Mad Professor - Royal Blue Overdrive
Postby pamaz » 02 Jan 2014, 09:31
hello all.
Somebody out there has any info that is willing to share?
Paolo
pamaz
Has thanked: 29 times
Have thanks: 10 times
Re: royal blue od - mad professor
Postby miter53 » 08 Jun 2014, 19:22
bump
miter53
Postby Dingleberry » 25 Sep 2015, 11:39
Found a gut shot from a Japanese site. Not much but at least something.
Simplify before you amplify.
For this message the author Dingleberry has received thanks: 2
modman (02 Oct 2016, 19:11), rocklander (25 Sep 2015, 15:41)
Dingleberry
Have thanks: 35 times
Postby BJF » 27 Jul 2016, 15:44
Hi there,
Right, well what do you want to know?
At your sincere service
BJ
For this message the author BJF has received thanks: 2
deltafred (27 Jul 2016, 18:02), sprentiss (30 Sep 2016, 18:48)
BJF
Have thanks: 54 times
Postby jamesdlow » 30 Sep 2016, 17:36
BJF wrote:Hi there,
BJ
Not the original poster but I have a few questions.
1) Looks like a bufferless TS style circuit with passive tone right?
2) I know you often use extended feedback loops around the opamps. Any of these at work here?
3) What frequency ranges are your tone and bass pots working at?
jamesdlow
Re: Mad Professor - Royal Blue Overdrive
Postby BJF » 03 Oct 2016, 03:22
Hi There James,
1) if you wish- actually using limiting diodes in the feedback loop is much older than that ;)
2) yes and that one is to limit the HiFi treble-sadly at my age or from rocking too hard in my leathers as it says on the internetz I no longer hear these super sonic frequencies but I know they are there and I can count on them from memory of better hearing days. The way the filter works here is that it feeds back a portion of the highest frequencies and nulls them at the inverting input. The whole point being to have some of the treble present but restricting treble a little.
3) Treble makes boost and cut at about 2KHz but boost is made milder by allowing some upper mids by the aid of the 3-dB filter; Bass makes near symmetrical boost cut at about 100Hz while high pass occours in the circuit at about 70Hz bending the boost downwards at lowest frequencies. The notch created at full boost is centered at about 750Hz and that also makes the peak when in full cut.
At your service
BJ
Belanger88 (30 Jun 2017, 18:04), IvIark (05 Oct 2016, 19:34)
BJF
Postby Skreddy » 09 Oct 2016, 02:20
Blah blah blah Where's the perfboard layout, Bjorn!?! :lol:
For this message the author Skreddy has received thanks:
modman (09 Oct 2016, 09:59)
Skreddy
Have thanks: 224 times
Postby BJF » 10 Oct 2016, 22:22
Hi there,
Actually I was wondering about the correct spelling of blah for the press release of my latest Fuzz:
It sounds like blah and behaves like blah, when you blah it. :hmmm:
Oh I'd be sure someone will do the honours with perfboard :thumbsup
Have fun
BJ
BJFElectronics
Sweden
BJF
Postby HamishR » 27 Jun 2017, 11:51
I have one of these and would be interested in the circuit so I can build an "inspired by the Royal Blue overdrive" pedal. I'm not very good at drawing schematics but I can list all of the components and give and indication where they join if that helps? I tend not to like LEDs as clipping diodes, so they would be the first thing I would change. I think it's actually a very cool pedal. I like having bass and treble controls much better than nature knobs. :-)
Is anyone else interested in how this thing ticks?
HamishR
Have thanks: 9 times
Postby HamishR » 28 Jun 2017, 12:34
Today I swapped the LEDs out for 1N4148 diodes and I like it a lot better. I'm also sure that a lot of guys would prefer the LEDs! I like the 4148s because they make the sound a bit crisper. They seem to have made the pedal a bit more "rock" to me. Really good overdrive.
HamishR
Postby modman » 30 Jun 2017, 18:38
HamishR wrote:Today I swapped the LEDs out for 1N4148 diodes and I like it a lot better. I'm also sure that a lot of guys would prefer the LEDs! I like the 4148s because they make the sound a bit crisper. They seem to have made the pedal a bit more "rock" to me. Really good overdrive.
Thanks so much for those pictures!
Has thanked: 3081 times
Have thanks: 534 times
Postby lovetone » 06 Aug 2017, 15:37
Just wondering if anyone has the schematic to the Royal Blue overdrive?
lovetone
Have thanks: 8 times
Users browsing this forum: JohnyBgoode, koesheryanto and 28 guests
