Wampler Velvet Fuzz  [traced]
Re: Wampler Velvet Fuzz
Postby Mbas974 » 12 Nov 2013, 16:04
Tone part could be something like swtc...
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Postby Ripdivot » 12 Nov 2013, 18:02
Mbas974 wrote:Tone part could be something like swtc...
I don't think so, based on the PCB photos earlier in the thread. I would sure like to get this figured out though. Are we sure the tone cap value is correct?
Ripdivot
Have thanks: 65 times
Postby indyguitarist » 12 Nov 2013, 19:07
indyguitarist wrote:quick note. At a glance, tone control is wrong. Also, sort through all jfets, 5089's, and 386's to make sure you are using low noise parts, you'll find tolerance can be a bit varied and it's crucial in a circuit such as this unless you don't want consistency.
My mistake actually.... it has been 6 months since I designed the vf and I confused that tone control with one of the bazillion prototypes we do. Verified on on the schem that the tone control is correct. Sorry 'bout that.
For this message the author indyguitarist has received thanks: 9
batteryacidtea (12 Nov 2013, 22:39), Intripped (29 Jul 2016, 11:22), jallenshaw (12 Nov 2013, 19:34), jrod (12 Nov 2013, 21:18), mganzer (16 Nov 2013, 22:59), Motter (22 Nov 2013, 20:40), nenecarrizo83 (12 Nov 2013, 19:32), Nocentelli (12 Nov 2013, 19:20), reddo (12 Nov 2013, 22:37)
indyguitarist
Have thanks: 161 times
Postby Ripdivot » 12 Nov 2013, 23:05
Brian you are a great guy, thanks for all your help on this site. I own a couple of your pedals and will likely buy a velvet as well. :applause:
Ripdivot
Postby sdlogan9 » 13 Nov 2013, 03:33
Ya great Pedal!!!
-Shane
sdlogan9
Postby benobo » 13 Nov 2013, 19:57
Evening,
here my take on the VEElvet Fuzz. It is based on Pindildo's schematic WVF V1.0.
a couple of things to add;
1 solder a 220pf cap between lugs 3 & 2 of the Fuzz pot
2 the switch mod doesn'select either 4.7nf or 33nf but add or remove 33nf, it won't make a big difference to your ultrasonic ears anyway...
The vero is a bit crowded and of course... not verified yet. Might have made a few mistakes but who cares..
My pleasure.
For this message the author benobo has received thanks:
joeboo88 (26 Nov 2013, 21:27)
benobo
Has thanked: 42 times
Have thanks: 11 times
Postby jallenshaw » 16 Nov 2013, 02:21
benobo wrote:Evening,
Thanks for that tip....the added bright cap (220p onto the already present 100p =320p) brings the bright/tone control into a very useable range, allowing for more brightness on tap for darker natured guitars.
JAS
jallenshaw
Have thanks: 6 times
Postby jallenshaw » 16 Nov 2013, 03:37
Well, I have to re-assert just how fantastic this pedal is....simply a great tube-like OD if adjusted just so, and of course the fuzz-into-stack tones are great, too!
If you watch the Brett Kingman demo of the VF on youtube, he just sits there speechless for a while with a big grin on his face.....I find myself doing the same thing quite often.
After living with the VF a while, I have another tip for the adventurous.
I subbed in a 2SK170 GR for the FAT/BIG trannie (slightly higher gain than the 2SK170 BL I already had in there) and biased it slightly cold.
If you build my vero version (verified) then you have a bias trimmer....with the FAT/BIG engaged, turn that trimmer until the guitar signal is loudest, then turn it back CCW ever-so-slightly until you hear just a slight decrease in output.
Adjusted like that (with a 2SK170GR) the FAT/BIG side will do the Dumble thing (into a clean Fenderish channel) VERY good indeed!
Happy building! (And tweakin'). :thumbsup
JAS
jallenshaw
Postby crw414tele » 26 Nov 2013, 09:30
Here is my finally finished version.I kept the fuzz master volume as well as the tight/fat controls and have wired it so I can use the plexi drive on its own or with the fuzz and the fuzz can also be used on its own to boost other pedals.The fuzz side LED changes colour depending on which side of the fuzz is selected.It was a squeeze to get all that in one box but it's worth it .It sounds great ,crunchy drive , light fuzz to flat out fuzz :horsey:
crw414tele
Has thanked: 17 times
Have thanks: 15 times
Postby jallenshaw » 26 Nov 2013, 13:36
Looks great!
JAS
jallenshaw
Postby PmCimini » 28 Nov 2013, 19:29
Still dont get the optocoupler switching... Seems a really bad idea from a production point of view
PmCimini
Has thanked: 24 times
Have thanks: 3 times
Postby jallenshaw » 28 Nov 2013, 20:29
PmCimini wrote:Still dont get the optocoupler switching... Seems a really bad idea from a production point of view
Neither do I. :scratch:
If it is for quieter switching, I just used the BJF/MP/Bearfoot method (a 5.1v zener in series with the LED CLR) and a standard 3PDT wired in a typical manner and have silent switching......
JAS
jallenshaw
Postby crw414tele » 09 Dec 2013, 05:43
I've had some interest as to how I wired my switches so I've done a layout for anyone interested. The layout is here for the fuzz section. viewtopic.php?f=7&t=22737&start=100#p230353.
The plexi circuit I used is from tagboard effects http://tagboardeffects.blogspot.com.au/ ... drive.html
pretty sure it's right , I didn't open the pedal, it's never coming off my pedal board :thumbsup
For this message the author crw414tele has received thanks:
stagolee (14 Dec 2013, 02:02)
crw414tele
Postby andregarcia57 » 09 Dec 2013, 16:05
My pleasure.
ok!!! for 4.5v transistor
Q1 = R1 = 20K
Q2 = R13 = 12K
Q3 = R15 = 11K2
Q4 = R19 = 12K
thanks!
andregarcia57
Have thanks: 87 times
Postby freq67 » 10 Dec 2013, 23:41
Being that Brian is into amp in a box themes.....He could of called this the Guytron. Same concept. Very cool design Mr. Wampler. :D
freq67
Have thanks: 9 times
Postby tinkercreek » 25 Dec 2013, 22:34
JAllenShaw
I am building your modified layout from Nocentelli. Finished everything and am doing the final wiring in the enclosure. Just wanted to check on something before I complete the last few connections. I notice that there are connections to Tight Drive 2 both from S1 and from the board. It appears that for Fat Drive 2, there is only a connection from S1. I was just making sure I wasn't missing a connection for Fat Drive 2 from the board - there is none labeled for that from the board.
I'm still working on my schematic to layout interpreting so I apologize if it's a dumb question. Just wanted to make sure before I finish so I don't have to back out and redo.
Thanks for the layout - really been looking forward to getting this done. I do have some 2SK170 GRs so I'll definitely be trying that sub as you mentioned.
Thanks man
tinkercreek
Have thanks: 2 times
Postby jallenshaw » 27 Dec 2013, 08:26
Hello tinker,
Yes, the extra tight pot pin 2 connection to the board is for the 100n cap to ground (which the fat pot doesn't have)
Also, MPSA18 sounds really good for the fat trannie, too....try different ones to your taste (re-bias, of course)
JAS
jallenshaw
Postby tinkercreek » 27 Dec 2013, 15:33
JAS
Thanks for the reply. I must admit though, that I got bored and went ahead and completed it before I got the reply since I was almost finished anyway. Afraid I've botched something in the build. The FAT side works but I get no sound on the tight side. I've set it aside for a couple of days while I finish a couple other builds that I have going.
The sound that I got on the fat side was good, although a good bit woofy and dark ( and I play single coils almost exclusively ). I didn't sub on the transistor yet though and will see what that does to the tone. I'll dig back into this weekend and see what I've done wrong.
Thanks again for the layout and the reply to my question.
tinkercreek
Postby stagolee » 31 Dec 2013, 20:10
crw414tele wrote:I've had some interest as to how I wired my switches so I've done a layout for anyone interested. The layout is here for the fuzz section. viewtopic.php?f=7&t=22737&start=100#p230353.
So I finished up a 1590bb build for this circuit using the wiring shared above for a 2-in-one arrangement. I really like being able to use the fuzz sections to drive other pedals, finding especially nice tones with my build of the crunch box. One issue though is that the setting seems too high on the fuzz master volume to get a good sound with the plexi side engaged, so that when the plexi side is off the volume spikes. not sure if another resistor or different pot values would be the best approach to balancing this out. Or if there might even be a way to wire it such that the fuzz master volume did not control the plexi side of the circuit.
Can anyone offer any pointers?
stagolee
Postby Nocentelli » 31 Dec 2013, 21:47
Just to check I understand correctly: You have the input section (BJT or 386 boost selectable with a switch, and a separate output level control for each type of boost) on one bypass switch, and a plexi circuit on another bypass switch, and when you engage the fuzz/boost side into the plexi and set the fuzz/boost output so it sounds good stacked, on it's own (without the plexi) it's too loud?
Nocentelli
Has thanked: 871 times
Have thanks: 839 times
Users browsing this forum: JBassTeleGuit and 10 guests
