Secretefx - Secret-1 STD overdrive  [traced]
Postby YuGi » 09 Feb 2014, 17:45
Hi all, I dissected the secret-1 pedal. The work is already on the italian forum http://www.fennecelectronics.it, http://www.fennecelectronics.it/smf/index.php?topic=11684.0
The soul of this hobby is sharing informations, so.. my two cents to the community :mrgreen:
As you can see, lot of degooping work :slap:
For this message the author YuGi has received thanks: 7
Cub (09 Feb 2014, 20:50), Fredenando (09 Feb 2014, 23:03), Intripped (09 Feb 2014, 23:18), IvIark (09 Feb 2014, 18:20), McKenzy (11 Feb 2014, 01:04), modman (31 Mar 2018, 21:43), rocklander (14 Jul 2014, 00:43)
YuGi
Have thanks: 26 times
Re: Secret-1 STD overdrive  [traced]
Postby YuGi » 09 Feb 2014, 17:52
I removed and measured all components. This is the "naked" PCB :D
And finally the schematics :applause:
What you think about? On the other forum we are discussing about in and out buffers.. is not strange that biasing? :scratch:
For this message the author YuGi has received thanks: 12
atreidesheir (09 Feb 2014, 19:04), Fredenando (09 Feb 2014, 23:03), Intripped (09 Feb 2014, 23:19), IvIark (09 Feb 2014, 18:22), jrod (09 Feb 2014, 18:08), Manfred (10 Feb 2014, 01:18), modman (31 Mar 2018, 21:43), Nocentelli (09 Feb 2014, 19:50), rocklander (14 Jul 2014, 00:43), tp801 (09 Feb 2014, 18:53) and 2 more users
YuGi
Re: Secretefx - Secret-1 STD overdrive
Postby IvIark » 09 Feb 2014, 18:24
Thanks for this :applause:
What are the transistors?
IvIark
Has thanked: 662 times
Have thanks: 675 times
Postby YuGi » 09 Feb 2014, 18:30
IvIark wrote:Thanks for this :applause:
All components values are scraped! Then i can only say BJT NPN, hFE around 200.
modman (31 Mar 2018, 21:44)
YuGi
Postby IvIark » 09 Feb 2014, 18:42
Great, thanks
IvIark
Postby AAntonio » 09 Feb 2014, 19:18
Great!!!!! :applause:
AAntonio
Have thanks: 15 times
Postby okgb » 09 Feb 2014, 19:25
Nice work , seems to be nothing special is that considered active tone control ?
and funny that those huge caps are even silk screened on the pcb .
okgb
Has thanked: 189 times
Have thanks: 41 times
Postby Nocentelli » 09 Feb 2014, 19:28
YuGi wrote:What you think about? On the other forum we are discussing about in and out buffers.. is not strange that biasing? :scratch:
+1
It looks like it's missing a 1M to ground from the base of both BJTs. That would make sense.
mmolteratx wrote:absolutely zero commercial use allowed. If I find anyone selling these, I'll fly to your house and kick you in the nads. And you may or may not find yourself in trouble.
Nocentelli
Has thanked: 842 times
Have thanks: 829 times
Postby IvIark » 09 Feb 2014, 19:37
In the Tubescreamer and similar the base resistor goes to VCC/2
IvIark
Postby YuGi » 09 Feb 2014, 19:42
+1
The schematics is absolutely correct (I have the PCB on my desktop..).
I simulated the buffers with LTspice and the headroom is better then a classic bjt buffer (bias with 1M to v/2 and 10K emitter resistor). Why?! :scratch:
modman (31 Mar 2018, 21:45)
YuGi
Postby Cub » 09 Feb 2014, 20:53
I don't remember where, but I saw a demo if it in front of a number of Big Muff pedals and it was a really nice sounding combination.
Thanks for sharing, YuGi ! :thumbsup
Cub
Has thanked: 67 times
Have thanks: 72 times
Postby smanq » 10 Feb 2014, 12:03
It's possible to bias a buffer in this way, but it's definitely the worse one, simply because it's higlhy hfe and temperature related.
A classic 2 resistors partition from supply and ground it's more stable and it permits to use a wide range of transistors (wide range of hfe), without any relevant difference in bias point. It will sound the same... or better (more dinamic, because you can adjust the bias point by design, not trying some different BJTs)!
If we connect the 1M resistor to V/2 like in a classic tube screamer, we've less trouble (less voltage difference across the resistor) and it will bias at good point.
If a circuit works fine from some decades, why we need to change it? :D
For this message the author smanq has received thanks:
modman (31 Mar 2018, 21:46)
smanq
Have thanks: 2 times
Postby pamaz » 10 Feb 2014, 12:35
hey smanq, its' exactly what I've written yesterday in the italian forum. We share the same thought.
pamaz
Has thanked: 29 times
Have thanks: 10 times
Postby Cannibal » 10 Feb 2014, 12:41
Aside from the buffers, is R5 just a positive feedback resistor? Also the frist opamp max gain is around 500x, so this thing should have a massive amount of distortion going on, instead is just a medium gain overdrive. Am i missing something?
Seiche wrote:there's a difference between being drugged (I don't think it was only booze) and retarded.
Cannibal
Has thanked: 31 times
Postby IvIark » 10 Feb 2014, 12:49
Here's the vero:
For this message the author IvIark has received thanks: 3
McKenzy (11 Feb 2014, 01:03), modman (31 Mar 2018, 21:46), rocklander (14 Jul 2014, 00:44)
IvIark
Postby YuGi » 10 Feb 2014, 14:02
Cannibal wrote:Aside from the buffers, is R5 just a positive feedback resistor? Also the frist opamp max gain is around 500x, so this thing should have a massive amount of distortion going on, instead is just a medium gain overdrive. Am i missing something?
The inverting opamp mixes dry and wet so the resulting wave is smootly distorted.
Cannibal (10 Feb 2014, 21:54)
YuGi
Postby Nick123 » 11 Feb 2014, 13:53
Schematic shows that the Gretsch Controfuzz could have been the source of the inspiration.
For this message the author Nick123 has received thanks:
pamaz (11 Feb 2014, 14:34)
Nick123
Have thanks: 9 times
Postby Mbas974 » 11 Feb 2014, 20:34
Please note that IL072 JRC4558 will works but in the original unit the chip is too silent...
we do not know exactly what it is but an OPA will be better choice
Mbas974
Has thanked: 40 times
Postby Agent86 » 13 Jul 2014, 14:12
is similars to Boss OD-1
Agent86
Postby IvIark » 31 Mar 2018, 21:33
Someone pointed out an error in the layout, the link to pin 2 should be going to pin 3, but I can't edit the post above so here is the updated layout.
For this message the author IvIark has received thanks: 5
dv8r601 (03 Apr 2018, 04:39), Manfred (01 Apr 2018, 00:00), modman (31 Mar 2018, 21:47), Nocentelli (31 Mar 2018, 22:47), sixthfloor (01 Apr 2018, 09:44)
IvIark
Next
Users browsing this forum: caspercody, gravelbed, jt, mirosol, Scorp, ultralord, x-tn and 26 guests
