Rockett - Animal Overdrive  [traced]
Postby Manfred » 14 Jul 2013, 22:12
Link
Updated schematic
For this message the author Manfred has received thanks: 16
bajaman (14 Jul 2013, 22:23), Dirk_Hendrik (15 Jul 2013, 06:24), HENK (15 Jul 2013, 07:35), Intripped (14 Jul 2013, 23:08), IvIark (15 Jul 2013, 12:03), modman (12 Feb 2017, 16:50), nooneknows (29 Jul 2013, 14:22), rcustoms (14 Jul 2013, 22:35), sinner (15 Jul 2013, 10:08), tp801 (19 Jul 2013, 18:29) and 6 more users
Has thanked: 890 times
Have thanks: 394 times
Re: ROCKETT ANIMAL [traced]
Postby alexradium » 15 Jul 2013, 10:05
Is this recent?
Very similar to the Blue Note,just the pot gain and some resistors different,best way to save product cost and design....i guess this was a Wampler's project,maybe slightly refined later.
what about that Indyguitarist?
alexradium
Has thanked: 48 times
Have thanks: 52 times
Postby Manfred » 27 Jul 2013, 02:38
Here the corrected schematic.
The DC-input protection diode polarity was wrong.
The OP-amp output was wrong labeled.
chaosphere (27 Jul 2013, 08:27)
Postby nooneknows » 29 Jul 2013, 14:24
Disappointing, nothing more than a sort of timmy without the output OAmp.
nooneknows
Has thanked: 22 times
Have thanks: 5 times
Re: ROCKETT ANIMAL [tagboard layout; but schematic updated s
Postby IvIark » 29 Jul 2013, 21:46
2 is also the inverting input and 3 non-inverting. Verified vero layout, thanks for the scheme
For this message the author IvIark has received thanks: 4
AJPennypacker (11 Feb 2017, 16:09), Fredenando (29 Jul 2013, 22:58), Manfred (29 Jul 2013, 22:13), zick (04 Jan 2014, 01:17)
IvIark
Has thanked: 662 times
Have thanks: 675 times
Postby Manfred » 29 Jul 2013, 22:22
IvIark wrote:2 is also the inverting input and 3 non-inverting. Verified vero layout, thanks for the scheme
Thanks for the hint and the strip board layout.
Corrected schematic:
Updated schematic
modman (12 Feb 2017, 16:52)
Postby Sept29 » 31 Jul 2013, 13:53
Hi, Manfred. Thank you for your nice schematics.
I have a question. +VS is connected to the 7th pin of JRC4558 in your schematics.
In IvIark's layout, I think +VS is connected to the 8th pin.
Which is right?
Sept29
Postby alexradium » 31 Jul 2013, 15:27
Sept29 wrote:Hi, Manfred. Thank you for your nice schematics.
Which is right?
being a 4558 chip,its gotta be pin 8.
For this message the author alexradium has received thanks:
Sept29 (01 Aug 2013, 01:10)
alexradium
Postby Manfred » 02 Aug 2013, 15:43
Sorry for the issues with the OP-amp pin designations.
Thanks for the hints.
Here the corrected schematic:
Updated schematic
modman (12 Feb 2017, 16:52), Sept29 (03 Aug 2013, 15:56)
Postby indyguitarist » 02 Aug 2013, 16:03
alexradium wrote:Is this recent?
Kinda but not quite.
We 'worked' together for a few months about 5 years ago. I came up with the schematic for the afterburner (which became the flexdrive) and had built a proto for a light overdrive that was a super simple build which I guess eventually became the blue note. We (me or Wampler Pedals) no longer have any affiliation, whatsoever, with Rockett now.
indyguitarist
Have thanks: 157 times
Postby stringline » 27 Aug 2013, 10:16
Any chance to see the PCB layout guys?
Thanks in advance :applause:
stringline
Has thanked: 18 times
Postby Manfred » 28 Aug 2013, 08:13
sorry, I sold the Animal after tracing.
Postby roberttomasz » 25 Nov 2014, 21:35
Schematic +VR = 470k-470k ,,, oryginal effect- +VR = 47k-47k ?????
For this message the author roberttomasz has received thanks:
Manfred (25 Nov 2014, 23:03)
roberttomasz
Have thanks: 17 times
Postby Manfred » 25 Nov 2014, 23:03
roberttomasz wrote:Schematic +VR = 470k-470k ,,, oryginal effect- +VR = 47k-47k ?????
Thanks for the hint, you are right!
Updated schematic
Postby roberttomasz » 16 Oct 2016, 07:42
4558 - IN +(3) ,, IN-(2),,OUT (1),, +9V/(8). Dioda 4001 ma być odwrotnie !!!!!
roberttomasz
Re: ROCKETT ANIMAL [traced]  [traced]
Postby Manfred » 16 Oct 2016, 16:10
roberttomasz wrote:4558 - IN +(3) ,, IN-(2),,OUT (1),, +9V/(8). Dioda 4001 ma być odwrotnie !!!!!
Thank you very much for the hint.
Moonsun (19 Oct 2016, 14:43)
Postby AJPennypacker » 11 Feb 2017, 16:05
Thanks for the work on this, I built on vero and really love this pedal. I want to make one with a second stomp instead of a switch for the snarl, I'd also like to be able to increase the volume on the snarl, either a fixed boost or better yet a variable boost set by an internal trim pot. I'm new to this so if anyone could assist with some direction I'd be grateful.
AJPennypacker
Postby Manfred » 11 Feb 2017, 17:28
Should the boost mod works in both snarl settings?
AJPennypacker (11 Feb 2017, 23:17)
Postby AJPennypacker » 11 Feb 2017, 21:19
Believe the snarl is either engaged for the modded Plexi sound or not for the non-snarl/modded sound, so just want it when snarl is engaged. My best idea so far is to add a simple boost circuit to the snarl side (micro amp, EP boost). Gonna give it a go today.
AJPennypacker
Re: ROCKETT ANIMAL
Postby HamishR » 04 Dec 2017, 04:32
From a technical POV this may be "disappointing" but from a player's POV it's just fine. :-) The Animal, Blue Note and now the Majestic are all very similar but they sound great! For such simple circuits they work exceptionally well. I actually think it's extremely clever to get such cool sounds from so few parts. I'm no electronics guy, just someone who loves guitar and getting great sounds. So for me these circuits are amazing. All three pedals sound good and different enough from each other to justify having each one.
HamishR
Have thanks: 9 times
Users browsing this forum: frooshontay, Google [Bot], jswinue and 13 guests
