output from HotLine2.
Hmm, I remember DarkAngel modding the SansAmp GT2.
Seeing E530 written on the case and seeing Lionsound on guitar-gear.ru in the AMT stompboxes thread made me think this is related.
The "new development" part makes me think he just wanted to advertise his pedal.
ggedamed
Has thanked: 138 times
Have thanks: 144 times
Postby rcustoms » 21 May 2014, 17:38
I think he said
Code: Select all
uhhh i think that this pedal is from a russian guy, very clever in deep ,this is the link (in russian)
http://guitar-gear.ru/forum/topic/3724- ... _lionsound
and this is the schematcs from the ver 12
an the ver. 14 is a mod from darksid.very clever pedal and very clever mod too.
guitars,pedals and amps.
@zuleta.rafael(Instagram)
For this message the author rcustoms has received thanks:
ggedamed (23 May 2014, 17:20)
rcustoms
Has thanked: 322 times
Have thanks: 481 times
Postby rcustoms » 21 May 2014, 18:38
Darksid46 wrote:на ver. 14 мод от darksid.Нет это не МОД.Это вер.14.0сновное ее название LIONSOUND 14.0 DarkAngel а смемотехника совсем другая ближе к ENGL530 в отличии от 12.0 .В 14.0 и SPSim тоже другой.
slap: :slap: sorry i dont speak ru. and the translation is not very accurate
rcustoms
Postby rcustoms » 21 May 2014, 19:15
Darksid46 wrote:
Darksid46 wrote:Вот новый СИМ
:D :D :D
and the pre amp schematic?
rcustoms
Postby rcustoms » 21 May 2014, 19:50
Darksid46 wrote:Да новый
if you could ? please share with us
thank anyway
rcustoms
Re: Amptweaker - Tight Metal
Postby J0K3RX » 22 May 2014, 00:16
Darksid46 - Где предусилитель?
J0K3RX
Postby J0K3RX » 22 May 2014, 01:07
He says that he would like to share but the actual project is not his.
I may have a go at the cab simulator... looks interesting and I have heard samples of the previous version with direct recording in a mix, sounded excellent! I am guessing this version is geared more towards being used with an ENGL type preamp.. more mids.
J0K3RX
Postby ggedamed » 23 May 2014, 17:19
I got it! They're speaking only Russian so - after little time - Putin will come and conquer FSB to protect the right of Russians abroad :horsey: .
I've already applied for a diystompboxes passport :secret:.
For this message the author ggedamed has received thanks: 3
J0K3RX (28 May 2014, 23:45), lespos (26 May 2014, 08:11), protakill (23 May 2014, 20:59)
ggedamed
Postby sweeplikevai » 28 May 2014, 16:40
Darksid46 wrote:Мой Жесткий Металл
awesome,. what are those pedals? care to share? :D
sweeplikevai
Postby sweeplikevai » 29 May 2014, 21:59
Darksid46 wrote:
awesome,. каковы эти педали? поделитесь? :D
Lionsund12.0 sound can be made as 5150 | OKKO Domimator-also very dense sound on OUT.Delo taste. :popcorn:
thanks bos..
any build instructions, schems, vero/pcb's,,? especially the lionsound(5150)... if you dont mind.. :D
sweeplikevai
Postby GodSaveMetal » 30 May 2014, 02:21
you have the LIONSOUND 14?? please post all you have PCB; layout; external connetions!! thanks!
For this message the author GodSaveMetal has received thanks:
J0K3RX (30 May 2014, 04:20)
GodSaveMetal
Has thanked: 141 times
Have thanks: 52 times
Postby J0K3RX » 30 May 2014, 04:57
I regularly frequent the guitar-gear.ru forum.. I already had the LS12 layout but have not built due to the odd components, 1208 programmable opamp and 2SK163... I think the UA776 or LM4250 may be suitable substitutes for the 1208 but not sure? I may have a go at the cab sim portion of the circuit, if I get around to it..?
It sounds really good to me but not so much to inspire me to investigate further...
Would prefer to see the schem for the LS14 ENGL sim... I LOVE anything ENGL!
Darksid46 - Maybe you can direct us to the mysterious forum or secret laboratory where the "LionSound 14" that you speak of lives? Is it being guarded by the Russian Yeti in some forsaken part of Siberia? :twisted:
For this message the author J0K3RX has received thanks:
sweeplikevai (01 Jun 2014, 01:57)
J0K3RX
Postby karul » 30 May 2014, 13:29
NTE888M - possible substitution for УД1208 (used in LIONSOUND)
http://modularsynthesis.com/kuzmin/poli ... ks_vcf.htm
karul
Has thanked: 209 times
Have thanks: 143 times
Postby sweeplikevai » 31 May 2014, 20:10
Darksid46 wrote:Yes there is a circuit and PCB http://guitar-gear.ru/forum/topic/3724- ... _lionsound
thanks.. much appreciated.
back to topic.
pls post amptweakers ic1/ic2 voltages..
For this message the author sweeplikevai has received thanks:
J0K3RX (31 May 2014, 20:19)
sweeplikevai
Postby Levictus » 16 Jul 2014, 22:50
Hi fellas
Awesome work on the Tight Metal! :applause:
Does anyone have a pcb available for sale or would someone be interested in making one for me? Thought about doing OSHPark but don't think Eagle or Gerber files are available. Thanks in advance for your help, feel free to pm me if you want... :D
Levictus
Postby brejna » 09 Dec 2014, 18:47
brejna wrote:If everything is ok with layout, here is the pdf.
REV1.1 There are errors on this layout :oops:
For this message the author brejna has received thanks: 3
287m (25 Jan 2015, 13:40), GodSaveMetal (10 Dec 2014, 03:54), J0K3RX (10 Dec 2014, 02:01)
brejna
Has thanked: 66 times
Have thanks: 54 times
Postby J0K3RX » 10 Dec 2014, 03:00
Does this layout work? I will build it if it does..
J0K3RX
Postby brejna » 10 Dec 2014, 11:33
J0K3RX wrote:Does this layout work? I will build it if it does..
I think it should work, correction are for tonestack. I've put two wrong junctions and rev1.1 should cover that. I've seen there are differences in your schematics.. Also I did layout with chargepump..
brejna
Postby brejna » 19 Jan 2015, 01:33
Here are new files with corrections and onboard 18v charge pump..
For this message the author brejna has received thanks: 2
Belanger88 (09 Dec 2016, 11:18), selfdestroyer (11 Mar 2015, 02:40)
brejna
Users browsing this forum: batak_man, fentemple, Lazzy, MarshallPlexi and 9 guests
