EWS Little Brute Drive  [traced]
Postby zedsnotdead » 11 Sep 2013, 15:00
Ok, so I have a friend of mine that wants to make the trimpots on this available outside the enclosure.
Since I never had a chance to contribute, here are some gut shots (click to enlarge).
What do you think? What is it based of?
For this message the author zedsnotdead has received thanks: 5
Blitz Krieg (24 Dec 2014, 10:50), Fredenando (12 Sep 2013, 16:22), Intripped (12 Sep 2013, 08:26), Manfred (13 Sep 2013, 22:16), Sept29 (15 Sep 2013, 22:59)
zedsnotdead
Has thanked: 33 times
Have thanks: 53 times
Re: EWS Little Brute Drive
Postby allesz » 11 Sep 2013, 15:58
Wow, I always found this little pedal incredible construction wise; making place for the 9V battery in a 1590a enclosure is not easy.
Post the values for the caps if you have the pedal still open.
How does it sounds, and what the internal pots do? maybe you just can drill two small holes on the back in order to use a little screw driver.... otherwise, even with 9mm pots, it seems hard to save the battery.
Thank you.
allesz
Has thanked: 46 times
Have thanks: 120 times
Postby alexradium » 11 Sep 2013, 16:05
i guess its similar to the Brute drive without the EQ/boost section,dual opamp with leds to ground,please explain the pots functions.
alexradium
Has thanked: 51 times
Postby alexradium » 11 Sep 2013, 16:08
Also take note of all the resistor and caps values,i could try a tracing
alexradium
Postby alexradium » 11 Sep 2013, 16:19
If you bring out the trimpots it will look a lot like a crunch box,only difference being the gain pot which is doubled,i guess one on each stage feedback.
alexradium
Postby zedsnotdead » 11 Sep 2013, 16:34
Well, I am going to put the circuit into a 1590B, drill 3 holes for the gain, level and tone (those last two are the trimpots).
Need to get the value of the caps and resistors also.
It has a IC which is sanded on top to hide the brand/model/type.
I will keep you posted.
zedsnotdead
Re: EWS Little Brute Drive  [traced]
Postby bigorangefan79 » 12 Sep 2013, 05:55
For this message the author bigorangefan79 has received thanks: 11
Bill_Mountain (13 Sep 2013, 14:53), dv8r601 (18 Aug 2017, 16:49), Fredenando (12 Sep 2013, 16:17), Intripped (12 Sep 2013, 08:26), jimpajohn (11 Aug 2014, 16:14), Manfred (13 Sep 2013, 22:16), modman (25 Jul 2017, 02:35), Nocentelli (12 Sep 2013, 06:48), rustvalid (17 Sep 2013, 03:11), Sept29 (15 Sep 2013, 22:58) and one more user
bigorangefan79
Have thanks: 28 times
Postby zedsnotdead » 12 Sep 2013, 11:39
@bigorangefan
you already have this one? :D
Should I re-check the values?
zedsnotdead
Postby bigorangefan79 » 13 Sep 2013, 01:50
Yeah, just realized I'd never shared it. Great mean little pedal.
bigorangefan79
Postby zedsnotdead » 13 Sep 2013, 14:23
Do you have a PCB layout for it also?
i am asking because I don't know how to work with software (e.g. eagle), but I am making efforts to understand how it works... to date I am a bit frustrated though.... :oops:
zedsnotdead
Postby alexradium » 18 Dec 2014, 11:01
bigorangefan79 wrote:
i'm on my way to try this circuit,i noticed the 400k bias resistor is tied to the collector ,not Va which is typical.
Is it correct this way?
thank you
alexradium
Postby Nocentelli » 18 Dec 2014, 12:25
thank you
Big muff Q1 is similar.
mmolteratx wrote:absolutely zero commercial use allowed. If I find anyone selling these, I'll fly to your house and kick you in the nads. And you may or may not find yourself in trouble.
alexradium (18 Dec 2014, 12:33)
Nocentelli
Has thanked: 842 times
Have thanks: 829 times
Postby mmolteratx » 18 Dec 2014, 22:09
thank you
Self bias. I think it was actually the first way we were taught to bias transistors in my intro to circuits class. Then the resistor divider.
mmolteratx
Has thanked: 103 times
Have thanks: 622 times
Postby marcao_cfh » 21 Jul 2017, 22:22
Sorry for ressurrect this thread, but I'm confused about the gain pot. Is it linear or log? GainA is log and gainB is lin at the schematic. Also, does anybody still have the pictures of the original board?
marcao_cfh
Has thanked: 29 times
Have thanks: 21 times
Users browsing this forum: No registered users and 22 guests
