Walrus Audio Deep Six Compressor  [traced]
Postby roctopus » 31 May 2013, 22:27
Here are a few pics I took of the new Walrus Audio Deep Six Compressor if anyone cares.
For this message the author roctopus has received thanks: 2
jtn191 (05 Jul 2014, 07:56), tuemmueh (26 Apr 2014, 08:59)
roctopus
Have thanks: 2 times
Re: Walrus Audio Deep Six Compressor
Postby Mbas974 » 01 Jun 2013, 22:20
Cool, seems something already seen on this forum... right Melinb ?
while whether you want to trace it... better heve picture of the other side as well.
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Postby mmolteratx » 02 Jun 2013, 07:15
It's much more likely to be a Ross-alike with a charge pump.
mmolteratx
Has thanked: 103 times
Have thanks: 627 times
Postby mictester » 02 Jun 2013, 10:01
Mbas974 wrote:Cool, seems something already seen on this forum... right Melinb ?
Nope. It's a Dynacomp using a 13600 / 13700 like the Yamaha version of the circuit. The other side of the 13600 is used as a fixed-gain bypass amplifier in the Yamaha.
mictester
Has thanked: 32 times
Have thanks: 799 times
Postby roctopus » 03 Jun 2013, 06:53
more pics
roctopus
Re: Walrus Audio Deep Six Compressor  [traced]
Postby lukatosh » 08 Feb 2015, 18:31
Hi everyone!
well... i'm attempting to trace this pedal.
Its pretty much like the BYOC 5 knob Comp although i've noticed a few things to discuss:
1.- 1uF "NP" (looks like electrolytic), 10uF"NP" and 4.7uF"NP" are used in positions where electrolytics caps were used originally in the dynacomp. can we just use polarized caps like in the Dyna?
2.- only half of the LM13700 is used, the other half is not connected.
3.- The blend circuit portion is a little bit tweaked; specially the last stage uses a fairchild 2n5484 (Image posted). I've read about using a 2n5457 as a replacement but:
3.a) why do they used this design instead the proposed by BYOC?
3.b) how do the 2n5457 will work?... we can just replace it or the circuit needs to be tweaked! (of course after checking the 2n547 pinout).
3.c) Do you suggest maintain this JFET or go back to the design proposed by BYOC?
That's it... I'll keep on working!
Please, excuse my bad english... Best regards from Chile!
For this message the author lukatosh has received thanks: 3
modman (08 Feb 2015, 19:04), selfdestroyer (09 Feb 2015, 21:14), storyboardist (05 May 2015, 14:35)
lukatosh
Has thanked: 33 times
Have thanks: 180 times
Postby lukatosh » 10 Feb 2015, 17:26
[ Image ]
Thanks!!
lukatosh
Postby mictester » 20 Feb 2015, 08:05
You can substitute the FET - pretty much any n-type will work in that circuit.
Your other question - why they did the blend like that - is because they can! It'll work OK and will be quiet because there's no DC differential on the pot.
mictester
Postby audioguy » 12 Apr 2015, 18:57
Did this project ever get completed with a layout?
audioguy
Has thanked: 24 times
Have thanks: 6 times
Postby lukatosh » 14 Apr 2015, 04:13
Nop... i've just traced the pcb!
lukatosh
Postby micahvdm » 28 Apr 2015, 07:29
good day!
any chance of a pcb layout or complete schematic?
micahvdm
Postby storyboardist » 29 Apr 2015, 18:08
Here's a schematic based on the BYOC schem with the changes noted by lukatosh. Working on a PCB
For this message the author storyboardist has received thanks: 6
Blitz Krieg (04 May 2015, 09:13), cdeschenes (30 Apr 2015, 05:02), lars-musik (04 May 2015, 07:59), micahvdm (30 Apr 2015, 10:16), Moonsun (30 Apr 2015, 20:15), ozzy666 (31 Mar 2017, 23:18)
storyboardist
Has thanked: 68 times
Have thanks: 187 times
Postby storyboardist » 05 May 2015, 14:32
Alrighty, here's the perf/pcb layout. I originally wanted on-board pots (and you could still board-mount 2 of them), but trying to keep it 1590B-friendly squashed those dreams. haha Guess there's a reason most modern circuit boards are multi-layer :wink: I drew the board to use 1µ tantalum caps to save space and for lower noise, fyi.
For this message the author storyboardist has received thanks: 3
cdeschenes (08 May 2015, 19:54), micahvdm (05 May 2015, 21:24), Sept29 (10 May 2015, 15:07)
storyboardist
Postby friedtransistor » 05 May 2015, 14:46
Hmm. Schematic look like the dod 280 that I built a while ago, except using a ota instead of an optocoupler, and mixing the dry and wet signals.
On the mixng part, does anyone have clips of that? Cause I've never heard a compressor mixed with dry, just straight wet. [smilie=a_yumdumdoodledum.gif]
For all you starwars fans...
http://lolsnaps.com/upload_pic/TheDarthFader-19337.jpg
Sorry, downsized by request.
Did I mention I love bass?
friedtransistor
Has thanked: 16 times
Have thanks: 30 times
Postby kaeisy » 08 May 2015, 21:28
For this message the author kaeisy has received thanks:
friedtransistor (09 May 2015, 02:56)
kaeisy
Has thanked: 19 times
Have thanks: 7 times
Postby newly » 30 Jun 2016, 06:45
storyboardist...is the one that using BA6110 an actual Deep6? I open up one last night, it has JRC13700 instead.
newly
Postby storyboardist » 18 Jul 2016, 14:42
newly wrote:storyboardist...is the one that using BA6110 an actual Deep6? I open up one last night, it has JRC13700 instead.
Sorry, just now saw this. The BA6110 is left over the BYOC 5-Knob Comp. Guess I forgot to swap it out for the 13700. Fix that and working on redoing the layout. The layout I posted before has been verified, though it's been pointed out to me that the VrefA has a minor error (56k to ground should be 27k). Here's the updated schematic and I'll be working on a new layout with the correct 13700 chip.
uncleboko (18 Jul 2016, 14:59)
storyboardist
Postby storyboardist » 18 Jul 2016, 21:48
Don't know how i missed this before, but there isn't a tone control on the Deep Six that there is on the BYOC. I would assume it follows the original Ross Comp schematic in that area. It also runs off 18v, so I've updated the schematic to reflect that as well. I would assume the charge pump is a typical 1054-style, but I didn't include that.
storyboardist
Postby storyboardist » 20 Jul 2016, 14:42
New layout. A bit bigger than the old one but the pots can be board mounted and there are fewer jumpers.
For this message the author storyboardist has received thanks: 2
batteryacidtea (20 Jul 2016, 16:32), Manfred (20 Jul 2016, 17:17)
storyboardist
Postby Joel Tavares » 16 Feb 2017, 00:19
Hi, is this layout verified? Thnks
Joel Tavares
Next
Users browsing this forum: jubz, ma1891, psychepool and 6 guests
