Dumbloid  [traced]
Re: Dumbloid
Postby johnk » 08 Mar 2014, 21:02
thanks. it's called a Fresnel lens. it just requires a 1/4" hole and it holds any standard 5mm led in it.
I get mine from mouser.
johnk
Has thanked: 32 times
Have thanks: 273 times
Re: Dumbloid
Postby LaceSensor » 09 Mar 2014, 09:02
johnk wrote:I built one using IvIark's rev2 layout. I didn't care for the OPA2134's fizzy decay , especially noticeable at the brighter settings, so I tried 30 different dual opamps in it and the MC33172N sounded great in it so I went with that.
I also added the Jazz/Rock switch to it so it's now a 'special'.
here's a couple of pics of mine in 1590B:
[ Image ]
[ Image ]
That's badass man, nice polish on the top part of the box.
Now to sell for $300 on TGP, right?
LaceSensor
Has thanked: 45 times
Have thanks: 248 times
Re: Dumbloid
Postby Jack Deville » 09 Mar 2014, 09:24
mmolteratx wrote:Did up a PCB since a buddy wants one. Once it's verified, I could do a small run. Price would be $5 plus shipping.
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
Jack Deville
Have thanks: 91 times
Re: Dumbloid
Postby Manfred » 09 Mar 2014, 11:28
The slewrate of the MC33172N is 2V/MicroSecond, the slewrate of the OPA2134 is 20V/MicroSecond.
I guess, that is the whole secret.
Manfred
Has thanked: 1038 times
Have thanks: 624 times
Re: Dumbloid
Postby astrobass » 09 Mar 2014, 16:52
Unlikely. I believe 2V/microsecond is still high enough to not affect frequency response in the audible range.
In this application the op amp is rail clipping on one side. Most op amps don't sound good when they're forced to clip in this fashion. There's really no specific datasheet value that will identify an op amp that will sound good or not when used this way.
astrobass
Has thanked: 50 times
Have thanks: 73 times
Re: Dumbloid
Postby johnk » 09 Mar 2014, 17:21
I agree completely. out of the others that tried (and even a few stacked ones), their spec of faster or slower slew rate didn't seem to be what made one sound better than the other when clipping.
johnk
Re: Dumbloid
Postby Cannibal » 09 Mar 2014, 17:22
TLC2262 to my ears clips more gracefully than most of the other opamps. Dunno it's because it's a MOS opamp or because of it's abysmal slew rate (0.35 to 0.55 Volt per millisecond, according to the datasheet).
Seiche wrote:there's a difference between being drugged (I don't think it was only booze) and retarded.
Cannibal
Has thanked: 31 times
Have thanks: 15 times
Re: Dumbloid
Postby astrobass » 09 Mar 2014, 18:03
Cannibal wrote:TLC2262 to my ears clips more gracefully than most of the other opamps. Dunno it's because it's a MOS opamp or because of it's abysmal slew rate (0.35 to 0.55 Volt per millisecond, according to the datasheet).
Having a really low slew, in that range, will limit the amount of high frequency sound getting clipped and this can help eliminate some of the fizz/harshness. It's got to be a LOT lower than 2 V before that makes an audible difference.
That said, I find the LM741 to sound awesome on its own, and I've read on here that the 4558 also works really good for this and I don't believe either have slew rates that audibly affect frequency response.
So I guess if you were guessing op amps that might sound good, going with something under 0.6V slew rate might improve your odds of grabbing a winner or at least, something that doesn't sound as bad as some of the alternatives. It seems like most of the op amps that sound better in this application seem to be older, noisier designs. It could be that the things more modern designs are doing to achieve lower noise, higher slew, lower heat, etc are counterproductive to this purpose.
astrobass
Re: Dumbloid
Postby johnk » 10 Mar 2014, 06:04
well, i'm really happy with the MC33172N and I tried a couple of 4458's (RC4458P, JRC4558D) and they had fizzy decays too. a JRC4562D sounded a bit better than the OPA2134 to me but still was a bit fizzy.
the TLC2262 is one that I didn't happen to try since the MC33172 sounded so good, but I might try that one too just for fun.
I know do that TL062's, TL072's, TL082's, 4459's, 4580's, OPA2604, LM1458, HA17458, LM258, LM348N, LM358N, NE5532, LF442 and LM883's didn't work very well in it.
I've read that the MC33172 is basically a dual 741 so that's probably why it works so well in this circuit.
For this message the author johnk has received thanks:
atreidesheir (10 Mar 2014, 08:56)
johnk
Re: Dumbloid
Postby roseblood11 » 10 Mar 2014, 09:33
a LM1458 is "basically a dual 741" as well...
Did you try any rail-to-rail opamps, like TLC2272?
roseblood11
Has thanked: 352 times
Have thanks: 315 times
Re: Dumbloid
Postby Manfred » 10 Mar 2014, 09:53
You are right, I had a shift of one decimal power while calculating, the frequency response will not affected up to 70 Kilohertz.
What the reason for the audible for the audible sound differences depend on the op amp type?
Manfred
Re: Dumbloid
Postby deltafred » 10 Mar 2014, 10:48
Manfred wrote:What the reason for the audible for the audible sound differences depend on the op amp type?
How they operate outside their design spec. They were never designed to reach clipping so how they react when they do can vary dramatically.
Some ring or generate a spike before they settle to their "clipped state". It is most probably this that determines whether they sound good or not.
deltafred
Has thanked: 404 times
Have thanks: 264 times
Re: Dumbloid
Postby Manfred » 10 Mar 2014, 14:31
It would be in interest to have some oscillograph curves in which the clipping signal for different op amps are shown.
Manfred
Re: Dumbloid
Postby MoonWatcher » 10 Mar 2014, 15:09
Manfred wrote:It would be in interest to have some oscillograph curves in which the clipping signal for different op amps are shown.
Yes, especially if there were ones that were somewhat considered to sound 'not bad' when they clip.
We may not see a visual pattern, but there still might be something of use. Maybe something typically present, or something typically missing.
MoonWatcher
Has thanked: 43 times
Have thanks: 65 times
Re: Dumbloid
Postby johnk » 10 Mar 2014, 18:51
i just tried a 2262 in it, and while it's better than the OPA2134, to me the MC33172 sounds the best (i.e. has the best sounding opamp distortion).
johnk
Re: Dumbloid
Postby deltafred » 10 Mar 2014, 19:57
I have seen a website somewhere with a load of scope traces. I will have look and see if I can find it.
deltafred
Re: Dumbloid
Postby andregarcia57 » 11 Mar 2014, 01:29
johnk wrote:well, i'm really happy with the MC33172N and I tried a couple of 4458's (RC4458P, JRC4558D) and they had fizzy decays too. a JRC4562D sounded a bit better than the OPA2134 to me but still was a bit fizzy.
hello ... where can I find MC33172N with good price and original.
no difference MC33172N and MC33172P, MC33172PG ?
andregarcia57
Have thanks: 87 times
Re: Dumbloid
Postby johnk » 11 Mar 2014, 04:43
I got mine from mouser.
johnk
Re: Dumbloid
Postby box » 11 Mar 2014, 06:33
Please check here:
http://www.ebay.com/itm/MC33172N-Dual-B ... _56wt_1105
Rgds,
box
box
Have thanks: 34 times
Re: Dumbloid
Postby andregarcia57 » 11 Mar 2014, 14:03
Please check here:
Rgds,
box
Does not ship to Brazil!
:cry:
exists between different ICs?
andregarcia57
Users browsing this forum: jalmonsalmon and 12 guests
